Wmacky
Reged: 11/24/07
Loc: Florida
Aligning my CGE new
      #5737282 - 03/16/13 09:07 PM
OK, I'm sitting here in my new warm room trying to do the first polar alignment for the new observatory, and I'm already dumbfounded.
Just how far off should my first alignment star be? I believe the scope to be pretty close to polar alignment. Using a star atlas I have offset my finder scope cross hairs the correct amount from Polaris. When the scope slews to where it thinks Sirius should be (first alignment star, it is in fact pointing at Saiph in Orion?
WTH? I know it may be a little off but 15 moon diameters? I've double checked all my settings 20 times?
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: Aligning my CGE new [Re: Wmacky]
      #5737298 - 03/16/13 09:11 PM
Time zone?
Wmacky
Reged: 11/24/07
Loc: Florida
Re: Aligning my CGE new [Re: jrcrilly]
      #5737307 - 03/16/13 09:13 PM
Time zone is set correct - Eastern
Wmacky
Reged: 11/24/07
Loc: Florida
      #5737455 - 03/16/13 10:05 PM
Will shoot, I thought this was going to be a tough one.
Anyone know how to restore to factory defaults on the CGE classic?
Don't know what else to try at this point.
Time is right
Date is right.
Even manually enter the correct Long/ Lat instead of the city list!
Daylight savings time
Time zone is correct
Polaris appears offset correctly
Whats left?
Edited by Wmacky (03/16/13 10:07 PM)
David PavlichAdministrator
Transmographied
Reged: 05/18/05
Loc: Mandeville, LA USA
      #5737479 - 03/16/13 10:20 PM
I don't remember exactly where it's at, but drill down through the menu and do the default setting. That generally cures the problem you're having.
David
Wmacky
Reged: 11/24/07
Loc: Florida
Re: Aligning my CGE new [Re: David Pavlich]
      #5737492 - 03/16/13 10:25 PM
Yep, That did it. Thanks David.
Let this be a lesson to others that get a bad 1st alignment star. There are settings in the scope other than the usual Start up setting that can wack your alignment.
OK, that only put me 3 hours behind so far tonight. Gotta love modern amateur astronomy!
Edited by Wmacky (03/16/13 10:34 PM)
jbalsam
Reged: 07/06/12
Loc: Darnestown, MD
Re: Aligning my CGE [Re: Wmacky]
      #5740473 - 03/18/13 11:05 AM
Glad you got it solved. I had a similar problem with my CGE when I got started with it, but it turned out to be a power supply with too low of a current rating.
11 registered and 33 anonymous users are browsing this forum.
