lswindell4
journeyman
Reged: 02/07/13
Loc: Eastern North Carolina
Case for Fujinon Meibo's new
      #5674752 - 02/11/13 08:24 PM
Hi Everyone, I am a newbie to this forum and have the good fortune of just picking up a mint condition Fujinon Meibo 7 by 30 Marine version bino's. They didn't come with a case - any suggestions on where to find one?? Lew
brentwood
Reged: 11/04/05
Loc: BC Canada
Re: Case for Fujinon Meibo's new [Re: lswindell4]
      #5674874 - 02/11/13 10:00 PM
You sure they are not 7x50? I have never seen a case for a Meibo, but that does not mean they don't exist.
rookie
Good Night Nurse
Reged: 01/14/06
Loc: St. Petersburg, FL
      #5674878 - 02/11/13 10:02 PM
You can go to WalMart and get a small backpack to carry your binoculars. Here's a Fujinon brand if you want a match. It should fit yours too.
Fujinon Binocular Case
edwincjones
Close Enough
Reged: 04/10/04
Re: Case for Fujinon Meibo's new [Re: rookie]
      #5675296 - 02/12/13 06:13 AM
if not at WM, check at Camera stores for the camera bags
-better padding
-more options
edj
hallelujah
Reged: 07/14/06
Loc: North Star over Colorado
      #5675414 - 02/12/13 08:57 AM
Shirley,
The ad says that it is for the Fujinon 8x30.
The Fujinon 7x50 is both taller & wider than the 8x30.
Could be a problem?
Stan
lswindell4
journeyman
Reged: 02/07/13
Re: Case for Fujinon Meibo's new [Re: hallelujah]
      #5675463 - 02/12/13 09:40 AM
My bag brentwood, they are indeed 7x50's. Thanks for the advice everyone!!
Neil Sanford
Reged: 11/20/11
Re: Case for Fujinon Meibo's [Re: lswindell4]
      #5677756 - 02/13/13 02:08 PM
Your mint Fujinon 7x50 Meibo ... do the lens coating appear more like blue/purple or more like green?
Depending on answer, I will offer some comments on your bino and a case.
lswindell4
journeyman
Reged: 02/07/13
Re: Case for Fujinon Meibo's new [Re: Neil Sanford]
      #5681320 - 02/15/13 12:17 PM
Hi! My lens coating appears more blue/purple. Thanks!
rookie
Good Night Nurse
Reged: 01/14/06
      #5682107 - 02/15/13 06:24 PM
Shirley,
Could be a problem?
Stan
Yes, indeed the case would be too small if the bino's are 7x50 and not 7x30.
hallelujah
Reged: 07/14/06
      #5682174 - 02/15/13 07:03 PM
Fujinon has manufactured alot of binocular models over the years, but I don't recall ever seeing a 7x30.
Stan
lswindell4
journeyman
Reged: 02/07/13
      #5682238 - 02/15/13 07:48 PM
The bino's are indeed 7x50's, not 7x30's, my typo - sorry!
Neil Sanford
Reged: 11/20/11
      #5683608 - 02/16/13 02:11 PM
(1) Comments on a case: For this bino, you don't have the usual considerations. Usually, you would consider protection from moisture and shock. Well, not that I would recommend it, but your bino is so sealed and tough, in a pinch you could use it as a hammer in a hard shower. Another usual consideration is protection of the lenses. But yours likely has wonderful, attached, snap-in objective covers, and a good, one-piece eye-lens cover. (I assume it's the usual, rubber-covered Meibo; a non-rubber armored would not have the objective covers.) To keep the eye-piece cover in place during storage or carry, I have variously used the neckstrap, a rubber band or string. So with all the usual, important, protective considerations of a case already solved by this great bino, what's left? Comfort and convenience. For travel, I just put mine in a plastic bag, then in a suitcase or backpack. For carry, I have used a daypack or cheap, minimal bino case--not protective but for easy carry and access. Bottom line, this bino can take care of itself; choose any carry solution(s) you find convenient.
(2) Comments on your bino: Greenish coatings showed up on the later models. They noticeably improved color and contrast. That being said, your earlier model is still fantastic, with a view of rare quality. For color and contrast, I like mine with the newer coatings, but still return to my one with blue/purple lenses for a view that seems somehow more "sharp." And of course any Meibo 7x50 is near unbeatable for land or sea views in low light or night.
Edited by Neil Sanford (02/17/13 01:39 AM)
8 registered and 28 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, WOBentley
