daveyfitz
Reged: 01/02/13
Loc: Utah
Quick -n- easy Scope Buggy new
      #5719034 - 03/07/13 06:41 PM Attachment (52 downloads)
I threw this together this afternoon, to shuttle my 12" Dob around the driveway/garage.
It's pretty low profile, with some small casters I had sitting around, so pavement only. I think it could easily be used with some bigger "offroad" casters to get around on dirt/grass.
I drilled holes for the (4) feet to sit in, which helps secure it in position.
daveyfitz
Reged: 01/02/13
Loc: Utah
Re: Quick -n- easy Scope Buggy new [Re: daveyfitz]
      #5719041 - 03/07/13 06:42 PM Attachment (38 downloads)
You will notice I made a square groundboard for the base, to keep the original out of the ground moisture, so the dolly is built to that dimension. The ground board has the 3 original feet, + 1 adjustable foot.
It's very easy to install, I just use the base handle to lift one side of the base a couple of inches, slide the board onto the feet, and set it down.
Same process other side, and the scope is mobile.
I've rolled it around, over some cement cracks, etc. and it's actually very stable.
amicus sidera
Reged: 10/14/11
Loc: East of the Sun, West of the M...
      #5719139 - 03/07/13 07:27 PM
Reminds me of a pair of depressed-center railroad flatcars! Very good idea and execution.
You could also attach small skis, or perhaps youth-size snowboards, to the bottom of each unit as needed for use where even large wheels would prove problematic (snow, tall grass, etc.).
Unknownastron
Reged: 04/06/05
Loc: CatsEye Observatory,Rural Sout...
Re: Quick -n- easy Scope Buggy new [Re: amicus sidera]
      #5719451 - 03/07/13 09:50 PM
My dad worked for the Railroad all the time I was growing up so I was steeped in railroad terminology. The word for depressed-center flatcar was wellcar. Just another useless fact!
Clear skies and clean glass,
daveyfitz
Reged: 01/02/13
Loc: Utah
      #5732573 - 03/14/13 05:07 PM Attachment (19 downloads)
Well, I picked up a set of 6" casters on ebay for $20, and got my buggy "off road ready".
It handles very well now, going from the driveway to the grass, and across the lawn. I think it will handle rough enough terrain for my purposes.
(although, I was sorely tempted by the $50 set of 8" casters, next post)
daveyfitz
Reged: 01/02/13
Loc: Utah
      #5732581 - 03/14/13 05:10 PM Attachment (15 downloads)
As you can see, I added a cross brace and handle, to make it easier to steer. It detaches with 2 wing nuts, so the whole contraption is easy to break down and carry.
Oh, here are the 8" wheels, which I decided were overkill, just too big and heavy.
But would it not be the awesomest buggy with those bad boys?
RossSackett
Reged: 08/17/07
Loc: Memphis, TN
      #5732600 - 03/14/13 05:22 PM
Bigger wheels are better on the bumps. Really big wheels will get you across the lawn.
Pinbout
Reged: 02/22/10
Loc: nj
Re: Quick -n- easy Scope Buggy new [Re: RossSackett]
      #5732624 - 03/14/13 05:36 PM Attachment (17 downloads)
and a motor...well lets just say I like to fantasize.
Gene7
Reged: 06/10/10
Loc: Mid Ohio, USA
Re: Quick -n- easy Scope Buggy [Re: Pinbout]
      #5733148 - 03/14/13 10:27 PM
Two 12 to 16 inch bicycle wheels work best and are free, Gene
10 registered and 32 anonymous users are browsing this forum.
