jonathanCR
Reged: 07/02/07
Loc: Costa Rica
3/16” x 1 ½” Side Rails instead of ¼” x 1 ¼”? new
      #5716739 - 03/06/13 04:07 PM
The K&B book recommends using ¼” x 1 ¼” steel side rails for an 18 points mirror cell (for 16” mirror) but I only have access to some scraps of 3/16” x 1 ½”. Do you think the stiffness or the strength of the mirror cell would be compromised by using these?
Regards
starman345
Wait, I'm Thinking
Reged: 07/06/10
Loc: New Brunswick, Canada
Re: 3/16” x 1 ½” Side Rails instead of ¼” x 1 ¼”? new [Re: jonathanCR]
      #5717226 - 03/06/13 08:33 PM
I would use it if that is all you have. I can't imagine it would have a negative impact on your build. You are going to have your cell welded together?
Pinbout
Reged: 02/22/10
Loc: Montclair
      #5717481 - 03/06/13 10:53 PM
Is it cold drawn or hot rolled?
Online metals.com sells 1018 cold drawn flat bar and the square tubing really cheaply and they'll cut it for you too fairly accurately
I like thicker cause of weight.
But the strength of the 3/16 is fine
Achernar
Reged: 02/25/06
Loc: Mobile, Alabama, USA
Re: 3/16” x 1 ½” Side Rails instead of ¼” x 1 ¼”? [Re: jonathanCR]
      #5717971 - 03/07/13 09:25 AM
I'm sure that will be fine, since the flatbar is 1/4" wider. When welded it will be more than strong enough, I made some brackets out of the same size and type of steel as the mirror cell in my scope that are supporting hundreds of pounds. I am not near as good a welder as other folks, but when I weld mild steel, the welds don't break even when the metal is subjected to being crushed or bent like a bobby pin. If you wish to use high strength steel, make sure to use the right rod or wire. High carbon and alloy steels often require pre-heating to weld without cracks forming in the welds. I's personally just use mild steel, and a 70,000 psi tensile strengh rod or wire suited to it. That way, the welds will be stonger than the base metal itself.
Taras
20 registered and 21 anonymous users are browsing this forum.
