yock1960
Reged: 06/22/08
Loc: (Mostly Cloudy) Ohio, USA
Stacking...alignment points new
      #5706853 - 03/01/13 09:39 AM
In the current thread on speckle interferometry...there are some comments on number of and proper placement of AP's. Rather than hijack that thread, I've started a new one. I've been thinking about this, because it's not the first time I've come across these comments.
I suspect this is a can of worms to some extent, but I'd like some discussion, as anything I can do, that's not too difficult or time consuming, that could improve my images, is a good thing!
When I first started this planetary 'obsession' at the end of last year, I was only using maybe 4 AP's. I did notice an improvement when I increased this to about double that. Maybe it was just coincidence? I have tried more, but to my eye, I didn't see any difference. This possibly dovetails into the other issue AP placement. Sometimes it's rather obvious, as in the case of the GRS or some other easily discernable feature and I've read about and can understand staying away from the edges. But many 10's of alignment points and how to place them (since I've read that manual placement is preferred) is a question to me!
Steve
AlanL
Reged: 11/11/10
Loc: Kansas, USA
Re: Stacking...alignment points new [Re: yock1960]
      #5709598 - 03/02/13 09:30 PM
I usually use automatic placement with 20-30 AP's. Usually manual placement doesn't give much improvement for me (maybe 'cause I don't know what I'm doing!).
Kokatha man
Reged: 09/13/09
Loc: "cooker-ta man" downunda...
Re: Stacking...alignment points [Re: AlanL]
      #5709654 - 03/02/13 10:12 PM
Well Steve, that "other thread" had comments by Emil who is the author of AS!2 and imo you can't go past "the horse's mouth" - apologies here Emil...I have no idea whether you resemble a horse...and they are fine, intelligent creatures even if you do!
Seriously, Emil makes the relevant points and in his long-running "AutoStakkert" thread here in this forum you'll find plenty of additional info to give you a sound basis for your own MAPs setting up...
7 registered and 17 anonymous users are browsing this forum.
Moderator:  TG, Starman81, bilgebay, WOBentley
