Astronewb
Reged: 09/19/11
Loc: Connecticut
iOptron ZEQ25GT Payload Test (AT10RC)
      #5712596 - 03/04/13 01:55 PM
Some users have asked about slews at the mount's rated capacity, so I rigged up the AT10RC on the mount to test it at 32 pounds.
AT10RC_ZEQ25GT by Astronewb2011, on Flickr
The little 10 pound mount didn't even break a sweat..here's a link to the YouTube video:
http://www.youtube.com/watch?v=_cIOTROXEpQ
No, don't even think about putting this much weight on the ZEQ25GT in normal use...this is just a test....!
Cheers all,
Paul
psandelle
Reged: 06/18/08
Loc: Los Angeles
Re: iOptron ZEQ25GT Payload Test (AT10RC) new [Re: Astronewb]
      #5712656 - 03/04/13 02:36 PM
Paul - great stuff! Totally enjoying all your videos. I have my iEQ30...so won't spring for this, but when the replacement for the 45 comes out, that's probably what I'll go for (with encoders).
Keep 'em comin'!
Paul
Ricky
Reged: 09/09/03
Loc: Nor Cal
Re: iOptron ZEQ25GT Payload Test (AT10RC) new [Re: psandelle]
      #5712696 - 03/04/13 02:58 PM
Nice!!! I wonder if ioptron will offer a pier/pedestal option for this mount...
zawijava
Reged: 10/06/07
Loc: Wells, Maine 04090
      #5712846 - 03/04/13 04:25 PM
Enjoying your videos Paul, thanks! Does this mount use belts in the drive system? If so, can you or others comment on the benefits and drawbacks of belt drives please
thanks! -Tim
Astronewb
Reged: 09/19/11
Loc: Connecticut
Re: iOptron ZEQ25GT Payload Test (AT10RC) new [Re: zawijava]
      #5712866 - 03/04/13 04:36 PM
Enjoying your videos Paul, thanks! Does this mount use belts in the drive system? If so, can you or others comment on the benefits and drawbacks of belt drives please thanks! -Tim
Hi Tim,
This mount uses cogged belt drives on each axis. In fact, the belt passes thru a reduced section of the mount casting, between pulleys, which serves to act as a belt tensioner of sorts.
The motors are planetary geared reduction DC servo motors. and as you can see in the video..they're pretty potent.
There is not a lot of excessive distance between the two cogged pullys, so the belt almost has to be forced over the pully to seat it...very nice setup.
One advantage to a cogged belt drive is no belt slippage, and a reduced drive harmonic due to the damping characteristics of the belt itself. A direct geared drive would have the dis-advantage of being susceptible to dirt, which would affect periodic error...?
Perhaps some engineering types can comment further?
Thanks for the nice comments,
Paul
Astronewb
Reged: 09/19/11
Loc: Connecticut
      #5712884 - 03/04/13 04:48 PM
Thanks Paul and Ricky.
@ Paul...if a "Z-Balanced" mount comes out, the same or similar capacity as the iEQ45 , with precision encoders...I'll be all over it like stink on you know what.
@ Ricky...there is an optional 2" tripod that will be available, but I haven't heard anything about a pier yet...though with the adjustable counterweight..a pier is just 'nice' to have instead of 'must' have for low latitude users.
And for the users in Alaska, at 62 degrees lat..this mount will go to 61.7 degrees max, measured with an inclinometer..so you might have to look elsewhere, or move where it's warmer...:) (Or lower two tripod legs for the extra few degrees)
Clear skies,
Paul
Edited by Astronewb (03/04/13 04:50 PM)
Ricky
Reged: 09/09/03
Loc: Nor Cal
      #5712987 - 03/04/13 05:30 PM
Thanks Paul,
If I decide to pu this mount I may just have a 4" adapter plate machined to fit on my ped30 pier...
tjugo
Reged: 11/06/07
Re: iOptron ZEQ25GT Payload Test (AT10RC) new [Re: Ricky]
      #5713176 - 03/04/13 07:28 PM
Paul et al,
What's the difference (in performance) between this mount and the iEQ30? Feature and capacity-wise they look pretty close, but this mount is almos 40% cheaper.
I will pull the trigger soon on a new mount small mount, my candidates were:
-- Orion Sirius
-- Celestron AVX
And now I am interested in this new mount...
Jose
Astronewb
Reged: 09/19/11
Loc: Connecticut
Re: iOptron ZEQ25GT Payload Test (AT10RC) new [Re: tjugo]
      #5713569 - 03/04/13 11:05 PM
Right Jose, they are close in performance. But the iEQ30 is the classic German EQ type..no real fulcrum point, just a couple of latitude locks placed anywhere it's convenient.
The Z Balanced Chinese Equatorial mount has a centrally located fulcrum pin, which allows for better weight transfer and balance..especially due to the 'Z' design.
And I presume the cost is driven down by the smaller casting needed for the mount, and a sharing of previously proven components whose initial R&D costs have been largely absorbed. Makes me wonder why Apple and MS prices continue to rise..?
The ZEQ25GT mechanically and from a design standpoint is excellent. The software routines I have still not fully explored due to lack of clear nights. I know the tracking and go-to's are spot on. Now to see how it images....
Best,
Paul
Edited by Astronewb (03/04/13 11:06 PM)
timmbottoni
Reged: 08/25/05
Loc: W Chicago suburbs, IL USA
      #5713588 - 03/04/13 11:18 PM
Wow - that's cool. I'm really looking at the iEQ45 for getting started with DSLR AP - thanks for your posts and videos
Timm
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5714102 - 03/05/13 10:11 AM
A toothed belt drive is really not much different than a geared drive. It is suseptable to PE, dirt, etc. just like a geared drive. It may in fact be more difficult to keep tight controls on the quality of the belt used (an likely made by a different company) than on gears. They are really just different means to the same end.
Jaime Riviere
Reged: 05/07/09
Loc: Salamanca, Spain
Re: iOptron ZEQ25GT Payload Test (AT10RC) new [Re: EFT]
      #5722434 - 03/09/13 02:35 PM
Thanks for the videos, Paul. They are really informative I am also thinking on this mount, although it is not the best moment pocket-wise...
korborh
Reged: 01/29/11
Loc: Arizona
      #5722610 - 03/09/13 04:38 PM
Right, AP mounts use many gears in its gearbox and have ultra-low PE.
Gears have advantages as they wont be susceptible to stretching/slippage, are more robust, longer life and provide more torque. I can imagine the precision ones costing much more than belts.
Astronewb
Reged: 09/19/11
Loc: Connecticut
Re: iOptron ZEQ25GT Payload Test (AT10RC) new [Re: korborh]
      #5723259 - 03/10/13 12:28 AM
Gears have advantages as they wont be susceptible to stretching/slippage, are more robust, longer life and provide more torquert
True enough. But cogged tooth belts have 'zero' slippage. Every modern racing engine and sports car mfg uses mainly cogged tooth timing belts, subject to rpm's of 10,000 rpm per minute and up...with no issues.
How much torque is a cogged belt subject to driving up to 32 valves, and torsion springs at 8000-10,000 rpm?
I don't think a cogged belt on a servo motor running at sidereal speed is going to have any problem whatsoever. Just saying...:)
Paul
herrointment
Reged: 03/12/11
Loc: North of Hwy. 64
      #5723338 - 03/10/13 03:29 AM
I once lusted for a comely LX80 but she was an illusion.
This siren sings a rapturous tune, I do reckon!.
Senator48
Reged: 03/12/12
Loc: New Jersey
Re: iOptron ZEQ25GT Payload Test (AT10RC) new [Re: herrointment]
      #5726057 - 03/11/13 03:07 PM
Great video! Thanks for taking the time - and risk to you RC - to do this mount test. Have to add this to my short list of potential mounts.
14 registered and 35 anonymous users are browsing this forum.
