coutleef
Reged: 02/21/08
Loc: Saint-Donat, Québec, Canada
Telrad riser new
      #5736594 - 03/16/13 04:27 PM
A simple question: which telrad riser to buy, the 2 or 4 inch riser?
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
Re: Telrad riser new [Re: coutleef]
      #5736626 - 03/16/13 04:44 PM
I have the 2"; and am happy with it, on my 16" dob.
coutleef
Reged: 02/21/08
Re: Telrad riser new [Re: csa/montana]
      #5736662 - 03/16/13 05:09 PM
Thanks Carol,
That is what i thougth but wanted someone with experience with the device to comment.
Thanks for your precious help
SteveG
Reged: 09/27/06
Loc: Seattle, WA
      #5736682 - 03/16/13 05:20 PM
2" for me as well - 10" dob.
Edited by SteveG (03/16/13 05:21 PM)
Scott in NC
Mad Hatter
Reged: 03/05/05
Loc: NC
Re: Telrad riser new [Re: SteveG]
      #5736708 - 03/16/13 05:34 PM
I bought a 4" riser for my 12" dob, and I'm very happy with it. But a 2" riser probably would have done the job just as well. I just happened to find a used 4" one for sale, and the price was right!
csa/montana
Den Mama
Reged: 05/14/05
Loc: montana
      #5736715 - 03/16/13 05:38 PM
I know you will be very happy using a riser with the Telrad; much more comfortable! Let us know how you like it!
Gary Riley
Reged: 12/01/11
Loc: White Bluff, TN
      #5736805 - 03/16/13 06:14 PM
I have the 4 inch riser on my Z12 dob and really like not having to bend so low to look thru it.
beatlejuice
Reged: 04/05/11
Loc: Hamilton, ON,Canada
      #5736921 - 03/16/13 07:02 PM
I have the 4" and it maximizes my relief from neck or back strain. Just make sure that you mount it Focuser-Finder-Riser otherwise you could have trouble accessing the finder eyepiece.
Eric
demiles
Reged: 11/07/06
Re: Telrad riser new [Re: beatlejuice]
      #5737062 - 03/16/13 08:00 PM
I have the 4in but wish they made a 6
JayinUT
I'm not Sleepy
Reged: 09/19/08
Loc: Utah
Re: Telrad riser new [Re: demiles]
      #5737497 - 03/16/13 10:29 PM
I use the 4 inch on my scopes.
Edit: One thing I did to my riser because I had one break once, was to use epoxy glue to reinforce where each of the stands connect to the bottom plate. . I have no worries now of one of them breaking like before. .
Edited by JayinUT (03/17/13 01:24 AM)
beatlejuice
Reged: 04/05/11
      #5737839 - 03/17/13 12:49 AM
You can stack a 2 inch on top of a 4 inch
Eric
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
      #5737936 - 03/17/13 02:23 AM
Eric
World's most expensive Telrad!
demiles
Reged: 11/07/06
Re: Telrad riser new [Re: johnnyha]
      #5738138 - 03/17/13 08:11 AM
You're right! It's worth a try.
coutleef
Reged: 02/21/08
      #5738207 - 03/17/13 08:57 AM
That becomes a difficult choice now
Spaced
Reged: 03/01/05
Loc: Tacoma, Washington, USA
      #5739577 - 03/17/13 08:25 PM
This is too cool! I was about to post the exact same question. Perfect timing!
stratocaster
Reged: 10/27/11
Re: Telrad riser new [Re: Spaced]
      #5740015 - 03/18/13 02:44 AM
I have a 10" dob. I originally purchased a 4". I thought it put the telrad too far away from the eyepiece - I would have to adjust my chair to look thru the telrad, then lower my chair to look comfortably thru the eyepiece. I sold the 4" riser and purchased a 2". I like the 2" much better.
coutleef
Reged: 02/21/08
Re: Telrad riser new [Re: stratocaster]
      #5740181 - 03/18/13 07:37 AM
Thanks a lot since that may be my situation, i will go for the 2 inch riser
Bob Griffiths
Getting Grouchy
Reged: 10/10/05
Loc: Frederick Maryland
      #5740322 - 03/18/13 09:40 AM
Francois...
I actually purchased BOTH..ended up using the 4 inch on my 8i and stuck the 2 inch raiser on my 4 inch refractor..
Time to get yourself out of the lab and spend some of your hardly earned money... Doctor !!! LOL
Bob G
Sarkikos
Reged: 12/18/07
Loc: Suburban Maryland, USA
Re: Telrad riser [Re: Bob Griffiths]
      #5741965 - 03/18/13 10:36 PM
I also bought and tried both sizes on my 10" f/4.8 Dob. The 4" was more comfortable for me. I have a 70mm finder between the focuser and the Telrad. The 4" riser means I don't have to lean over so much to sight through the Telrad.
I sold the 2" riser, I believe to someone else in this thread.
1 registered and 7 anonymous users are browsing this forum.
Moderator:  Jarad, tecmage
