Alfredo Beltran
Reged: 08/01/10
Loc: Bogota, Colombia
iEQ45 PE reduced to 4.5 arcsec peak to peak!!
#5699059 - 02/24/13 10:45 PM
Hi everyone
After looking at other users results in which the PE of iEQ45 mounts has been taken to +/-2 arcsec, I decided to try with mine. Those results have been published in the iEQ45 imaging yahoo group.
My mount is an iEQ45 of the first batches with 8406 hand control. I used a trial version of Pempro to measure the Periodic Error (PE) of the mount and found it was 14.38 arc-secs: http://flic.kr/p/dXEmxd . Better than expected.
Data was aquired through a Celestron C6 SCT with an Orion StarShoot Autoguider and a Celestron f6.3 focal reducer. Pixel Scale was 0.95" per pixel, which implies the telescope was at f7.5 (1130 mm).
After training the Periodic Error Correction (PEC) on the mount, I got a peak to peak PE of just 4.59 arc-secs: http://flic.kr/p/dXyEEX
This is a very satisfying result which speaks very well about this mount! Best regards
Alfredo
lambermo
Reged: 07/16/07
Loc: .nl
Re: iEQ45 PE reduced to 4.5 arcsec peak to peak!!
[Re: Alfredo Beltran]
#5699262 - 02/25/13 02:56 AM
Thanks for posting this info, I've added it to my mounts list .
-- Hans
Alfredo Beltran
Reged: 08/01/10
[Re: lambermo]
#5699381 - 02/25/13 07:52 AM
Hi Hans
These results show than in fact the iEQ45 performs very well when compared to other mounts in its class.
I must clarify that in no way I'm related to iOptron. I'm just a satisfied costumer.
You have very valuable information in that list. A good guide about mounts performance.
Best regards
Alfredo
timmbottoni
Reged: 08/25/05
Loc: W Chicago suburbs, IL USA
#5699545 - 02/25/13 10:04 AM
I'm becoming more and more interested in this mount, since I'm looking at getting started in Astrophotography. I think I will also join the Yahoo group mentioned.
Timm
zjc26138
Loved By All
Reged: 02/24/05
Loc: Mingo Junction, Ohio
[Re: timmbottoni]
#5700104 - 02/25/13 03:47 PM
Thanks for posting the info.
I think I'm going to run PemPro tonight on my mount. Quick question though. In the setup for the mount it asks you how many teeth are in the worm gear. I found the number 216 on iOptron's website for mount specs. Is this the correct number of teeth?
Alfredo Beltran
Reged: 08/01/10
[Re: zjc26138]
#5700274 - 02/25/13 05:25 PM
Yes, that's the correct number of teeth
Best regards
Alfredo
zjc26138
Loved By All
Reged: 02/24/05
#5700299 - 02/25/13 05:45 PM
Best regards
Alfredo
Alfredo, Thanks for the info!
Alfredo Beltran
Reged: 08/01/10
[Re: zjc26138]
#5700356 - 02/25/13 06:22 PM
You're welcome.
Keep us posted about your results.
By the way what's your name?
Best regards
Alfredo
zjc26138
Loved By All
Reged: 02/24/05
#5700382 - 02/25/13 06:38 PM
My name is Zach. Will do, hopefully I can get some results tonight
Astronewb
Reged: 09/19/11
Loc: Connecticut
[Re: zjc26138]
#5700747 - 02/25/13 11:00 PM
It might be helpful at this point to mention that PEC will not work with the iEQ45 with the 8407 handcontroller when autoguiding. The mount will turn off PEC by default in that situation.
You may still be able to do it by using Ascom thru the RS232 port to guide instead of the ST4 port?
Paul
zjc26138
Loved By All
Reged: 02/24/05
[Re: Astronewb]
#5700765 - 02/25/13 11:13 PM
I couldn't get PEMpro to work. I have the older controller. I was using my guide camera to try to get it work, an Orion SSAG.Which is plugged into the the ST4 port and then USB'd into my computer. It was not recognizing the mount. Should I have had the RS232 cable plugged from the mount into the computer as well or is that guide scope setup enough? Also what other software do I need for PEMpro to work? Thanks!
Edited by zjc26138 (02/25/13 11:14 PM)
Alfredo Beltran
Reged: 08/01/10
[Re: Astronewb]
#5701084 - 02/26/13 07:23 AM
Hi Paul
Since I own the 8406 HC and not the 8407, I couldn't tell. Nevertheless that has been said in the iEQ45 imaging Yahoo User Group and yes, you can guide through the serial port with PEC on.
I think with 8406 you can guide with PEC on through the standard ST4 port. I can check that next time I am under the stars
Best regards
Alfredo
Alfredo Beltran
Reged: 08/01/10
[Re: zjc26138]
#5701106 - 02/26/13 07:40 AM
Hi Zach
I also have the "older" 8406 controller and this seems to be an advantage because it would let you guide through ST4 port with PEC on.
To make Pempro work, you need to use the SSAG as your main camera in Maxim (check Pempro's help because I think other software also will work). Then you run the tutorials to configure everything. I may be wrong, but you can't connect the SSAG to the ST4 port for this process.
There are some settings you need to configure. See here
Best regards
Alfredo
zjc26138
Loved By All
Reged: 02/24/05
#5701171 - 02/26/13 08:43 AM
Alfredo, Thanks for the help again. I'll try it today and see if I can PEMPro to work. It's going to be raining/snowing the next few days so I went be able to test under the skies until then.
Thanks, Zach
Astronewb
Reged: 09/19/11
Loc: Connecticut
[Re: zjc26138]
#5701812 - 02/26/13 02:43 PM
Thank you Alfredo,
Just an update for 8407HC users, iOptron has informed me that PEC will indeed work in conjunction with ST4 autoguiding...?
“The autoguiding will work as long as the mount is in tracking. If the PEC is ON, they will work together. The PEC playback period is 0.1 second. If autoguiding period is greater than 0.1 second, the PEC will play the main role.”
I had a little concern about the 'as long as the mount is tracking' statement. Does that mean just visually tracking an object?
And, if the PEC playback is .10 sec..then you would have to have your PHD exposures at .05 seconds, to enable PHD to send guide commands..and that won't work at that short exposure unless you're guide star is Sirius or another very bright star.
So, next opportunity I have with the iEQ45, I'm going to try and record PEC and initiate playback, with, and without guiding enabled, just to see what's going on.
If any other 8407HC users have successfully used PEC in tandem with ST4 port guiding, I'd love to hear about it.
Cheers all,
Paul
Phillip Easton
Reged: 12/24/10
Loc: DFW
[Re: Astronewb]
#5702186 - 02/26/13 06:06 PM
Gratz again Alfredo on the good results!
Paul,
Wow that opens up a lot more questions??!! LOL Good to know the PEC period though. Since it's that short more reason to collect a lot of curves and average them in PEMPro.
Cheers!
Alfredo Beltran
Reged: 08/01/10
[Re: Phillip Easton]
#5703461 - 02/27/13 12:45 PM
Thanks for your comments Phillip.
I'm very happy with my mount, as well as others who have gotten similar results
Best regards
Alfredo
Kendahl
Reged: 02/02/13
#5704381 - 02/27/13 10:09 PM
I have been following comments about the iEQ45 for several weeks on Yahoo's ieq45imaging group and on here.
On paper, the iEQ45 looks very promising. Load capacity is enough for a 9.25" SCT which is the heaviest telescope I will ever want to handle. Price is moderate. Weight, which is my major concern, is substantially less than an Atlas or CGEM. However, I have been discouraged by comments about uncorrectible tracking errors that would make the mount useless at focal lengths greater than a few hundred millimeters. At this point, I can't decide whether to buy an iEQ45 as my permanent imaging mount or to start out with something cheap, like a CG-5, to learn with, and make the big financial jump to the likes of an Astrophysics Mach1 later on.
I would like to propose the following test of an iEQ45's tracking accuracy. Track on and photograph a bright star such as Sirius. Use a long focal length to magnify the results of tracking errors. An SCT with a Barlow instead of a reducer would be a good choice. Make repeated images, as quickly as possible, for at least one full worm period. It may be possible treat the star like a planet and run a DSLR in video mode. Perform the test with all four combinations of PEC on and off and autoguiding on and off. Examine the images and graph the movement of the target star over time.
With autoguiding off, I would expect to see the results Alfredo got superimposed on a steady drift due to residual errors in polar alignment. With autoguiding on, I would expect to see the drift eliminated and hope to see the remaining PE substantially reduced. What are of most interest are tracking errors that autoguiding, with or without PEC, cannot correct. They are what determines the longest focal length at which one can still get good images. I have read comments that a Mach1 has a PE of 0.5 arc-seconds out of the box. This is impressive but irrelevant if one can do as well autoguiding an iEQ45.
Bluejay08
Reged: 09/29/09
[Re: Kendahl]
#5704416 - 02/27/13 10:20 PM
well, Luke Jones had already posted a message to correct his claim of uncorrectable tracking errors at long focal lengths. Here is the link: http://tech.groups.yahoo.com/group/ieq45imaging/message/1904
Hope this clears your concerns.
Jay
timmbottoni
Reged: 08/25/05
[Re: Bluejay08]
#5704471 - 02/27/13 10:49 PM
Thanks for all the info in this post! I'm eagerly following the iEQ45 as a possible AP capable mount for me to start with
Kendahl
Reged: 02/02/13
[Re: Bluejay08]
#5704609 - 02/28/13 12:46 AM
I'm aware of his retraction. It's encouraging but not a complete answer. There are still going to be tracking errors of a certain size. That size determines the longest focal length at which one can still get good images.
As a beginner, I am confused by the extreme range of recommendations I have found on various forums. There are people who are happy with a C8 on a CG-5. On the other hand, when I asked, elsewhere, about a Losmandy GM-8 versus a G11 to carry a C9.25, a couple of responses stated that both the mount and the telescope would be a disappointment and that I would be better off jumping straight to Astrophysics or Takahashi equipment. There seems to be consensus that mount capacity ratings should be discounted by 30% to 50% for astrophotography. Yet a guy in my local club is doing well with a C11 plus camera and piggy back guide scope on a CGEM. The CGEM's 8/3 issue and the C11's mirror shifts don't appear to cause him problems. It has been recommended that I begin at an image scale of no less than 2 arc-seconds/pixel. At that scale, the Ring Nebula occupies only 75 pixels. Rather than start with something small and cheap and upgrade repeatedly until I find a satisfying combination of mount and telescope, I would prefer to do enough research to jump straight to the final one.
Edited by Kendahl (02/28/13 12:53 AM)
Midnight Dan
Reged: 01/23/08
[Re: Kendahl]
#5704796 - 02/28/13 07:06 AM
The reason you find such a range of recommendations is that people have different tolerances for what's good enough. Fact is, there's no "hard" cutoff point where a mount has too much load on it. There's just a range of factors such as load and length of scope, that produce a range of results. It's up to each individual to decide where the cutoff point is. For some, a C8 on a CG-5 produces decent results. For others, the exact same setup won't be nearly good enough and not worth the frustration.
Generally speaking, the smaller the mount, the bigger the load, and the longer the focal length, the worse the results. And, as you've read, a good rule of thumb is that you should load a mount between 50% to 70% to get the best results. But again, some people are perfectly happy with the results even when exceeding those numbers, some times by a lot. And then of course there's the variation in the quality from example to example of the same mount.
So if you're looking for hard answers, you won't find them. Unless you're already in the game and have tried several mounts and know your own tolerance for quality level in your images, all you can do is go by the "rules of thumb".
A C8 will work on a 30 pound capacity mount like a CG-5, VX, Sirius, iEQ30, or HEQ5. But, when you add up the weight of all gear you'll have mounted along with it, it will be much happier on a 40-45 pound capacity mount like an Atlas, iEQ45, or CGEM. A C9.25 is starting to push that 40-45 pound mount class, but will certainly work on it. I think a C11 is too much and should be on the next class up with a 60 pound or more capacity, but again, there are those who will do it and be satisfied with the results.
-Dan
freestar8n
Reged: 10/12/07
[Re: Kendahl]
#5704821 - 02/28/13 07:45 AM
Hi and welcome to cloudy nights.
You have a refreshingly open perspective on the issues of autoguiding and PE, and I agree the information you find on the web can be confusing. For some reason there is a strong emphasis placed on the PE characteristics of a mount - when that is separate from how well the mount can create a small image of a star when autoguiding - which is the whole goal of good autoguiding in the first place.
In short, when you hear advice I would look at the actual results people get with the equipment they have. There are many plots showing a reduction of PE, but it is rare to see information on a corresponding reduction in star size, or fwhm in arc-seconds. There are many people who could not get good results with mid-range equipment and found a dramatic improvement spending for high end - but that doesn't mean they could not have achieved similar results with mid-range using the right techniques and software.
This leads to advice not to bother with mid-range equipment, and discouragement that small stars can ever be obtained - hence a push towards large pixels. There is no doubt that a small refractor and big pixels, in arc-seconds, is easier for imaging - but if you want high resolution in something like the ring nebula - then you will need long focal length and small pixels, in arc-seconds - but the result is achievable as demonstrated by many people, including my images on the MetaGuide site with cge and cge-pro (but not cgem).
There may be more effort and care required with mid-range equipment - but the existence of results at 2" fwhm and below is proof that such results are achievable without a high end mount - and such results benefit from small pixels.
More on topic - I think it's great the OP's PE was reduced, and that may well make the mount more forgiving when guiding - but the number I like to see is the achieved fwhm in arc-seconds in long exposures - which sounds like what you are interested in also, ultimately.
Frank
Alfredo Beltran
Reged: 08/01/10
[Re: Kendahl]
#5704828 - 02/28/13 07:54 AM
Hi Kendhal
For me, my iEQ45 performs very, very well. I agree with Dan: one has to know the performance of several kinds of mounts. Getting down to 4.5 arcseconds is very good. Is it for anyone else? Only each one an answer that.
The weight, cargo capacity, PEC capability and GPS were features that attracted me when I bought mine, but the main feature which made my decision was the fact that it can get to 5 deg of latitude with no other accesories required because I'm located at 4.8 deg North. So, no matter how good or bad its competitors are, they didn't work for me.
Apart from that, I have been kindly surprised by the good performance of this mount, as many other owners of it have. I know at least two other cases in which the PE with PEC has been taken to 4 and 6 arcseconds, which are in the same range as I am. Tracking is good, alignment is easy wih the built-in routine and the go-tos are always into the FOV.
Having said that, it is not a Mach 1 or a Paramount, but is a very good mount. I'm in no way related to iOptron. I'm just a satisfied costumer.
Is it the right mount for you and within your price range? You have to evaluate that.
Let us know if you need more help.
All the best,
Alfredo
Alfredo Beltran
Reged: 08/01/10
[Re: freestar8n]
#5704841 - 02/28/13 08:08 AM
Hi Frank
How can the fwhm be measured? I'm very interested in measuring that.
Alfredo
freestar8n
Reged: 10/12/07
#5704868 - 02/28/13 08:25 AM
Hi Alfredo-
Most image processing tools provide a way to measure it. You just need to take a guided image of perhaps 5-10 minutes that is focused as well as you can. You need to know the plate scale, arc-seconds per pixel - which you can estimate using the focal length and the pixel size - or use plate solving software. It should be a raw or calibrated image that has not been stretched or manipulated at all.
As long as the stars aren't saturated, they should all have the same width when measured at half their height (fwhm). So the brighter ones look wider - but they are also "taller" - and when you measure them half way up to their peaks - the width will be about the same for all.
The fwhm in arc-seconds is an indication of how well you are imaging. Extreme professional results at excellent sites can be as small as 1", while a typical result with a guidescope is around 4" perhaps. I consider a good target to be 2".
So if you use Maxim or Images Plus or something - you can just enter the plate scale (arc-sec per pixel) and point at a star and read the fwhm.
If you get a big number it could be due to seeing or guiding, but I think a common limitation is just making sure the focus is excellent. Anyway - it serves as a quantitative measure of how good your imaging is - so you can measure it and try to improve it.
Frank
Alfredo Beltran
Reged: 08/01/10
[Re: freestar8n]
#5704968 - 02/28/13 09:29 AM
Hi Frank
It seems very simple! I will try it next time I'm outside and see what I can find.
Best regards
Alfredo
freestar8n
Reged: 10/12/07
#5704987 - 02/28/13 09:39 AM
Hi-
I just noticed you may be using a DSLR. In that case you can't measure with the raw images very well and you need to debayer them first. So I would calibrate them with darks/flats/bias - or however you do it - then debayer - then measure fwhm.
Frank
Alfredo Beltran
Reged: 08/01/10
[Re: freestar8n]
#5705001 - 02/28/13 09:46 AM
Hi-
Frank
Very good suggestion Frank, thank you!
Alfredo
Phillip Easton
Reged: 12/24/10
Loc: DFW
#5705164 - 02/28/13 11:40 AM
Alfredo,
You could also get a trial of CCD Inspector. You can easily measure FWHM of several images. It is a good tool for analyzing your images to help troubleshoot issues with your imaging system.
http://www.ccdware.com/products/ccdinspector/
I would take images with short exposure 15-30 sec and then at times you normally image at. This way you can get a better indication of performance of the mount. If the two sets are close then I would think the mount is doing what you want. If the short subs have large FWHM then of course there may be other issuse like colimation, focus, etc. affecting your performance.
Here are the results from my last imaging session. I am imaging at 0.89 arc-sec/pix with my Canon 60D and have adapted a Hotech T-adapter to keep the camera centered. From an analysis of 10 files while guiding for 5 mins each, I neglected to get shorter exposures for analysis last time to compare.
Min FWHM: 2.08"
Max FWHM: 3.50"
Curvature: 31.6%
Tilt in X: -0.1"
Tilt in Y: -0.3"
Total Tilt: 9% @107 deg
Collimation 3.7"
Stars Used: 2483
The numbers don't tell the whole story. When you look at a plot you see how the FWHM changes across your image. Mine is fairly flat but I get curvature in the extreme corners so that is were the stars start getting fat and the max goes to 3.5. The average value was around 2.5.
The rest of the information tells you about colimation and whether your camera is tilted.
Cheers!
Edited by Phillip Easton (02/28/13 11:41 AM)
Alfredo Beltran
Reged: 08/01/10
#5705259 - 02/28/13 12:31 PM
Alfredo,
Hi Phillip
Thanks for the suggestion. I will take a look. Seems very promising.
Best regards
Alfredo
freestar8n
Reged: 10/12/07
#5705401 - 02/28/13 01:52 PM
Short exposures 1-15 seconds can tell you about the optics - but for assessing the autoguiding of the mount it would be better to go for many minutes - preferably at least one worm period. That's what you do when you do deep sky imaging - so it makes sense to use the mount to do what you need to do - and then measure it to see how well you did.
If someone gets small fwhm with a mount - that is a direct indication the mount is capable of achieving that fwhm in a deep sky image - because it did.
Frank
