star chaser
Reged: 02/10/13
Primary focus new
      #5686124 - 02/17/13 10:45 PM
My 10" 1200mm f/4.7 Dob primary focus is flush with the optical tube so I am unable to attach my camera to the focus tube for primary photography.How far back will a barlow or coma corrector bring my primary focal plane so I can start using the telescope for primary photography?
Jeff2011
Reged: 01/01/13
Loc: Sugar Land, TX
Re: Primary focus new [Re: star chaser]
      #5686150 - 02/17/13 11:02 PM
That is a common problem with Dobs. Using a Barlow is a form of eyepiece projection. Just about any Barlow will work, but it shrinks the FOV considerably. With barlows you don't have to worry too much about a specific length behind the Barlow, however the further back the greater the magnification. That is not true with coma correctors as you need to get the correct distance as specified by the manufacturer. I was able to achieve true prime focus or more correctly Newtonian focus by moving my primary mirror up about 1.5 inches. This was done by simply replacing the collimation bolts. I replaced the 1in bolts with 2 in. After doing this I had to get a tube extender to use my eyepieces and had to do a serious collimation.
Edited by Jeff2011 (02/17/13 11:05 PM)
star chaser
Reged: 02/10/13
Re: Primary focus [Re: Jeff2011]
      #5686160 - 02/17/13 11:07 PM
thanks. I am trying to avoid changing the position of my primary mirror but maybe that is the best option.
Jeff2011
Reged: 01/01/13
Loc: Sugar Land, TX
      #5686292 - 02/18/13 12:38 AM
You can also try replacing the focuser with a low profile. I think the combination of a low profile focuser and coma corrector might get it for you. Moving the mirror is less expensive however.
star chaser
Reged: 02/10/13
Re: Primary focus new [Re: Jeff2011]
      #5686707 - 02/18/13 09:59 AM
Thanks again I will start doing my home work.
4 registered and 10 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, fishonkevin, WOBentley, rflinn68
