Equipment Discussions >> Electronically Assisted Astronomy
maroubra_boy
Vendor - Gondwana Telescopes
Reged: 09/08/09
Loc: Sydney, Australia
Removing built-in Barlow from focuser?? new
      #5732790 - 03/14/13 07:21 PM
Hi all,
I'm considering getting a short tube reflector, but the one in question has one of these blasted barlow lenses built into the focuser. As it is the f/ratio is 7.7, giving an effective focal length of 1000mm. I'm suspecting a spherical mirror, but as this scope will be used for video, could focusing still be a problem at f/3.85 on the small area that is the GSTAR-EX chip (very similar to the Mallincam Jr)?
Alex.
maroubra_boy
Reged: 09/08/09
Re: Removing built-in Barlow from focuser?? new [Re: maroubra_boy]
      #5732808 - 03/14/13 07:37 PM
I should note that I have a Celestron FirstScope, being f/3.9, very similar to the scope I'm looking at. It has a spherical mirror, and other than a imperfect final figure, it does give a very nice image at low power using half decent eyepieces, such as a 25mm plossl.
From this I know that a spherical mirror does work with the human eye (at low power), but how would this be with the chip of a video camera considering it is not as adaptive as a human eye?
jgraham
Reged: 12/02/04
Loc: Miami Valley Astronomical Soci...
      #5733142 - 03/14/13 10:22 PM
Unfortunately, that's not just a Barlow, it's also a corrector lens. The mirror in these short tube Bird-Jones Newtonians is spherical and won't work without the corrector lens in place.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Removing built-in Barlow from focuser?? new [Re: jgraham]
      #5733209 - 03/14/13 11:04 PM
A spherical mirror at low power doesn't seem so bad only because of the small image scale. A video camera has a field of view about equivalent to a 6mm eyepiece... See how visually obvious the spherical aberration is with such an eyepiece installed! Your video camera, even though it hasn't near the eye's resolving power, will readily enough show such SA.
maroubra_boy
Reged: 09/08/09
      #5733221 - 03/14/13 11:13 PM
Thanks John.
After reading your reply I've been reading up on this Bird-Jones design. The old Tasco is such a scope with the corrector lens sitting between the primary & secondary. This scope shows when done correctly it works very well.
Thing is, this scope has this lens placed in the focuser tube, so it's not a true Bird-Jones design. How annoying!
When you say "it won't work", what do you mean? Focus it should, despite the spherical shape. The actual focal point would be well outside the travel (in or out) of the focuser?
I just want to really understand the situation of how & why
Alex.
maroubra_boy
Reged: 09/08/09
      #5733224 - 03/14/13 11:15 PM
Ahh, thanks Glenn.
I saw your reply only after I posted mine.
ccs_hello
Reged: 07/03/04
      #5734561 - 03/15/13 05:39 PM
Flex the OTA mirror to get a better result:
http://www.cloudynights.com/documents/convert2.pdf
More on Bird-Jones (properly corrected ones) vs fake (Barlwo only) cheapies: CN linkie.
maroubra_boy
Reged: 09/08/09
Re: Removing built-in Barlow from focuser?? new [Re: ccs_hello]
      #5740110 - 03/18/13 05:10 AM
Fixe the OTA to get a better result:
What a fantastic link, the first one!!! Just the sort of thing that also appeals to me to undertake, Thanks so much for that CCS.
I reread one of my earlier posts, an I noticed that I had omitted the model of Tasco reflector I was talking about, the 8V - that is a true Bird-Jones reflector.
Dragon Man
Reged: 03/07/06
Loc: Snake Valley, Australia
Re: Removing built-in Barlow from focuser?? [Re: maroubra_boy]
      #5740386 - 03/18/13 10:14 AM
G'day Alex,
I hope you get it sorted.
Sorry I haven't been able to help much via email, but there are a few people in here that will steer you right
3 registered and 9 anonymous users are browsing this forum.
Moderator:  droid, David Pavlich, JayinUT
