Speciality Forums >> Stellar Media
rinalmj
Reged: 11/23/09
Loc: Saxonburg, PA
Writing in charts new
      #5725476 - 03/11/13 09:55 AM
I'm trying to decide on the best way to draw in the constellation lines in my Sky Atlas 2000. Pencil seems like a logical choice because I could go back and erase portions if I ever wanted to, but I'm worried about it smearing over time. I'm wondering what others have done and what has (and hasn't) worked well. Thanks!
droidModerator
rocketman
Reged: 08/29/04
Loc: Conneaut, Ohio
Re: Writing in charts new [Re: rinalmj]
      #5725639 - 03/11/13 11:34 AM
Another idea, go to office max, pick up some clear over head projector over lays, lay on top of chart ,draw away.
Reged: 07/06/07
Re: Writing in charts new [Re: droid]
      #5726093 - 03/11/13 03:26 PM
But you have to have something that will draw nice sharp lines on view-graph film and not smear under dew...
OP: My pencil constellation lines have never smeared over many years of use in dew that is probably worse than yours.
faackanders2
Reged: 03/28/11
      #5726821 - 03/11/13 08:41 PM
The finder chart has the lines. The detailed charts do not, because too often they would go off the chart. They are needed for more a mental orientation. Using the finder you can orient the detailed chart. Since the actual sky doesn't have lines, lines on the detailed chart don't help once you have the orientation right (since most mentally look at the brightest stars first and work their way down in brightness.
rinalmj
Reged: 11/23/09
Loc: Saxonburg, PA
Re: Writing in charts new [Re: faackanders2]
      #5728320 - 03/12/13 02:49 PM
I don't mind if they go off the page, I'm just so used to visualizing the shapes of the constellations that it would be beneficial for me to have the lines drawn in. The finder chart does help, but I'd rather have the lines on the main charts as well. My only concern is smearing.
edwincjones
Close Enough
Reged: 04/10/04
      #5728419 - 03/12/13 03:41 PM
the chart is a tool
not a sacred object
use it as needed
replace when used up
edj
Carol L
Reged: 07/05/04
Loc: Tomahawk, WI 45N//89W
Re: Writing in charts [Re: rinalmj]
      #5728733 - 03/12/13 06:16 PM
Use pencil - i made a few mistakes using ink and although white-out covers the mistake, you can still tell it's a patch-job. If the pencil lines smear after a while, just re-do them and they'll look like new.
I used a Sharpie on my laminated set and it worked well. Mistakes can be removed (with enough pressure) if they're caught soon. The downside of using the Sharpie is that over time, the lines will need to be refreshed. Every time the dew is wiped off of the chart, a bit of the Sharpie comes off too.
0 registered and 4 anonymous users are browsing this forum.
Moderator:  droid, okieav8r
