AlexxxAA
Reged: 01/06/12
Loc: Downey, CA
Which 6" Achro to get??? *DELETED*
      #5732173 - 03/14/13 12:29 PM
Post deleted by AlexxxAA
SeptemberEquinox
Reged: 01/29/12
Re: Which 6" Achro to get??? new [Re: AlexxxAA]
      #5732208 - 03/14/13 12:54 PM
I believe the skywatcher f/5 scope is a same scope as mine, from synta. I love my scope, it is sharp. You do get false colors on really bright objects, but it doesn't bother me much, why? Because details on the objects are sharp, just pretty fringing around it. I did order Baader Semi Apo to see if it can improve its sharpness. I can see m81 and m82 in a very light polluted area with this scope. If you are looking to buy 6" achromatic refractor, I'd vote on 6" f/5. And it only weights 16 pounds.
SeptemberEquinox
Reged: 01/29/12
Re: Which 6" Achro to get??? new [Re: SeptemberEquinox]
      #5732248 - 03/14/13 01:22 PM
And I love the focuser that came with the scope.
galaxyman
Vendor - Have a Stellar Birthday
Reged: 04/04/05
Loc: Limerick, Pa
      #5732269 - 03/14/13 01:31 PM
Between both of these scopes the ES is the better scope. Probably better optics, better coatings (a little less reflective), much better focuser, and can be collimated whereas the 6" f/5 does not have an adjustable cell. A Celestron version 6" f/5 I checked was way out of collimation and was sent back to Celestron to deal with it. The scope is fine now with a happy owner.
The only drawback of the ES 6" f/6.5 that it is the bulkier scope, but it's certainly not overwhelming.
Karl
E.O.H.
Chesmont Astronomical Society - www.chesmontastro.org
Galaxy Log - http://www.youtube.com/user/GalaxyLog4565?feature=mhee
Glaxy Log Blog - http://galaxylog.blogspot.com/
HASB - http://www.haveastellarbirthday.com
Telekit (Swayze optics) 22" F/4.5 Dob
Homemade (Parks Optics) 12.5" F/4.8 Dob
TMB/APM 8" f/9 Refractor”The Beast”. One great DEEP SKY achro
ES 6" f/6.5 achro. Good one
Celestron Omni XLT 102 refractor.
Celestron 10x60mm Binos
jbalsam
Reged: 07/06/12
Loc: Darnestown, MD
Re: Which 6" Achro to get??? new [Re: galaxyman]
      #5732324 - 03/14/13 02:14 PM
EDIT: I know you said you're getting out of AP, but I'm going to leave this response for anyone else weighing a similar question who might be interested.
I have the ES AR152 and I love it. I got it used for around $600 from Gary Hand. I use it for astrophotography, and it's great. CA is definitely noticeable as star bloat when using a OSC camera, but with a filtered mono camera and refocusing between filters it's beautiful.
I did have a problem with the optics being pinched at one point (during cold weather), but loosening and re-seating the secondary lens set screws fixed that. Collimation is easy, and it holds it well.
I'm not much into observing, and I haven't compared it against anything else in that category so I can't give any objective info there. I've peered at a few bright nebula (Orion, ring, etc) and they're there. That's about all I know to say.
EDIT: I've used the AP CCDT67 telecompressor with this scope and it handles it very nicely (speeds it up to around F/4.4 if you get the spacing right). I use it to squeeze in large nebulas like the rosette, or bits of the heart/soul.
Edited by jbalsam (03/14/13 02:19 PM)
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
Re: Which 6" Achro to get??? new [Re: jbalsam]
      #5732371 - 03/14/13 02:47 PM
I own an AR152, but I can't speak to the other scope you mentioned. The AR152 build quality is top notch for a mass produced scope -- very impressive for it's price point. The main drawback of the AR152 for me, as you've already mentioned, is mounting it. I have mine mounted on a CG-5 which works fine for visual up to about 250x. You'll need a very light touch with the focuser at higher magnifications with a CG-5 class mount. It also requires 2 11lb. counterweights to balance in RA. I ended up purchasing an Orion Sky View Pro 16" extension for the mount which improved dampening times and also keeps the mount from hitting the tripod legs, but that comes with a cost of making the mount more unwieldy. I might eventually end up getting an Atlas for the scope.
I timed myself setting up the scope one night and it takes about 15 minutes and 4 trips to set up on my back patio. First I carry out the mount, then the counterweights, then the scope, and finally the accessories (power tank, EP case, and chair). If you have the capability to mount the scope and can deal with a little extra set up time, I think you would love the AR152.
The scope performs very well optically -- just be prepared to deal with CA on objects of about 3rd magnitude and brighter. On nights of poor seeing, I've seen CA on object down to about 3.5 or 4. This scope provides some breath taking wide field views though and I love using 2" eyepieces in it. Even my cheapo 38mm Q70 provides great view in this scope.
AlexxxAA
Reged: 01/06/12
Loc: Downey, CA
Re: Which 6" Achro to get??? new [Re: Mike4242]
      #5732634 - 03/14/13 05:40 PM
Thanks guys! Your input and experience helped a lot
De Lorme
Reged: 12/30/08
      #5732647 - 03/14/13 05:50 PM
I have the CR6" f/8 which is really great!. If you can look
at the optics before you buy, I would get a Ronchi Eyepiece
buy Easytester. Mine showed straight lines all the way accross with either 4 or 7 lines. Also Istar is coming out with the their Raycorr this spring for around $300.
Their saying that this will make your achro into a very very
good ED or perhaps even a Apo,depending how good your optics are to begin with. De Lorme
De Lorme
Reged: 12/30/08
Re: Which 6" Achro to get??? new [Re: De Lorme]
      #5732660 - 03/14/13 06:02 PM
Just thought you should know, I can get the Double Cluster
in the field of view using a Measde 32mm super plossi.
I have a CGEM{in a rool off roof} and I extend the legs all the way to the last 3" inches and it works great. The only time I have to get on my knee is when it's pointed staight up at zenith, which is seldom. Otherwise I use 2 different chairs. One for almost standing and the other just sitting.
De Lorme
AlexxxAA
Reged: 01/06/12
Loc: Downey, CA
      #5732879 - 03/14/13 08:07 PM
Wow that's awesome for an f/8 !!! So my 32mm should get a really nice wide view!
bob midiri
Reged: 06/17/04
Loc: pa 19320
      #5733458 - 03/15/13 03:57 AM
with my CR6 and the Meade UWA 24mm I easily get both nM81 and 82 in same FOV, with a lot of sky around them. its a great combination
dlapoint
Reged: 08/18/03
Loc: Moncton NB Canada
Re: Which 6" Achro to get??? new [Re: bob midiri]
      #5733932 - 03/15/13 11:24 AM
Go with an at 152, or es 152. You still get 6" of aperture and a compact body with nice features. Focuser etc.
AlexxxAA
Reged: 01/06/12
Loc: Downey, CA
Re: Which 6" Achro to get??? new [Re: dlapoint]
      #5733939 - 03/15/13 11:28 AM
Sounds good guys!
Already got the ES 152!
Waiting for first light this weekend. Either tonight or Sunday
Mike4242
Reged: 11/02/11
Loc: Memphis, TN
      #5733940 - 03/15/13 11:29 AM
Awesome! Looking forward to your first light report.
saemark30
Reged: 02/21/12
      #5734135 - 03/15/13 01:20 PM
I don't know if there are any differences between a new Skywatcher 6" f/8 and older dark blue tube ones.
There was also one marketed by Efstonscience and Celestron C6R.
They were all made by Synta and should have the same quality or lack of.
AlexxxAA
Reged: 01/06/12
Loc: Downey, CA
Re: Which 6" Achro to get??? new [Re: saemark30]
      #5735499 - 03/16/13 03:55 AM
So today was the day to test out the new AR152...
But like always... The "New Telescope Curse".
We've had clear nights here for like 2 weeks! But tonight the marine layer creeps in. And then the moon is coming up too. So I guess it's Moon and Jupiter observations for the next 2 weeks lol
hottr6
Reged: 06/28/09
      #5735919 - 03/16/13 10:35 AM
APO-snobbery? Synta actually makes pretty good optics, and certainly at a price-point that makes good optics affordable by everyman. I believe good demonstrations of Synta's abilities are being able to make hugely enjoyable short-f/l achros for visual work and world-class quality MCTs.
Does Synta make EDs and triplets?
Shane in gray-zone NM
saemark30
Reged: 02/21/12
Re: Which 6" Achro to get??? new [Re: hottr6]
      #5736533 - 03/16/13 03:41 PM
Hardly.
Synta has quite a journey in increasing quality from the early 102mm achromats which could not form a point star to high end APOs today that is indeed world class.
Given the price point of their achromats, some are good and some are dogs, just like any other mass produced item.
If you think their MAKS are world class then I dare you compare them to the TEC or AP MAKS and write a review.
hottr6
Reged: 06/28/09
      #5738263 - 03/17/13 09:37 AM
Given the price point of [Synta] achromats, some are good and some are dogs, just like any other mass produced item.
If you think [Synta] MAKS are world class then I dare you compare them to the TEC or AP MAKS and write a review.
Reading the reviews here at CN, I have found that most people are happy with their Synta achros, with poor quality ("dogs") being the exception rather than the rule.
I have also found that most people think highly of their Synta MCTs, and that they compare favorably with Rumak-Maks made in Russia. While maybe not at the pinnacle of TEC Maks, I'd say they still qualify as world-class.
aa6ww
Reged: 10/23/11
Loc: Sacramento, Calif.
      #5739710 - 03/17/13 09:49 PM Attachment (7 downloads)
the skywatcher does not have the XLT high transmission coatings on them. Otherwise they seem to be similar to the OMNI 150R.
I also have a Celestron Omni, 150R, and love the optics. I use it for comet hunting and also for wide field views of space. Im working on the Herschel 400 with only this scope and its been coming along beautifully.
The HUGE plus to this scope vs the ES-152 is that this scope tips the scale at 16 pounds fully loaded and can easily be supported by my Vixen GP-DX mount, and give me wider fields of view this the 750mm FL vs the longer FL on the ES 152. The ES-152 is substantially heavier and requires a much beefier mount!
The optics are rock solid razor sharp right out to the edges even with a 41 pan. I replaced my focuser with a W/O 10:1 Crayford I had but never had a home for. Its an excellent refractor up to about 120x or so,
Of all the scopes i own, this one absolutely gets use the most.
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5628163/page...
...Ralph
13 registered and 36 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
