avalys
journeyman
Reged: 01/19/13
Lunt double-stack module for LS60: 50mm or 60mm? new
      #5700495 - 02/25/13 08:05 PM
I have an LS60, pressure tuned. I am considering buying a double-stack module at some point in the future. The 50mm costs $1,000, the 60mm $1,500.
45% more aperture for 50% more money seems like a good idea to me, especially since I understand the double-stacked image will be dimmer.
Is the difference less obvious in practice? All the "pre-packaged" double-stacked LS60s use the 50mm module. Any reason for this? I assume the 60mm will be brighter, better resolution, etc.
frolinmod
Reged: 08/06/10
Loc: Southern California
Re: Lunt double-stack module for LS60: 50mm or 60mm? new [Re: avalys]
      #5700549 - 02/25/13 08:50 PM
The 50mm module is easier and quicker for them to produce. There's a possibility you might have to wait longer for a 60mm module than for the 50mm module unless either Lunt or a Lunt dealer has them in stock. You might want to call Rikki at Lunt and ask about that. If there is a wait, it's probably worth waiting for.
jerwin
Reged: 05/17/12
Loc: Romeoville IL
Re: Lunt double-stack module for LS60: 50mm or 60mm? [Re: avalys]
      #5700552 - 02/25/13 08:51 PM
I haven't looked through a 60mm DS. I have a 50mm on mine and it's pretty good. What I've read it'd exactly what you said, a little brighter a little better resolution. I don't think it's going to be night an day by any means.
If it were me, I'd buy whichever one I could get faster. If they had the same lead time and I had the $500 to spare I'd probably buy the 60, but I think if the 50 was all you ever knew you'd still be very happy with it.
my 2 cents.
mhilscher
Reged: 07/13/11
Loc: Cologne, Germany
Re: Lunt double-stack module for LS60: 50mm or 60mm? new [Re: jerwin]
      #5701402 - 02/26/13 10:57 AM
I have the 60mm, glad I went with that version.
hfjacinto
I think he's got it!
Reged: 01/12/09
Loc: Land of clouds and LP
Re: Lunt double-stack module for LS60: 50mm or 60mm? new [Re: mhilscher]
      #5703852 - 02/27/13 05:06 PM
I looked through both but got the 50MM, if doing it again I would have gotten the 60MM.
9 registered and 16 anonymous users are browsing this forum.
