drksky
Reged: 09/01/09
Loc: Bloomington, IL
CGEM - Play in the RA Axis
      #5694542 - 02/22/13 11:53 AM
I recently purchased a used, hyper-tuned CGEM that while tracks well and is very smooth, has a lot of play in the RA axis. What can I do to eliminate this play? Does the worm need adjusted? Any guides for doing that on a CGEM?
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: CGEM - Play in the RA Axis new [Re: drksky]
      #5694580 - 02/22/13 12:14 PM
...What can I do to eliminate this play? Does the worm need adjusted? Any guides for doing that on a CGEM?
Here you go - worm/wormgear adjustments. These instructions are specifically for an Atlas/EQ6, but the method for the CGEM is identical.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: CGEM - Play in the RA Axis new [Re: DaveJ]
      #5694992 - 02/22/13 03:34 PM
Tony, go to the CGEM yahoo group. There is specific instructions on adjusting the CGEM worm on there. It is similar, but I like seeing the CGEM info .
I can't remember how much play my CGEM had... did you try just balancing it heavy to the meridian you're imaging in?
drksky
Reged: 09/01/09
Re: CGEM - Play in the RA Axis new [Re: Raginar]
      #5695040 - 02/22/13 03:54 PM
I wasn't really doing any imaging. I had my LS80 on it and the image was jumping out of the FOV while I was trying to adjust the tuning. I can grab the CW shaft and wiggle it more than I think I should.
John O'Grady
Reged: 11/15/09
Loc: Waterloo, ON CAN
      #5695737 - 02/22/13 10:04 PM
I had similar play in the RA on my CGEM that I resolved by adjusting the worm gear. Mount has performed much better since making the adjustment.
Fortunately your mounts already been hypertuned. For those reading this that have a CGEM and want to adjust the worm gear, read this warning caution from Ed Thomas (happened to me):
http://tech.groups.yahoo.com/group/CelestronCGEM/message/7756
Unfortunately I found Ed's post after performing the worm gear adjustment. Live and learn.
22 registered and 37 anonymous users are browsing this forum.
