Escher
Reged: 08/30/07
Loc: Fenton, MI
CPC1100 complete overhaul new
      #5680934 - 02/15/13 09:16 AM
I'm in the process of overhauling my CPC1100. As you have read in my other thread in the CPC forum, my motor board died so I'm waiting on a replacement...
While I'm in there I may as well do it all.
Current plans:
- Motor Board swap (and any other electrical issue I find along the way)
- New bearings and Moly lithium grease
- Regrease and adjust all drives (currently had the "clunk/tick" issue)
- Flock tube
- (If I can get the funds together) Feathertouch focuser
Anything else I should do while I have it gutted? I was thinking about active cooling, but since it lives in a dome, I dont see the need...
I'll be posting pics of the process...
jerwin
Reged: 05/17/12
Loc: Romeoville IL
Re: CPC1100 complete overhaul new [Re: Escher]
      #5682289 - 02/15/13 08:27 PM
I think you have it covered. I'll be interested to follow your progress.
Escher
Reged: 08/30/07
Loc: Fenton, MI
Re: CPC1100 complete overhaul new [Re: jerwin]
      #5682393 - 02/15/13 09:29 PM
Ok... so here are some initial pics of the disassembly.
First - the base - no logic boards, just simple connector boards and power.
Cpc1100 disassembly by Christopher Purdy, on Flickr
Now the Right side arm - if facing the control panel - this has the GPS interface board and the GPS unit at the top.
And the Left side arm - this had the Locking clutch, motor and motor controller board:
I did another test tonight to make *sure* my issue is the motor controller board. I unplugged the GPS interface board and powered it on - still stuck at "initializing"... So.. not know exactly what the program code in the handset does - I have to assume it tests each subsystem - ALT, AZ, and GPS... since it never gets out of initializing, and knowing that if a motor fails you will get an error 16 or 17, then I can only conclude that the motor controller is not responding properly.
My new motor board will be here next week.
Next, while I wait for the motor board, I will be doing the base bearing mod, at least inspecting the bearings to start... that should happen Sunday or Monday.
Geo.
Reged: 10/01/08
Loc: Upstate NY
Re: CPC1100 complete overhaul [Re: Escher]
      #5683127 - 02/16/13 10:12 AM
Do you have another HC to eliminate that from the boot up problem?
Escher
Reged: 08/30/07
Loc: Fenton, MI
Re: CPC1100 complete overhaul new [Re: Geo.]
      #5683543 - 02/16/13 01:40 PM
Unfortunately, no.... But I have re-flashed the firmware several times and it always completes and can be verified... The handset shows hex characters (I think its hex) while the update is being performed... I think its okay...
But - that will be my next course of action if the motor control board doesn't fix the issue.
Escher
Reged: 08/30/07
Loc: Fenton, MI
      #5686543 - 02/18/13 07:58 AM
I know you guys want more pics - just havent had time... but heres my progress over the weekend:
- Removed main gears on both axes and degreased
- Removed fork assembly from base to expose the bearing balls in base
- cleaned up locking nut on fork base (this thing is an ugly mess)
Just FYI for people looking to do the bearing mod to their base... The large locking nut that you have to remove is a BEAR!!! They used some kindof industrial locktite on it and it took a LOT of force to loosen.. Have a vacuum ready after you get it off since so much of the locking compound will flake off, you dont want to get it into the bearing on the center shaft...
I pulled all the nylon ball bearings out and cleaned up both sides of the channel - I also ordered 200 new chrome 1/4" ball bearings - pretty cheap on the 'bay ($12.00 shipped for two bags of 100).
Ohh and a side note - I was incorrect on the statement "there are no other logoc boards other than the GPS interface and the motor controller"...
It appears that the "PC&AG" board has two small IC's and a voltage regulator on it... at least thats what a quick examination looks like... That board is $23.... Had I known (read: paid more attention).. I would have just ordered it at the same time just in case...
So - No more updates until the bearing balls arrive (although I will try and get some more pics posted)... talk to you in a couple of days...
Escher
Reged: 08/30/07
Loc: Fenton, MI
      #5694121 - 02/22/13 07:39 AM
Well this is quite the adventure..
Bearing balls and Motor board arrived last night.
I wont keep you in suspense... Its still not working. Same issue. Now it has to be the handset, which I had doubted... but by process of elimination there really isnt much else it could be.
I will probably order the small power board as well since that is only $25 dollars and I really want to just have all the parts available in case its *not* the handset.
So - I ordered a nexstar+ handset from Adorama last night (Alt-AZ model) and it should be here by Tuesday.
But - On with the show - I still had work to do!
Taking the base clutch assembly off:
Cpc repair 2 by Christopher Purdy, on Flickr
And the same for the Arm:
Gears removed and degreased:
Removing the Lock nut on the base - lots of nasty threadlock here... this is a pain!
Old nylon bearing balls:
New Chrome bearing balls and Extreme Pressure moly grease:
New motor control board (now I have a backup!)
Testing...
I learned a few new things in the process:
1) You can remove the base and all cables (except the single cable that runs between the two boards in the base) and test wihtout the CPC connected... You can also flash the handset this way.
In theory - I should have gotten "No response..." messages, but once again, never got past the "initializing..." screen.
Another thing I noticed:
2) You can re-assemble the axis locks without putting the skins and such back together... you also dont need to tighten the grub screws on the lock handles - those are just there so you can't take the handles off, but they still function perfectly without using the grub screws.. So you can position the tube with it in a disassembled state as seen in the last pic.
Movement is much smoother due to the new bearings... More updates once the handset arrives!!
Escher
Reged: 08/30/07
Loc: Fenton, MI
      #5700583 - 02/25/13 09:13 PM
... and thats got it!!
Hand control it is - and a nice upgrade to boot! THe new handset is much nicer!
I made a video of the scope showing the major parts and where everything is located as well as discussion of the mods I did and costs associated with repairs. I thought it would be easier than a bunch of pics.
Video is located here
http://youtu.be/ZxAN4t1PzKo
Edited by Escher (02/26/13 12:08 AM)
herrointment
Reged: 03/12/11
Loc: North of Hwy. 64
      #5700808 - 02/25/13 11:39 PM
Getting a 404 on the vid but thanks for the photos and update!
Escher
Reged: 08/30/07
Loc: Fenton, MI
Re: CPC1100 complete overhaul new [Re: herrointment]
      #5700834 - 02/26/13 12:09 AM
Fixed... I has a trailing colon in the link...
herrointment
Reged: 03/12/11
      #5700889 - 02/26/13 01:17 AM
Thanks Chris....very helpful vid you did!
Escher
Reged: 08/30/07
Loc: Fenton, MI
      #5830478 - 04/29/13 03:12 PM
hmmm... link no longer working...
Fixed here:
http://www.youtube.com/watch?v=ZxAN4t1PzKo
3 registered and 14 anonymous users are browsing this forum.
