Kent10
Reged: 05/08/12
Re: Oil on bottom of my TEC 160FL Objective new [Re: Jeff B]
      #5679542 - 02/14/13 01:50 PM
Thanks Jeff. That is on my list of what to try. Spit with clean finger and then clean up quickly. I am guessing I should clean it up with the Eclipse and a clean wipe. I think I will try the Eclipse with the Opto-wipes first to see how that goes. I did try breathing on it and using the micro fiber cloth but that wasn't enough. Thanks again.
EJN
Reged: 11/01/05
Loc: 53 miles west of Venus
Re: Oil on bottom of my TEC 160FL Objective new [Re: Kent10]
      #5679582 - 02/14/13 02:10 PM
If oil is puddling at the bottom of the lens, I would check the oil pump.
Perhaps someone could post a youtube video on how to change the oil or re apply the oil.
You remove the drain bolt in the oil pan, let the old oil drip out. Replace
the drain bolt, add new oil, check the level with the dipstick.
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: Oil on bottom of my TEC 160FL Objective new [Re: EJN]
      #5679614 - 02/14/13 02:25 PM
I feel your pain Kent. One time, my Denkmeier 14s had a grease leak and that stuff is very tough to clean. My guess is the absorbent Opto-Wipes will fix you up.
Kent10
Reged: 05/08/12
Re: Oil on bottom of my TEC 160FL Objective new [Re: johnnyha]
      #5679624 - 02/14/13 02:30 PM
Yes thanks Johnny. I am somewhat relieved however. When I first saw the streak, it was so perfectly formed that I thought it was a scratch and that is why I started cleaning it. I had to see what it was. At least it is not a scratch but what it is and how it got there ???? I hope the Opto wipes will work. I may have to use a little pressure to lift it off so we will see. I don't want to scrub.
mgwhittle
Reged: 08/24/11
Loc: Chattanooga, TN
      #5679640 - 02/14/13 02:36 PM
Forget the optiwipes and pecpads for the final wipe, they have their place in the cleaning process but not at the end when you are trying to get up the last of whatever it is on the lens. Just use plain white kleenex, one sheet per wipe for the final stage. Also I would not just try and clean a section of the lens but the whole lens, in my experience cleaning a section will just have you chasing around that final piece of residue from one area to another.
I will tell you what I use and have never had a problem either with damage or getting stuff off high end glass. After blowing off any dust, first clean with 91% isopropyl alcohol on a pecpad (or optiwipe), then blue windex with kleenex (one sheet per pass) then a pass of acetone on a pecpad. The acetone will leave a small residue at the point of the very last pass where you pull up the wipe. I then use my breath and single sheets of kleenex to get that last bit up.
The alcohol breaks down parts of the grime, the windex gets the other parts and with the kleenex gets it off the lens (something that will never happen if you use a pecpad), then the acetone takes care of residual cleaner and any remaining grime that the alcohol and ammonia in the windex didn't get and finally, your breath is an excellent distilled water to remove the very last remnants of the acetone.
And oh yeah....no scrubbing....all of this is with the truly slightest pressure. Let the solutions do the work of dislodging the grime, oil, whatever....the wipes are just to mop up what you have released from the lens.
Kent10
Reged: 05/08/12
Re: Oil on bottom of my TEC 160FL Objective [Re: mgwhittle]
      #5679667 - 02/14/13 02:48 PM
Wow Mark, thanks. That is quite the process. I worry about the acetone because of what is on the edges of the lens. I can see very small bits of felt maybe. I am not sure what it is but even with the Eclipse when I got close to the edge there was some black on the wipe. Of course the acetone could be used if you stay away from the edge. I will have to give this another try with the Opto-wipes once I receive them and then make some decisions. Do you like the Kleenex because it is even more absorbent than the Opto-wipes. Thanks again, Mark, for your detailed explanation.
mgwhittle
Reged: 08/24/11
      #5679749 - 02/14/13 03:30 PM
Pecpads are great for applying whatever cleaner and breaking free the contaminant, but in my opinion, plain white Kleenex does a much better job pulling the contaminant off the lens. As far as the acetone, if you have something already reacting to Eclipse then I would be cautious. That is disappointing if you cannot use it, it's a great final wipe. You don't need much of it, just a very small amount on a pecpad. It should be moist, not wet if that makes sense. As you wipe accross the surface it should dry instantly. In fact, Eclipse should be used the same way, if you swipe across the lens with Eclipse, it should be instantly dry. However, I am hesitant to say use any acetone if you are pulling black residue off already using the proper technique. Just to reemphasize the point, you are only using the very slightest amount of acetone or Eclipse to get rid of mostly the left over residue of the alcohol and windex.
teelgul
Reged: 09/02/11
Loc: Australia
      #5679893 - 02/14/13 05:02 PM
kent
i think you should contact TEC, , and try sending the objective in its present condition with out further cleaning. let them have a look and see whats the oil streak or whatever and if necessary clean it. its unusual to have such a sticky stuff on the lens . may be its a minor thing ,or may be a leak but let TEC do it as i believe they stand for their products.may be even they overlooked it the first time. the objective is the heart and better to get the best possible help and be at peace with something we value so much
regards
Kent10
Reged: 05/08/12
Re: Oil on bottom of my TEC 160FL Objective new [Re: teelgul]
      #5680065 - 02/14/13 07:09 PM
vaidya: Thanks for your advice. I am torn between sending it off again and doing it myself. But I have sent it to Yuri 2 times already and I worry about it in transit. Getting lost might be rare but dropping it could do harm even when packed so well. And the temperature shock problem that I have had might occur again. It happened when the scope was shipped to me from Illinois when I bought it used just a few months ago. It was $75 for cleaning and then with shipping both ways it turned out to be over $100. It would be nice just to have it professionally cleaned and be done with it if I didn't have to worry about the transit.
Kent10
Reged: 05/08/12
      #5680081 - 02/14/13 07:21 PM
OK everyone. I think I got somewhere with the cleaning. I like the Opto-pads a lot more but maybe I didn't give the Pec Pads enough of a chance. The Opto-pads are a lot thicker and they do absorb so I think that made the difference. I did have to press a little to get some of it off but I think it was fine. The lens is no longer cloudy but there are still some streaks along the edge and a few small marks elsewhere. The lens looks really good if viewed in normal light. It is only when I shine the flashlight on it that you can see all the streaks. I realize some say not to use the flashlight because you will always be disappointed.
So it is not perfect but from everything I have read I doubt it will affect my views at all and I am satisfied knowing I have a first rate scope. So now if only I would have the time to use it
It would be nice to know what the "gunk" is. I think it is coming from the edge because that is where it started and any time I got too close to the edge things would get worse so I stayed away from the edge after trying to clean it.
Thanks to everyone for all your advice. I really love this forum.
      #5680369 - 02/14/13 10:52 PM
Fog the lens with your breath and go over it with a PEC pad, and then check the surface again with a red flashlight. Breath fogging is always my final step whether cleaning objectives, correctors or eyepiece eye lenses. It does wonders for whatever reason. Just enough moisture to "float" the cleaning pad and remove stubborn, thin, residual streaks.
We still don't know, though, if your objective is leaking or the goop came from somewhere else, right? I'd keep a close eye on it.
- Jim
Kent10
Reged: 05/08/12
Re: Oil on bottom of my TEC 160FL Objective new [Re: jrbarnett]
      #5680395 - 02/14/13 11:15 PM
Thanks Jim. I did use the fog on the lens trick as a last step. I think it helped but there were still some streaks of the "stuff" near the edge and a few elsewhere. To get those I think I would have had to rub a little harder and I was already tired. It was getting to the point where it was getting worse as I tried to get the "stuff" near the edge. So I told myself to stop before I made it worse yet.
You are right. I will keep an eye on it to see if any oil does leak. I will also have to use it in the cold but there will be no shock as far as I understand shock. I have always let it cool down and warm up gradually so I think this was just an unusual case of frost buildup that eventually melted and maybe the wet from the frost did something that I will still find out about in the future. Yuri had it for 2 weeks and couldn't find any problem though so he sent it back. That streak of "stuff" that I saw was quite long and thick. It was about an inch long and a quarter inch wide and had the same curve as the edge of the lens, was close to the edge but not right up to the edge. So being such a "perfect" size it doesn't appear to be a result of the melting of the frost but that is just a guess. It was quite sticky or gooey considering how hard it was to remove. Before today I had never touched the back of the objective.
So you use a red flashlight to check the surface. I used white light. Will have to try red sometime.
johnnyha
Reged: 11/12/06
      #5680720 - 02/15/13 06:14 AM
Those stubborn edge stains! This is one of the two perfect uses I have found for the controversial, mini-chamois tipped Lens Pen Pro. I use only a fresh new lens pen - you have to be very careful with them because the chamois can grab grit. But nothing can clean up the edges of a refractor lens quite so easily and thoroughly as a Mini Lens Pen Pro. It's quick, it's easy. They also work well for cleaning out binoviewer prisms. But again, when using a lens pen on expensive optics that I only clean once or twice a year, I make absolutely sure to use a brand spanking new, fresh virgin unused lens pen!
Kent10
Reged: 05/08/12
      #5680846 - 02/15/13 08:35 AM
As it turns out I have a brand new Nikon brand lens pen that I have been saving for a special occasion. Maybe I will try it out on the objective some day. I think many also recommend using only brand name ones too. I once had a very cheap one and the black particles on the cloth tip were very noticeable. I decided not to risk using it and threw it out.
Yuri
Vendor - (Telescope Engineering Company)
Reged: 04/22/09
Loc: Colorado
      #5681259 - 02/15/13 11:50 AM
"I think Yuri would do himself a huge favor if he would post a pictorial guide on TEC's website showing how the TEC optical group is oiled, assembled and mounted in its cell. It might help alleviate some of the superstition about oil-spaced objectives. "
Jim,
the oiling techniques is kind of "know-how" to share on internet. And even if we would not count on this, the assembling, centering, sealing requires special equipment
including auto-collimator, etc. We also want to keep the immersion formula for internal use...
Many companies try to get into "oiled" design, but only two made it right.
Regards, Yuri
teelgul
Reged: 09/02/11
Loc: Australia
Re: Oil on bottom of my TEC 160FL Objective new [Re: Yuri]
      #5681493 - 02/15/13 01:25 PM
Regards, Yuri
Love to hear that .TEC ! thanks for tracking this very interesting thread .
Cheers
Vaidya
timwetherell
Reged: 09/03/10
Loc: A Land Down Under
      #5681769 - 02/15/13 03:22 PM
- Jim
It sounds more like an external source to me. I'd have thought a leak would create a blob not a streak? Given the thinness of the film you'd also think there'd be a bubble if it were a leak? But I agree Jim, keep an eye on it.
Before I bought my first oil spaced objective I nervously read lots about the potential horrors of oil leaks, oil degradation etc. But having owned a couple for several years now it's not something I ever worry about. If you have an air spaced objective there's the danger of fungus attacking the inner surfaces. Now it seems there's the danger of the lens being cracked by the sonic boom of giant meteors hitting the Earth.
There's been some good advice on cleaning posted here too. If it were me I'd clean it then just keep an eye on it. If anything odd happens (which I think is very unlikely) I'd just ask Yuri's advice and I'm sure he'll see you right. Most of all don't forget to get out under the stars and enjoy that awesome scope
Kent10
Reged: 05/08/12
Re: Oil on bottom of my TEC 160FL Objective new [Re: timwetherell]
      #5681828 - 02/15/13 03:48 PM
Thanks Tim. I have enjoyed reading your articles such as "How much glass is enough?" It was one of the reasons I wanted a Tec so badly. I was going after a 140mm but then the 160 came up. Your 200mm is so beautiful. Did you see it in this thread of prettiest scopes http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5655015/page...
I have cleaned my objective pretty much to my satisfaction. I haven't looked through it yet but I think it will be fine. And I will keep an eye out for any further oil leaks or frost. If it frosts that should just disappear with time. I am not sure if the frost leads to other problems but I will keep an eye on it.
      #5682284 - 02/15/13 08:25 PM
Thanks Yuri.
Good thing I didn't take it apart, then. I ain't got no special tools. But then again, I ain't got no problem with the optic, either.
I'm still very much enjoying the scope. I use it a couple of times a week, weather permitting.
Patrik Iver
Reged: 07/29/03
Loc: Kaarina, Finland
      #5682802 - 02/16/13 03:51 AM
Regards, Yuri
I hope you are wrong as I just recently ordered an oiled triplet from a (the?) third manufacturer of such refractors.
32 registered and 54 anonymous users are browsing this forum.
Moderator:  FirstSight, panhard, star drop, dr.who
