Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Pushing the Limits
#5689066 - 02/19/13 03:12 PM
Every now and then, but not all the time, I like to see just how deep my 12.5" can see. Over the years, I've run into many challenges, but the following are some I've pursued this year. Only #13 has eluded me this last year. I've seen to H1, but not H2 or I. Yet.
If you have some of your own, post them here and we'll see just where this thread goes.
Some challenges for the 12.5", with some a LOT easier than others:
1) The horizontal branch of M14--seeing hundreds of stars across the cluster. HB=mag.17.1 2) Seeing individual stars in NGC206 in M31. There are 6 superimposed stars in the Milky Way. If you see a dozen or more, you're picking up stars in M31. Mags 17.03-17.55 3) Seeing the spiral arms in M81 4) Seeing the spiral arms in NGC2403 5) Seeing the spiral arms in NGC7331 6) Seeing white swirls inside the Great Red Spot on Jupiter 7) Seeing albedo markings on Ganymede 8) Seeing shadows of the festoons on the edge of an EQ Band on Jupiter 9) Seeing 6 distinct galaxies in Hickson 92, aka "Stephan's Qunitet" 10) Seeing IC4617 on the outskirts of M13 11) Seeing IC1296 on the outskirts of M57 12) Seeing the central star in M57 13) Seeing the G-H1-H2, and I stars in the Trapezium 14) Seeing the jet in M87 15) Seeing the "fingers" protruding from NGC5195 (companion of M51)
My hope is to add to this list to provide some year-round challenges for 10-12"+ apertures.
deepskydarrell
Reged: 03/09/08
Loc: Abbotsford, BC Canada
Re: Pushing the Limits
[Re: Starman1]
#5690090 - 02/20/13 01:12 AM
Thanks Don, for the start of a fantastic Challenge List. I've only had my refigured mirror since September and the weather up here has been dismal as usual, but these are the types of things I'd like to test on. After 10 years of pushing the envelope with my old optics I'm pretty much overwhelmed by all the sights that I want to revisit with my new eyes.
Would the Draco Dwarf meet the criteria?
Darrell.
hbanich
Reged: 06/17/05
Loc: Portland, Oregon
[Re: deepskydarrell]
#5690138 - 02/20/13 02:41 AM
A few challenge objects off the top of my head and in no particular order. All with my 28 inch f/4 Newtonian unless otherwise noted:
1. Einstein's Cross. So far I've seen three of the lensed images and the lensing galaxy. 2. Hickson 50. My best so far is three Hickson 50 galaxies. 3. Stars with NGC 604. 4. The second central star within M57. 5. Knots within M87's jet. 6. IC 4277 near M51. This is a bugger! 7. The southern arc in Cassiopeia A. No luck yet, but the northern arc is really cool. 8. Abell 85. No luck yet. 9. HH 399 in the Trifid Nebula. No luck yet. 10. A small but photographically bright HII region at the end of M51's bridge. No luck yet.
Starman1
Reged: 06/24/03
Loc: Los Angeles
#5690545 - 02/20/13 10:10 AM
Darrell.
At almost the same size as M33 and 5 magnitudes fainter overall, the SB of this galaxy is going to be quite low. It would be interesting to see what scopes can see it.
JakeSaloranta
Reged: 09/18/08
Loc: Sisu Sauna Sibelius
#5690654 - 02/20/13 11:20 AM
I think UGC 10822 is going to be faint no matter the aperture. It can be seen with giant binoculars, small refractors and anything above that.
/Jake
Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
[Re: JakeSaloranta]
#5690701 - 02/20/13 11:43 AM
IF there's no light pollution, no Moon and the atmosphere has been purged of any haze by a hurricane or something like that, AND you're at 10,000 feet altitude...
But yes, I've heard of visual sightings. I've yet to see anything but stars in the region. The UMi dwarf is no better. They do have the advantage of passing right overhead here.
Clear skies! Thomas, Denmark
LivingNDixie
TSP Chowhound
Reged: 04/23/03
Loc: Trussville, AL
[Re: Astrojensen]
#5690779 - 02/20/13 12:28 PM
Thomas, Not to nitpick but hurricanes actually don't purge the atmosphere of moisture after they pass. Been through a couple of hurricanes
But you are right dry skies with low humidity is good though
nytecam
Reged: 08/20/05
Loc: London UK
[Re: hbanich]
#5690838 - 02/20/13 12:55 PM Attachment (13 downloads)
Wow Howard - what an impossible list but obvious worthy for 28" Dob
Just dug out my M51 brief shot from last April with edge-on gxy IC4277 @ m17.95 [circled] and unidentified brighter m17.3 gxy [square box], according to Sloan DSS, in immediate field. Good luck in your quest
leviathan
Reged: 11/29/11
Loc: Azerbaijan
[Re: nytecam]
#5690859 - 02/20/13 01:07 PM
6, 7, 8, 12, 13 should be easy for 12". But 17-17.5m for that scope I think is impossible.
JakeSaloranta
Reged: 09/18/08
[Re: Astrojensen]
#5690874 - 02/20/13 01:15 PM
I was hoping the light pollution part would come without saying but the others are so-so. I've seen both the Draco and Ursa Minor Dwarfs with a 4.3" Tal-1 refractor from Nokia, Finland less than 20 kilometers from the 3rd largest city in Finland - Tampere. No altitude and "plenty" of light pollution in the worst parts of the sky but still dark, SQM-L 21.30+ and NELM 7.0+ skies.
I also personally know that both of the dwarfs have been seen with even smaller apertures. These include observations at least by Jyri Lehtinen (with a 10 cm scope from NOT, La Palma, NELM ~8.0) and Steve Waldee from CA with a 8 cm scope. I also remember some guy from France(?) that saw them with a pair of giant binoculars. There's surely a thread of it here on CN / Google.
The fact that the objects rise ~70 deg above the horizon surely helps up here in the north.
/Jake
Astrojensen
Reged: 10/05/08
[Re: JakeSaloranta]
#5690971 - 02/20/13 02:02 PM
The amount of moisture in the atmosphere above is sure going to be a huge factor in the visibility of these very difficult galaxies. I've got dark skies (SQM 21.7 is just ten minutes in car from my house), but my skies are often gray with haze.
JakeSaloranta
Reged: 09/18/08
[Re: Astrojensen]
#5691027 - 02/20/13 02:36 PM
Jeez, so fine you have to have "dark skies and relatively low humidity" to see it. Keep in mind that low humidity never occurs in here. My observation and sketch were made in April and the weather notes do not mention snow cover so with the breeze... humidity probably was as close to "low" (40-50%) as it ever can get in here.
The point was, that Draco Dwarf can be seen from less than pristine locations as well and even with smaller apertures.
/Jake
Astrojensen
Reged: 10/05/08
[Re: JakeSaloranta]
#5691185 - 02/20/13 03:47 PM
I think haze might not always be associated with humid conditions near the ground (but probably most often is). I think your location might possibly have a lot lower moisture content in the upper atmosphere than here. I have, as mentioned, quite dark skies, but I've never seen the UMi or Draco dwarfs, even when looking for them with quite suitable gear, but perhaps I've not tried hard enough.
Do you have an idea of how much more difficult they are, compared to Coddington's Nebula, IC 2574? I've seen that one as a ghostly glow with one or two clumps in a 6" f/8 achromat at 40x, with a 30mm ES82 eyepiece. The clumps were easier with an 18mm ES82, 67x.
I've only had the ES eyepieces for a month and a half, but the 30mm on the 6" refractor is going to be my scope of choice on the next assault on the Draco and UMi dwarfs.
That you consider the Draco dwarf possible under less than ideal skies is a great encouragement for me!
J Lowrey
Reged: 01/22/11
Loc: Fort Davis Texas
[Re: nytecam]
#5691196 - 02/20/13 03:52 PM
Howard,
Could you be more specific on where the knot in M51 is that you are talking about in your post.
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
[Re: Starman1]
#5691213 - 02/20/13 04:00 PM
Darrell.
If you mean 10th magnitude UGC 10822, that has been seen in some rather modest apertures (six inches for example). I even caught it one night at the Nebraska Star Party in my 9.25 inch SCT, which surprised me a bit. Clear skies to you.
David Knisely
Reged: 04/19/04
[Re: Starman1]
#5691265 - 02/20/13 04:27 PM
Well, let's see...
Humm... I see many stars in M14 in my 10 inch, but they are probably AGB stars mostly.
It looks granular in my 14 inch and there are a few stars there, but which are M31 stars and which are not I don't know about.
Been there. Done that (in an 8 inch f/7 no less).
Lots of patchy detail in it in my 10 inch, but full arm structure is elusive.
Done that (in a 10 inch this time).
I don't know about "white swirls", but under good seeing, the interior of the red spot starts to show some arc-like inner detail in my 10 inch. In my 14 inch, the interior structure is unmistakable, although it isn't quite "white".
I have seen the "dot" in my 9.25 inch SCT, but much more required my 14 inch Newtonian.
You're kidding, right?
Well, four with the 9.25 inch and five with my 14 inch (don't know which is the 6th galaxy unless you want to count the more distant NGC 7320C over four arc minutes to the northeast of NGC 7320).
That one took a 12.5 inch Portaball at the Nebraska Star Party to do, as I failed using my 10 inch. In my 14 inch Newtonian, it was no problem last summer.
I have done that with my 10 inch Newtonian, although I don't know about it being on the "outskirts" of the nebula.
Did that one night from my driveway in my 9.25 inch SCT.
Nope, not yet, but quite frankly, I haven't had a lot of interest in seeing them.
Tried with my 14 inch but failed due to seeing. I will keep trying.
The "prongs" as I like to call them were not all that hard in my 10 inch one exceptionally dark night, but it does take a really good night to do it. I have had some halfway decent nights where they failed to show up well even in my 14 inch, other than as faint hints of something trailing off to the north of NGC 5195.
Keep those challenges coming! Clear skies to you.
Astrojensen
Reged: 10/05/08
[Re: David Knisely]
#5691293 - 02/20/13 04:40 PM
That's quite an impressive list of achievements!
tnakazon
Reged: 06/26/10
Loc: Los Angeles
[Re: Starman1]
#5691420 - 02/20/13 05:50 PM
With my 3.9" Orion SkyScanner F/4 Newtonian, three difficult objects I've been able to pick-up with it were:
1) NGC 6822 or Barnard's Galaxy in Sagittarius (visual mag.=9.9, surface brightness=15.5)
2) NGC 4236 in Draco (visual mag.=9.9, surface brightness=15.2)
3) NGC 4145 in Canes Venatici (visual mag.=11.2, surface brightness=14.6)
All of these were observed under dark skies (green/blue zone).
Barnard's is probably visible with scopes of even smaller aperture, just as long as you have dark skies.
Starman1
Reged: 06/24/03
Loc: Los Angeles
[Re: leviathan]
#5691433 - 02/20/13 06:00 PM
Well, not really. It depends on whether we are talking stars or DSOs. With my 12.5", I've seen stars of magnitude 17.35, at the zenith, at high power, and under near-optimum conditions (mag.21.7 skies with near-perfect seeing). Mag. 16.8 is visible nearly every time I observe--sometimes more than 80% of the time. Try downloading the magnitude chart around M57 for some really faint magnitudes: http://www.astrochris.net/page.php?pg=20
As for DSOs, I have a few observations logged that reach past magnitude 16, notably: NGC4297 NGC6027C (In Seyfert's Sextet) PK110-12.1 planetary NGC3005
One of my favorite challenges, though not quite as dim, is the galaxy at the edge of Abell 70. Both galaxy and planetary visible without filter. An O-III makes the planetary stand out, but reduces the galaxy to merely a bright spot on the periphery of the nebula.
Astrojensen
Reged: 10/05/08
[Re: tnakazon]
#5691470 - 02/20/13 06:20 PM
I've not seen NGC 6822 or 4145, but I've seen NGC 4236 a couple of times or three, with my 63mm Zeiss. Usually it's extremely hard and only visible as a very faint, slightly elongated glow (the bulge), but one time I saw it as a huge, very elongated object, one of the biggest near edge-on galaxies I've seen. Truly a fascinating object. That night I saw many, many objects like I've never seen them before or since. The sky was coming alive with galaxies and stuff.
