psu_13
Reged: 05/30/10
CG-5 Keypad Problem
      #5733588 - 03/15/13 08:04 AM
I have a CG-5 that's a couple of years old that I only use occasionally now since I got a newer and shinier mount.
Anyway, I set it up last night to do some quick comet hunting and to my chagrin I can't make the Enter key on the keypad respond to presses. I assume this sort of thing must have happened to others. Short of just replacing the keypad what's the easiest thing to try to fix this?
The mount has been stored in the garage for the last year so it's always cold, and it gets used once every few months at the most. So I guess I should remember to exercise the keypad once in a while in the future.
DaveJ
Reged: 01/07/05
Loc: NE Ohio
Re: CG-5 Keypad Problem new [Re: psu_13]
      #5734097 - 03/15/13 12:59 PM
This kit from Scopestuff worked wonders on several of my Meade Autostar controllers. Should do the trick, if you're comfortable taking your controller apart to do the repair.
FaronD
Reged: 03/25/10
Loc: Richmond Hill, Ontario
      #5734127 - 03/15/13 01:15 PM
I had the same issue years ago with my Meade HC. I used a product similar to what Dave mentioned and it was better than ever afterwards. It replaces the graphite contacts on the rubber keys. It's very simple to do. You can also try building up a layer with a pencil but it isn't nearly as effective. Check your local electronics store, you may find something similar for less.
Faron
33 registered and 30 anonymous users are browsing this forum.
