DarkDisplay
Reged: 12/21/10
Loc: Texas
The accuracy of lens size new
      #5717217 - 03/06/13 08:28 PM
I can't understand why the supposed lens size on many binoculars is not accurate. A 10x50, for example, may actually be less than that. It might be made very well. Yet, the stated lens size is misleading. The observer would not really be getting a 10x50 view. This matters.
Two questions for those more informed than I am:
1. Why is this so common and is there any way it could be prevented?
2. Are there companies that are accurate (as is possible) when presenting the lens size for a binocular?
Much thanks for your comments.
Best wishes,
Frank
EdZ
Professor EdZ
Reged: 02/15/02
Re: The accuracy of lens size new [Re: DarkDisplay]
      #5717227 - 03/06/13 08:33 PM
all the objective lens sizes are accurately made. That's not where the problem lies. It's most commonly in the prisms, which are often too small to pass the entire light cone from the objective lens. Bigger prisms raises a whole bunch of additional design issues, so it's not easily solved.
edz
hallelujah
Reged: 07/14/06
Loc: North Star over Colorado
      #5717252 - 03/06/13 08:49 PM
Frank
Take a look at these under the aperture heading:
http://www.cloudynights.com/item.php?item_id=1770
Stan
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: The accuracy of lens size new [Re: hallelujah]
      #5717412 - 03/06/13 10:23 PM
The physical clear aperture of most binoculars are as stated, with a few being perhaps 1mm smaller due to the construction of the lens cell.
The far greater problem, ad Ed pointed out, is effective aperture restriction. While we commonly think this results from too-small front prism openings, it's really because of the manufacturer's insistence (spurred by customer demand for compactness) on using objectives of excessively short focal length. If instead of the f/3.75-4 lenses so commonly used, f/4.5 or so would redress this unnecessary affliction.
Reged: 06/16/04
Re: The accuracy of lens size new [Re: GlennLeDrew]
      #5717779 - 03/07/13 06:25 AM
The barrels themselves can be the restriction, there is not enough clear aperture for that F/3.75 focal ratio. This is probably a result of designing around the undersized prisms.
DarkDisplay
Reged: 12/21/10
Loc: Texas
Re: The accuracy of lens size new [Re: EdZ]
      #5717828 - 03/07/13 07:32 AM
"...so it's not easily solved."
I suppose companies could put 10x50(more or less), 15x70(almost), etc. on their binos. A little sarcasm, but it's true. Some companies probably do their best. Others may not really care about accuracy. I prefer a binocular that is what it's supposed to be.
Best wishes,
Frank
Tony Flanders
Reged: 05/18/06
Loc: Cambridge, MA, USA
      #5717838 - 03/07/13 07:40 AM
I don't think this is any accident. Premium-priced binoculars today run at or very near their advertised aperture. And almost all binoculars from the 1970s or earlier ran at or near their advertised aperture.
DarkDisplay
Reged: 12/21/10
Loc: Texas
Re: The accuracy of lens size new [Re: Tony Flanders]
      #5717909 - 03/07/13 08:32 AM
Yes, there was a time when people took pride in the quality of the product they made. It seems that many companies today aren't like that.
Best wishes,
Frank
Reged: 06/16/04
Re: The accuracy of lens size [Re: DarkDisplay]
      #5717943 - 03/07/13 09:04 AM
Best wishes,
Frank
I think it more about getting what you pay for.
There have always been poorly made, under performing, "junk" binoculars. We tend to remember to the "typical" binoculars from earlier eras as the ones that are still around today, those are the ones good enough to last 40 or 50 years, the ones that were good enough for someone to hang onto for 40 or 50 years. When I travel the garage sale route, I seem pretty poor quality plastic binoculars and stamped metal binoculars from years gone by.
It's more about what the buyer is willing to accept. There have been numerous posts here about the Celestron 15x70s, Celestron is making something people, knowledgeable people, are willing to buy. The reality is, a 15x63 for $75 is still a good value and offers reasonable performance (if collimated).
If you want to purchase binoculars made with pride, there are many, many out there to choose from. But they cost more than $75.
Tony Flanders
Reged: 05/18/06
Re: The accuracy of lens size new [Re: Jon Isaacs]
      #5718036 - 03/07/13 10:09 AM
You can say that again! I still have the pair of binoculars my parents gave me when I was a young child, and they're just awful. However, they were surely marketed as kid's binoculars.
On the other hand, I have a pair of 10x50 Celestron Ultimas from the late 90s that are really quite good, both mechanically and optically. But their effective aperture is actually 46 mm. Not terrible, but enough to make a difference.
GlennLeDrew
Reged: 06/18/08
      #5718250 - 03/07/13 11:47 AM
Here's something I noted which often differentiates older from newer Porro binos.
The older ones usually employed 25mm prisms, which moreover had notable angled slices cut off on one or both sides of the apex. This allowed the field stop to be placed closer to the rear prism aperture, which in turn allows the objective to be located commensurately farther forward of the front prism aperture. A more forwardly positioned objective means its light cone is a bit narrower where it meets the front prism aperture, this lessening (or obviating) aperture reduction.
Modern binos of lower cost mostly seem to use 22mm wide prisms, which sometimes do not have the larger angled slice off the apex. The latter feature notwithstanding, the narrower prism often does not allow the field stop to be placed nearer to the rear prism aperture, thus forcing a somewhat closer positioning of the objective to the front prism aperture. And this tends to result in aperture reduction.
It's not so much about the quality as it is about dimensioning of components. If a smaller prism is used, which forces the eyepiece's field stop farther back, a slightly longer focal length objective ensures full aperture performance.
Of course, when quality is bad, a potential affliction is turned edges on lenses and prisms, due presumably to too-vigorous polishing. (I've seen pretty egregious examples of this defect.) If there is turned edge on the objectives, a reduced aperture is a benefit, for it masks the image-damaging periphery.
Mark9473
Reged: 07/21/05
Loc: 51N 4E
      #5718534 - 03/07/13 02:15 PM
That made me smile, Glenn, "Porto" binoculars. A bit out of fashion, but still, ...
KennyJ
The British Flash
Reged: 04/27/03
Loc: Lancashire UK
Re: The accuracy of lens size new [Re: Mark9473]
      #5718553 - 03/07/13 02:25 PM
Aren't these new "Porto" binoculars the ones made in Portugal? :-)
Kenny
ronharper
Reged: 02/14/06
Re: The accuracy of lens size new [Re: KennyJ]
      #5718663 - 03/07/13 03:20 PM
And aged 30 years in oak casks?
GlennLeDrew
Reged: 06/18/08
Re: The accuracy of lens size new [Re: ronharper]
      #5718976 - 03/07/13 06:08 PM
Ha ha, guys. I've gotta watch what I type like a hawk, because of the auto-correction in my iPhone. But I dare not disable it 'cause otherwise I'd really be doing a lot more correcting myself. A blessing and a curse, but I more of the former if I'm honest.
6 registered and 20 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, WOBentley
