elbert
Reged: 03/21/11
Loc: Limburg, Netherlands
Sky watcher NEQ6 GT AZ polar scope led brightness new
      #5679592 - 02/14/13 02:16 PM
Overall I'm very pleased with my new mount. It's very stable Goto and autoguiding Work wel, periodic error seems small. There is ons problem: the led in the polar scope is way too bright. According to the synscan manual there should be an option 'polar scope led' in the utility functie. Menu. When I look for this it simply isn't there (I'm using firmware version 3.31). Anyone have a similar experience / solution?
Renards, Elbert
hectar
Reged: 12/24/12
Loc: Ontario, Canada
Re: Sky watcher NEQ6 GT AZ polar scope led brightness new [Re: elbert]
      #5689929 - 02/19/13 11:04 PM
Did you try yahoo's EQMOD and EQ6 groups?. Apparently it could be done with older firmware (3.24?) or with some small patch to synscan..
rigel123
Reged: 06/29/09
Loc: SW Ohio
Re: Sky watcher NEQ6 GT AZ polar scope led brightness [Re: elbert]
      #5691860 - 02/20/13 10:20 PM
Check the Setup menu rather than Utilities. See if there is a choice for Handset Settings. There you should find the choice for dimming the PA Scope LED
24 registered and 47 anonymous users are browsing this forum.
