BenB85
Reged: 02/17/13
Loc: Colorado and Alaska USA
Whats wrong with my first photo? 5x90sec Orion
      #5708030 - 03/02/13 12:35 AM Attachment (40 downloads)
Hello, I just received my scope and mount today, 127mm apo. So I tried astrophotography.
This is my first astrophoto ever. Its is a composite of 5 90 second exposures through my 5" apo. Is cold here in Denver so I set up the scope on my balcony. I cant see north from my balcony so I just pointed the mount in general north. I did use the SSAG.
Does this look like a 7.5 minute exposure to you guys? I guess Im a little disappointed. Granted the light pollution is bad, but I was expecting more light/detail with 7 minutes.
Im considering returning it and getting a Celestron Edge 1100HD on the CGEM DX with a hyperstar.
I used Deep Sky Stacker and Adobe CS5.
Any advice is appreciated!
Edited by BenB85 (03/02/13 04:35 AM)
NeilMac
Reged: 09/25/10
Loc: MedHat, AB, Canada
Re: Whats wrong with my first photo? new [Re: BenB85]
      #5708041 - 03/02/13 12:45 AM
Besides looking a bit out of focus, you may just need to adjust the colors, reduce yellow saturation etc.
Nice other wise. Play with the picture a bit to see what you can get.
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #5708042 - 03/02/13 12:46 AM
You probably picked one of the harder objects to image as your first object. It's very easy to blow out the core of m42, yet the object has a very high dynamic range. In light polluted skies, you'll want to use a light pollution filter, and then use a Minimal Exposure Regime as explained in the link. Using your histogram is the key to getting your DSLR exposures correct.
Patrick
Joe Bergeron
Vendor - Space Art
Reged: 11/10/03
Loc: Upstate NY
Re: Whats wrong with my first photo? 5x90sec Orion new [Re: BenB85]
      #5708080 - 03/02/13 01:20 AM
You're considering returning your scope on the basis of a single imperfect photo made under imperfect conditions and with no experience? Have a little more patience. Experiment, and learn what you're doing wrong. Buying a new scope won't help with that.
BenB85
Reged: 02/17/13
Re: Whats wrong with my first photo? new [Re: Patrick]
      #5708083 - 03/02/13 01:28 AM
Patrick
Is the light pollution the main issue with the photo then? Meaning, a 7.5 minute photo in dark skies would be far superior?
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #5708107 - 03/02/13 02:06 AM
No, you've over exposed the core of M42. That's detail you'll never get back since it's all white. M42 is a difficult object to get right because it has very bright regions and then a lot of faint wispy regions. To get it right you really need to expose for the core and also expose for the faint areas and then combine them.
If I were you I'd pick an easier object to start with.
Secondly, you need to be taking a lot more subframes. Several hours worth would be more like what you need. You need lots of subframes so that you can start to get rid of the noise a camera produces. Did you take darks, flats, and bias frames as well? You need those other frames to subtract out the noise and camera artifacts to get to the real image.
Get the book A Beginners Guide to DSLR Astrophotography and read it.
Patrick
BenB85
Reged: 02/17/13
      #5708127 - 03/02/13 02:38 AM
Patrick
I will get that book. Thank you Patrick.
This is why I am concerned: http://www.cloudynights.com/documents/rebel.pdf
This gentleman has a 60mm f5.8 scope, unmodified DLSR totaling 8 minutes and he has a fantastic amount of detail coming through. A 5" APO with 7.5 minutes total, modified DLSR, should blow that away. So I dont understand why there is not more light coming through, even if the core is burned out, I should still be getting more nebulosity.
Ben
BenB85
Reged: 02/17/13
      #5708158 - 03/02/13 03:46 AM Attachment (18 downloads)
Hello
Here is the same set just photoshopped more.
Edited by BenB85 (03/02/13 03:47 AM)
RedLionNJ
Reged: 12/29/09
Loc: Red Lion, NJ, USA
      #5708180 - 03/02/13 04:22 AM
With 90 second exposures and a good-quality 127mm refractor, I'd be expecting a LOT more.
There has to be something you're not telling us.
Yes, the focus is a little soft - you'll get the hang of that with practice. I hope you're using BackyardEOS on a computer as a focus, framing, exposure and overall camera control aid.
I can see severe vignetting and posterization. This usually means the image has been stretched too harshly to compensate for underexposure. What kind of ISO did you shoot at? With your setup, I'd set it to 400 and never change it. If that results in a saturated image at 90 seconds, either incorporate a LPR filter or reduce the exposure time. Look at the resulting histogram - it should be clear of the left side but far from touching the right side.
It's hard to tell if the 'soft' stars are really a focus issue or a guiding/seeing issue. I'd lean toward focus primarily because that's the easiest of the two to remedy.
A 5" refractor and an 1000D should be able to pull out a LOT more than this. You WILL get there.
Good shooting,
Grant
BenB85
Reged: 02/17/13
Re: Whats wrong with my first photo? 5x90sec Orion new [Re: RedLionNJ]
      #5708186 - 03/02/13 04:33 AM
Hi Grant,
Yeah, I agree about the 127 should be producing a lot more. That's what I don't get. I used a televue .8x reducer too, at iso800. I am in Denver so the images came out bright red when loaded onto the laptop, I'm assuming from light pollution. I figured with this setup, I should be getting bright images even if they are out of focus, so the only thing I can think of is the camera is the issue, but it is astromodified.
Ben
Smack
Reged: 07/24/09
      #5708298 - 03/02/13 08:14 AM
Ben,
Can you please post a single light frame on dropbox or something like that?
I wouldn't mind having a look.
Steve
Alex McConahay
Reged: 08/11/08
Loc: Moreno Valley, CA
Re: Whats wrong with my first photo? 5x90sec Orion new [Re: Smack]
      #5708303 - 03/02/13 08:20 AM
Good effort on the first shot. THe stars are round which means tracking and alignment is good. It could be sharper and the exposure is off. As has been pointed out, getting exposure right in M42 is difficult because of the wide exposure latitude required (High contrast).
Do not go to a different scope. Your apo is a much better scope for learning the ropes than a high focal length SCT. Really. THe scope is not the thing holding you back from even better shots.
Alex
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #5708369 - 03/02/13 09:10 AM
The images are coming out red because you have a modified camera. All camera makers use a filter over the sensor to block the high end infrared. Modifying the camera removes that filter and makes it more sensitive to the red spectrum. But modifying a camera doesn't put it on steroids. I wouldn't expect too much.
That's not to say you aren't dealing with light pollution and gradients. You most certainly are. Going to a dark sky site always helps with everything!
Patrick
Jeff2011
Reged: 01/01/13
Loc: Sugar Land, TX
Re: Whats wrong with my first photo? 5x90sec Orion new [Re: Patrick]
      #5708420 - 03/02/13 09:50 AM
Focusing issues can be easily solved with a bahtinov mask. I have been able to squeeze out some good detail on shorter exposures using StarTools. There is an evaluation copy you can try.
RedLionNJ
Reged: 12/29/09
      #5708476 - 03/02/13 10:23 AM Attachment (9 downloads)
Such an exposure would likely come out bright red for me, too, without any subsequent processing. Maybe the original data is just fine but we're lacking the appropriate post-processing. I dug up some samples I took earlier this year, with a much smaller scope (81mm, F6) and a Canon T2i. The exposure length was a little longer (120s) and the capture ISO was 800. First, here's a "raw" out-of-the-camera:
RedLionNJ
Reged: 12/29/09
      #5708480 - 03/02/13 10:24 AM Attachment (10 downloads)
Then you average 10 of these together, to get:
RedLionNJ
Reged: 12/29/09
      #5708483 - 03/02/13 10:26 AM Attachment (9 downloads)
Finally, with the application of some levels and curves (not even any darks or flats), you can turn the above into:
Grant
shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
      #5708507 - 03/02/13 10:37 AM
Can you provide some more detail on what you did in photshop? One iteration of curves doesn't cut it, you need 10 or 15 applications of curves and levels to bring out detail when it's buried down close to the noise.
I think there is a lot more in there you could pull out with processing.
Flats are really needed, that's what is causing the darkening around the outside.
If you upload the stacked tiff in dropbox and give a link, I think you would be surprised what other folks are able to pull out.
Smack
Reged: 07/24/09
Re: Whats wrong with my first photo? 5x90sec Orion new [Re: shawnhar]
      #5708567 - 03/02/13 11:06 AM
I imagine the issue is processing. There's likely a lot more data there than you think.
Steve
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5708600 - 03/02/13 11:20 AM
Startools is your friend Best 50 bucks you'll spend
For PS, just remember, to first, neutralize the background (set your white/black points), then color calibrate by aligning each color on top of each other.
You've got some good advice so far. Check out Wodaski's or Jerry's books on it. Wodaski's book is kindof expensive since it's out of print but you'll learn a lot on the basics.
CounterWeight
Reged: 10/05/08
Loc: Cloudyopolis, OR.
      #5708713 - 03/02/13 12:25 PM
Just want to congratulate you on taking the first step.
Patience is key along with a lot of reading and trial and error, and maybe even more patience. I agree to keep the scope, and get focusing down as that is the final word in detail at whatever exposure length you use, it's critically important.
Once over that little hurdle you will find that capturing data is specific to the object you are imaging - as Patrick pointed out M42 is a steep learning curve. Having a decent setup that will track and give you round stars, all the difficulty is in processing data - you may spend a lot more time on that than capturing the image.
It's part of the fun!
Ugmul
Reged: 05/17/11
Loc: Tucson AZ
Re: Whats wrong with my first photo? 5x90sec Orion new [Re: CounterWeight]
      #5709407 - 03/02/13 07:24 PM
One thing to remember, having 5 90sec exposure is not the same as having 1 450s exposure. You will only have 90 seconds of exposure to work with, the 5 extra shots reduce the noise created.
Light pollution filter will help bring out the dust that I belive is getting lost. Also using 400-800 ISO will help as well. Orion is very bright, and you should have more data on a raw 90s exposure.
Are you using raw format? Did you take Darks/Flats?
Hang in there, keep at it, read as much as you can about processing, you can bring out some amazing detail with the right processing tools. Or you can ruin the shots without knowing it.
BenB85
Reged: 02/17/13
      #5709587 - 03/02/13 09:19 PM
Ben,
Steve
Steve
I have never used dropbox but I just downloaded it and put a light frame in.
How do I share it?
BenB85
Reged: 02/17/13
      #5709592 - 03/02/13 09:24 PM
Ben,
Steve
Does this work?
https://www.dropbox.com/sh/3onw4pe8svxkkkf/Fcldmd3QdS?m
Madratter
Reged: 01/14/13
      #5709656 - 03/02/13 10:16 PM Attachment (8 downloads)
There is quite a bit more data than your processing is bringing out. We don't have the darks, the originals, flats, etc. to process this right, but with just the reduced size light you posted, this data was there to be had. If you object to me posting this, please let me know so I can take it down.
BenB85
Reged: 02/17/13
Re: Whats wrong with my first photo? 5x90sec Orion new [Re: Madratter]
      #5709662 - 03/02/13 10:21 PM
NO, that GREAT!
How did you do that? Photoshop? Levels, curves ect?
Ben
Madratter
Reged: 01/14/13
      #5710413 - 03/03/13 11:12 AM
I am positive there are people on this forum that can tease more out of that picture than I did. I am a rookie at this stuff.
I used a combination of Nebulosity and Photoshop CS6.
Nebulosity, I got rid of the background color shift (what they call the offset). I also ran it through what is called DPP, which can be thought of as a fancy form of levels.
In photoshop, I did some additional moving of the blackpoint.
I should have worked on the color balance as well (things are still too blue).
But I was just trying to make a point that there is more data in that picture than you thought. And far more could be brought out by stacking all of your exposures properly, etc.
And the bigger point is that although the equipment matters, it isn't all about the equipment either. The processing of that data you have captured is important too. And that isn't something you can just buy. That is something that needs to be learned and it will take time and effort.
RedLionNJ
Reged: 12/29/09
      #5710505 - 03/03/13 11:53 AM
Agreed on most of Madratter's points, especially the bit about time and effort. I achieved a similar (though not quite as smooth - well done on that part!) version of your image with DSS and an alpha version of GIMP 2.9 (for 16-bit images).
One of my observations on the single-sub data is that it seems to comb quite noticably when stretched. I'd hazard a guess this is due to the 8-bit JPEG format of the image. You may get significantly smoother data from Canon RAW format.
The very best images come from the "cleanest" data. That means perfecting focus/guiding and minimizing noise. Many of the stars in the same frame are a bit wider than desirable and also elongated. This could be the focus is a fraction of a millimeter off (seriously - that's all it takes) and/or that guiding is not configured optimally.
I know not everything went right on MY first attempt and I'm sure many others have similar experiences. Refine one piece at a time and you'll get there. If you don't have sufficient patience, maybe AP isn't for you.
Grant
Smack
Reged: 07/24/09
      #5710530 - 03/03/13 12:14 PM
I was able to get similar results to Madratter and Grant.
Processing is hugely important in astrophotography. The learning curve is steep but the rewards can be very satisfying if you stick with it.
Steve
rigel123
Reged: 06/29/09
Loc: SW Ohio
      #5710692 - 03/03/13 01:51 PM Attachment (5 downloads)
Looks good for a first attempt. I work in mono so I approached your image that way and broke out the different channels since your red channel was way to the right of the histogram compared to the Blue and Green Channel. I then recombined them in PS and did a desaturation of the background.
As others have said, the best advice is patience. Stars are a bit soft on focus (check out getting or making a Bahtinov Mask for checking focus), guiding is off a bit and this is most likely from not getting a good polar alignment. If you can't use Polaris then do a search on Drift Alignment to help with getting your PA sharpened up. Then add more subs and you might check out some tutorials such as Anna Morris's on her website, www.eprisephoto.com Go to the Astrophotography section and Tutorials. With this nebula to get best results you want to take a series of very short exposures (4 to 10 seconds) and then some long ones to get the faint nebulosity and then combine them so that you can get the trapezium in the core and the fainter nebulosity that stretches for quite a distance from the core.
Keep at it and don't beat yourself up too much, this is not a simple process. It typically takes a while to get comfortable with your setup, alignment, capture and processing.
6 registered and 10 anonymous users are browsing this forum.
