John Miele
Reged: 05/29/05
Loc: North Alabama
PHD Guide Image Brightness new
      #5713112 - 03/04/13 06:48 PM
Just tried my new QHY5-II Mono camera for guiding last night for first time. I had it mounted in my ST-80. Even at 1 second exposures, the guide image in PHD was very bright and looked way overexposed. The contrast between stars and background was poor and washed out. I have not guided in a while, but I recall my older QYH5 based Kwiq-guider behaved similarly but not as bad. Are there settings in PHD to improve the contrast and darken the background? I cannot find any. It was so bad that I am half way considering stopping down the ST-80 to increase the focal ratio and maybe darken the background that way. I did find a camera gain setting and will fiddle with that next time...Thanks...John
P.S. I know it will get asked and the answer is...No...I did not ever get it to guide due to unrelated issues I had actually run across before and forgotton about in my time away from guiding ...
Mike7Mak
Reged: 12/07/11
Loc: New York
Re: PHD Guide Image Brightness new [Re: John Miele]
      #5713135 - 03/04/13 07:06 PM
There's a slider somewhere in the PHD window that varies the contrast of the guide image.
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: PHD Guide Image Brightness new [Re: Mike7Mak]
      #5713271 - 03/04/13 08:15 PM
Well whatdayaknow! Thanks Mike. I can't beleive in all the times I used PHD I never noticed that slider ! I'll try it out next chance. Thanks again!!...John
Harel_Boren
Vendor-The Boren-Simon PowerNewt Astrograph
Reged: 03/15/09
Loc: Israel
      #5716864 - 03/06/13 05:11 PM
I think you may solve this by shooting darks for it. It's an automatic process in phd.
Harel
JoseBorrero
Reged: 09/04/09
Loc: MI
Re: PHD Guide Image Brightness new [Re: Harel_Boren]
      #5717739 - 03/07/13 05:14 AM
If the camera is binned, also increase brightness.
astrovienna
Reged: 12/04/06
Loc: The NoVa White Zone
Re: PHD Guide Image Brightness [Re: JoseBorrero]
      #5717955 - 03/07/13 09:13 AM
How bright were the guide stars? If I understand correctly, PHD adjusts the display brightness depending on the stars. Bright stars will give you a dark background. Adjusting the slider will help, but faint stars will still have a bright background. The background doesn't affect the guiding at all, however.
Kevin
Tandum
Reged: 03/01/10
Loc: Brisbane, Australia
Re: PHD Guide Image Brightness new [Re: astrovienna]
      #5718022 - 03/07/13 10:00 AM
There is also a gain control for the camera in ascom setup before you connect.
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: PHD Guide Image Brightness new [Re: Tandum]
      #5718691 - 03/07/13 03:32 PM
I actually did take darks the other night and it was still very bright and washed out. The stars themselves were hard to pick out from the background. But I must have done something wrong because this camera is known to work well. I'm going to try again tonight and will adjust that gamma/contrast slider and/or the camera gain to see what works best. Thanks for the replies from everyone and I'll report back...John
AstroScience
Reged: 10/28/10
Loc: Israel
      #5719676 - 03/07/13 11:55 PM
John, what version of PHD you use?
QHY is the same camera as Orion SSAG and i think i know what's the problem.
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: PHD Guide Image Brightness new [Re: AstroScience]
      #5720027 - 03/08/13 08:41 AM
Hi Sergio,
I'm using the latest version from the Stark Labs website.
I tried again last night. I had used Procyon as an alignment star so it was in the QHY5's FOV. I immedatley noticed the background was much darker and the star field looked more contrasty. I moved the gamma/contrast slider a bit and got a very pleasing view. Then I slewed to my target galaxy which had no bright stars around it and the view became all washed out again. I was able to move the slider almost all the way to the right and the few stars in the field stood out well enough to lock on for guiding but I did get some starmass warnings that periodically flashed on and off. I used 2 second guide exposures and a dark frame. So it looks like when there is a bright star in the field, PHD does perform somy type of auto adjustments on contrast which can be augmented with the slider and you get a nice dark and contrasty background. But when you only have faint stars in the field, it's difficult to darken the background and get good contrast. I don't think this is anything unique to using the QHY5-II. I have not guided in a while, but I remember my old Kwiq-guider doing something similar...John
astrovienna
Reged: 12/04/06
      #5720780 - 03/08/13 04:11 PM
You can always get a reality check on the star with Tools>Star Graph (or something like that). This shows a cross section of the star, which helps me predict whether that star is really usable by PHD.
Kevin
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #5720856 - 03/08/13 05:11 PM
Just to be clear about this. PHD does NOT use the gamma slider you set for PHD to detect the stars. PHD detects stars however the programmer (Craig Stark) set it. Gamma slider is there for each user to view the stars on the computer monitor. Changing the gamma slider points has no effect for PHD Guiding.
Peter
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: PHD Guide Image Brightness new [Re: Peter in Reno]
      #5722251 - 03/09/13 12:41 PM
Thanks Peter. I was wondering a bit about that very question. Had another session last night and while my guiding performance was not as good as I wanted, PHD worked well and locked onto the guide stars with no trouble...John
16 registered and 15 anonymous users are browsing this forum.
Moderator:  Oldfield, bilgebay
