CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Win 8 driver for Paramount MX
      #5715586 - 03/05/13 11:10 PM
Tonight I tried o power up my MX for the first time and install the driver. My Win 8 laptop will not accept the non-signed driver. I have done the update and daily build from SB. I cannot find an updated driver on their website. Between not being able to sign into my SB account without switching my computer to some "compatibility mode" and having an $8400 brick sitting on my kitchen floor, I'm losing a little patience. Does anyone have a fix for this driver problem? Thanks,
CharlesW
Reged: 11/02/12
Re: Win 8 driver for Paramount MX new [Re: CharlesW]
      #5715675 - 03/06/13 12:25 AM
A very kind gent on the Software Bisque site suggested getting into the advanced start up menus for Win 8 and disabling the signed drivers requirement. That did work but it took two restarts to drill down to that menu.
frolinmod
Reged: 08/06/10
      #5715695 - 03/06/13 12:42 AM
You gotta love Microsoft.
Bob Moore
Reged: 04/07/06
Loc: New York
      #5715703 - 03/06/13 12:48 AM Attachment (8 downloads)
sounds like a lot of trouble to me, I'll take the MX off you hands for 5K.
your going to love the mount, I have used all kinds of mounts, the PMX blows them all away.
PGW Steve
Reged: 10/03/06
Loc: Winnipeg, Canada
Re: Win 8 driver for Paramount MX new [Re: Bob Moore]
      #5716184 - 03/06/13 11:08 AM
I had an issue with a serial card in my Windows 8 machine that I use for an SBIG All Sky Cam.
My IT guy got this procedure from the maker of the serial card, and it worked fine. Glad to see that you got it sorted out!!!!
1. From the Desktop move your mouse to the top right hand corner of the screen. This will pull up the "Charm Bar" and select "Settings".
2. From the "Settings Menu" select "Change PC settings". This will pull up a new Window.
3. From the "PC Settings" windows select "General".
4. At the bottom of the General Settings Page, you will find "Advanced Startup". In this section click on "Restart Now". Don't worry there are still plenty of steps left.
5. From this new Window select Trouble Shooting > Advanced Options > Startup Settings and finally Restart.
6. At this point your system will reboot and present you with a series of options allowing you to enable or disable several startup options.
7. Within this first page you should see a F-Key that refers to "Disable Driver Signature Enforcement". Once you enter the appropriate F-key, the system will startup, allowing you to install hardware that hasn't been digitally signed.
oo_void
Reged: 11/13/09
Loc: San Francisco, CA
Re: Win 8 driver for Paramount MX new [Re: PGW Steve]
      #5716489 - 03/06/13 02:06 PM
You could also just right click on the installer and "Run as Administrator".
PGW Steve
Reged: 10/03/06
Re: Win 8 driver for Paramount MX new [Re: oo_void]
      #5717619 - 03/07/13 01:24 AM
You've actually had this work with Windows 8?
frolinmod
Reged: 08/06/10
      #5717668 - 03/07/13 02:38 AM
I was under the impression that all installers on Windows 7/8 automatically run as administrator whether you explicitly run them that way or not. Not that this has anything to do with Windows Test Mode that allows one to run unsigned drivers. Test mode can be turned on permanently. I run in Test Mode at all times because I run with home brew (developer) drivers that will never be signed by Microsoft.
PGW Steve
Reged: 10/03/06
Re: Win 8 driver for Paramount MX new [Re: frolinmod]
      #5717918 - 03/07/13 08:39 AM
The problem isn't the installer. It has to do with the 'digital certificate' not being signed. Thus the detailed procedure to get around the issue and install a driver.
blueman
Vendor Blue Sky Accessories
Reged: 07/20/07
Loc: California
      #5718515 - 03/07/13 02:05 PM
This is the main reason that I bought another Win7 laptop this month. I just do not want to deal with Win8 and all the problems associated with it. Plus I am not a fan of the new interface.
Win9 will be out soon and then Win8 will be another Vista. I just don't see the need to get into the Microsoft point of view on opperating systems.
Blueman
WesC
Reged: 02/06/13
Loc: La Crescenta, CA
Re: Win 8 driver for Paramount MX new [Re: blueman]
      #5764562 - 03/29/13 12:34 PM
I've had driver problems like this going all the way back to Win95... this is not a new problem.
24 registered and 28 anonymous users are browsing this forum.
