Privacy Policy |
Please read our Terms
of Service | Signup and
amdizack
Reged: 08/23/12
Loc: Goodyear, AZ
How do I piggy back a DSLR onto my Edge?
#5698289 - 02/24/13 01:40 PM
Should be an easy one and I just need clarification or someone to point me towards the correct adapter/mount/clamp.
I have an CGEM C8 Edge and have two items mounted on the OTA already: 1, a dovetail on top that holds my guidescope setup, and 2, the standard finderscope that comes with the Edge. Is there an additional adapter that I can mount somewhere on the OTA that screws into the bottom of my DSLR without removing either the guidescope or finderscopes?
KD58
Reged: 11/23/12
Loc: West Texas
Re: How do I piggy back a DSLR onto my Edge?
[Re: amdizack]
#5698496 - 02/24/13 04:02 PM Attachment (6 downloads)
I can't tell you what to do on the Edge but I've come up with a solution for my refractor. I have mounted a side by side adaptor on to the dovetail on top of the scope. Then mount the guidescope on one and the DSLR on the other. I have had to rotate the OTA a little bit to allow a clear view for the finderscope, Here is a photo:
KD58
Reged: 11/23/12
Loc: West Texas
[Re: KD58]
#5698505 - 02/24/13 04:06 PM
ADM carries all the adaptors you would need for such a setup. I have a 4" Vixen style dovetail bar attached to the guidescope that goes into one of the clamps and the camera adaptor on the other side.
fishonkevin
Reged: 04/29/07
Loc: Michigan
[Re: KD58]
#5698580 - 02/24/13 04:50 PM
When doing piggy-back, remove the guidescope and mount your camera to the top rail. You can use the Edge to guide with.
amdizack
Reged: 08/23/12
Loc: Goodyear, AZ
[Re: fishonkevin]
#5698726 - 02/24/13 06:10 PM
OMG! DUH!!! Thanks! (see? I told you I was overthinking this)
fishonkevin
Reged: 04/29/07
Loc: Michigan
[Re: amdizack]
#5698727 - 02/24/13 06:12 PM
KD58
Reged: 11/23/12
Loc: West Texas
[Re: fishonkevin]
#5699002 - 02/24/13 10:05 PM
My setup allows me to shoot through the main OTA and also the DSLR with a lens attached. I can also image a different section of the sky with the DSLR.
9 registered and 19 anonymous users are browsing this forum.
Moderator: Undermidnight, fishonkevin
