Privacy Policy |
Please read our Terms
of Service | Signup and
JimP
Reged: 04/22/03
Loc: South Carolina
Paracorr II setting for lunar imaging?
#5738872 - 03/17/13 03:16 PM
What setting do you recommend using on a Paracorr II for Lunar imaging with a Skynyx camera and the following setup? 20" F/3.3 Lockwood/Starmaster with 5x powermate only. No eyepiece. The Paracorr II would give an additional desireable 1.15x magnification (like an additional 1.15x Barlow).
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: Paracorr II setting for lunar imaging?
[Re: JimP]
#5739415 - 03/17/13 06:59 PM
From the TeleVue site: FOR IMAGING APPLICATIONS 1) Back off set screw under flange (D) so you can unscrew lens assembly. 2) For use with DSLR cameras (APS size chips recommended, as full-size chips will show vignetting). Tele Vue Canon Wide-T Adapter CWT-2070, or Standard T-Ring Adapter TRG-1072 attaches directly to the Paracorr Type-2 flange. 3) For CCD cameras, use Tele Vue Imaging System accessory tubes with Tele Vue camera adapters, or A2A-1107 adapter for cameras with 2" nosepieces. Best back focus is approximately 55mm from flange face.
So you don't use the tunable top--you can't get the chip to the optimum 55mm distance using it unless the chip is right at the very front of the camera, which is unlikely.
22 registered and 25 anonymous users are browsing this forum.
Moderator: ausastronomer, Scott in NC, iceblaze
