PGW Steve
Reged: 10/03/06
Loc: Winnipeg, Canada
Smart EQ Pro......heavily modified!!!
#5693836 - 02/22/13 12:19 AM Attachment (59 downloads)
I have been playing around with various travel ready rigs suitable for wide field and telephoto photography with DSLR for a while. I started with an original Astrotrac, changed up to a new version with autoguiding and the whole travel pier, wedge and EQ head. I have a Vixen Polarie with PAS and owned a Sightron Nano, but it was DOA and I never got to see what it could do.
I purchased a Smart EQ Pro, and found the tripod to be greatly lacking. I own a machine shop, and make a lot of my own stuff, I looked at the tripod with improvement in mind. That quickly changed when I realized I would be making all new parts to fix the deficiencies. I then came up with the idea of making an adaptor to fit it onto a Manfrotto tripod with already great stability.
PGW Steve
Reged: 10/03/06
Re: Smart EQ Pro......heavily modified!!!
[Re: PGW Steve]
#5693839 - 02/22/13 12:20 AM Attachment (43 downloads)
I did some testing with this and determined that the block that attaches to the declination shaft with two set screws, did not satisfy my OCD.
PGW Steve
Reged: 10/03/06
[Re: PGW Steve]
#5693841 - 02/22/13 12:22 AM Attachment (33 downloads)
I then started to add a modular system for attaching various telephoto/DSLR combos that will have widely ranging balance points.
PGW Steve
Reged: 10/03/06
[Re: PGW Steve]
#5693843 - 02/22/13 12:24 AM Attachment (33 downloads)
A long time ago, I made some mini 60 degree dovetail plates for all of my telephoto lenses and camera bodies, thus I made little clamps as well to fit on my ball heads.
Since this is intended to be autoguided with the tiny SBIG STi Autoguiding kit, I made a custom mounting for this as well.
PGW Steve
Reged: 10/03/06
[Re: PGW Steve]
#5693845 - 02/22/13 12:26 AM Attachment (47 downloads)
This is what the whole rig looks like with a 400mm f5.6 Canon lens, and a 5DII.
PGW Steve
Reged: 10/03/06
[Re: PGW Steve]
#5693847 - 02/22/13 12:27 AM Attachment (35 downloads)
Here are all of the pieces laying next to each other.
PGW Steve
Reged: 10/03/06
[Re: PGW Steve]
#5693855 - 02/22/13 12:33 AM
I've had this assembly out under the stars for one evening at -20C, the mount worked fine for about 2 hours till the cold made it freak out. The autoguiding worked 'okay'......I have to figure out the settings for PHD using a 100mm focal length lens. By okay, I mean the mount guided for about an 80% success rate on 5 minute exposures at 400mm FL. I had some weirdness calibrating which I attribute to me not having the settings at optimum. I'm sure once I get these settings nailed, this mount will work great for its intended role.
Astronewb
Reged: 09/19/11
Loc: Connecticut
[Re: PGW Steve]
#5694401 - 02/22/13 10:31 AM
Excellent machine work Steve, nothing like a nice pile of alloy chips on the floor. I like your over-under solution for the autoguider, very nice.
Looking forward to seeing how it works for you under the stars...
Thanks for sharing
Paui
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
[Re: Astronewb]
#5694433 - 02/22/13 10:54 AM
Steve,
That's beautiful. Thanks for sharing!
CounterWeight
Reged: 10/05/08
Loc: Cloudyopolis, OR.
[Re: Raginar]
#5694532 - 02/22/13 11:50 AM
Agree - very nice work!
PGW Steve
Reged: 10/03/06
[Re: CounterWeight]
#5696937 - 02/23/13 04:31 PM
Thank you Gents!! I've got some feedback on the SBIG Yahoo Group and I'm going to try the new settings when the weather cooperates.
s800
Reged: 03/19/08
Loc: Wisconsin
[Re: PGW Steve]
#5697632 - 02/24/13 12:18 AM
Well done!
