yock1960
Reged: 06/22/08
Loc: Ohio, USA
Jupiter, Io, Europa & shadow ; 2-15-13 new
      #5682518 - 02/15/13 10:50 PM Attachment (99 downloads)
This makes the first time that I've managed to get moon(s) and not some blob! I've got a couple of these...not enough for a decent animation...but I may try anyway.
Steve
Edited by yock1960 (02/15/13 10:51 PM)
Timthelder
Reged: 06/12/12
Loc: Bowling Green KY
Re: Jupiter, Io, Europa & shadow ; 2-15-13 new [Re: yock1960]
      #5682527 - 02/15/13 10:56 PM
Nice shotSteve!
Cheers
yock1960
Reged: 06/22/08
Loc: Ohio, USA
Re: Jupiter, Io, Europa & shadow ; 2-15-13 new [Re: Timthelder]
      #5682549 - 02/15/13 11:08 PM
Thanks Tim!
Steve
wenjha
Vendor
Reged: 09/24/08
Loc: SuZhou China
      #5682894 - 02/16/13 07:19 AM
nice!what's your setting
yock1960
Reged: 06/22/08
Loc: Ohio, USA
Re: Jupiter, Io, Europa & shadow ; 2-15-13 new [Re: wenjha]
      #5682917 - 02/16/13 08:01 AM
Thanks Sam!
Here are the settings:
FireCapture v2.2 beta (Build: #37) Settings
Observer=Steven
Location=Ohio
Scope=Celestron C8
Camera=ASI120MC Camera (ZWO Design)
Filter=L
Profile=Jupiter
Diameter=40.80"
Magnitude=-2.40
CMI=197.7° CMII=311.4° CMIII=31.0°
Filename=Jup_021613_015454.avi
Date=021613
Start=015454
Mid=015554
End=015654
Duration=120s
Frames captured=4865
Binning=no
ROI=512x400
FPS=40
Shutter=25.28ms
Brightness=0
Gamma=50
Gain=62
Histogramm(min)=0
Histogramm(max)=177
Histogramm=69%
Noise(avg.deviation)=0.00
AutoAlign=false
PreFilter=none
Limit=120 Seconds
Steve
ToxMan
Reged: 01/23/11
Loc: Tucson, Arizona, USA
      #5683027 - 02/16/13 09:23 AM
Very nice, Steve.
yock1960
Reged: 06/22/08
Loc: Ohio, USA
Re: Jupiter, Io, Europa & shadow ; 2-15-13 new [Re: ToxMan]
      #5683077 - 02/16/13 09:47 AM Attachment (23 downloads)
Thanks Paul!
I wish I had been a bit more on the ball and had thought about doing an animation, but I only have four frames and one is a bit out of step.
Steve
Timthelder
Reged: 06/12/12
      #5683313 - 02/16/13 11:41 AM
Gottem coming and going...Very nice animation. (is that a reverse rotation?)
Tim
yock1960
Reged: 06/22/08
Loc: Ohio, USA
      #5683563 - 02/16/13 01:49 PM
Thanks Tim!
Timewise it's correct, but I didn't change orientation. This is straight from the videos, no flipping or rotating.
Steve
shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
      #5683684 - 02/16/13 02:52 PM
That's really nice, what software did you use to make the animation?
sfugardi
Reged: 09/30/06
Loc: CT
Re: Jupiter, Io, Europa & shadow ; 2-15-13 new [Re: shawnhar]
      #5683787 - 02/16/13 04:00 PM
Steve, awesome image and animation! Details are well resolved. Thanks for posting
Steve
ToxMan
Reged: 01/23/11
Re: Jupiter, Io, Europa & shadow ; 2-15-13 new [Re: sfugardi]
      #5684356 - 02/16/13 10:24 PM
I think we have all been there, Steve. When you miss these opportunities, you adapt your capture routine to be ready. The first time I missed a double transit in good seeing, I started looking ahead for those opportunities. And, unless something is haywire with the equipment, you can capture at a regular interval to make a nice animation (if you get a 3 or 4 hour run of data in your session.) Shooting monochrome, sometimes all I got was a few nice IR images and a decent animation in IR. While the R might be ok, the G & B would be garbage. No decent color image.
I think you did a marvelous job on the animation. I can see why you wish you had more data. Thanks for sharing.
Paul
Tassydevil
Reged: 08/17/11
Loc: Tasmania, Australia
      #5684442 - 02/16/13 11:37 PM
Very nice.
yock1960
Reged: 06/22/08
Loc: Ohio, USA
      #5685235 - 02/17/13 01:31 PM
Thanks all!
Shawn, I used CS2 to make the animated GIF.
Steve
Kecktastic
Reged: 01/16/10
Loc: Broken Hill NSW Australia
Re: Jupiter, Io, Europa & shadow ; 2-15-13 [Re: yock1960]
      #5685886 - 02/17/13 08:21 PM
Well done Steve, nice level of detail in the images and excellent animation.
Regards
Trevor
DynamicUniverse
Reged: 07/14/12
Loc: southeast US
Re: Jupiter, Io, Europa & shadow ; 2-15-13 new [Re: Kecktastic]
      #5687719 - 02/18/13 08:20 PM
How long of a time span is this? If you can pull this off, try a three hour series capture with two minute intervals in between. Windows Movie Maker and VirtualDub are good tools for stringing the processed images together into an AVI.
Great capture BTW.
Chris
11 registered and 11 anonymous users are browsing this forum.
Moderator:  Boot, bilgebay
