tclehman1969
Reged: 05/18/10
Loc: SF Bay Area, California
Advice Requested -- What type mount to get
      #5744335 - 03/20/13 01:39 AM
Good evening all!
I have currently a Super C8 Plus stil in its original fork. I want to get into astro photography pretty extensively and the current mount just seems to have a bit of a jiggle that I think is in part due to its mount. Even a very slight breeze can ge the scope bouncing noticeable in an eyiece and in photos that would be devastating. So, I am looking at taking the plunge to a German equatorial mount, but there are a lot of manufacturers out there and I have questions, too. So, here we go!
Equipment I have is a C8 with a 8x50 finder. For photography I often go piggyback with wide field lenses up to my Celestron Onyx 80mm mounted in rings. The camera I use is a DSLR. Max equipment load from this I would guess would be about 30 lbs. so a mount that can support at least 30 lbs would be good.
I don't observe from a fixed location, so portability is a requirement. I like to get my current scope up to the mountains whenever possible, and it can be a bit bulky, but doable.
Auto guiding options. I know Orion has a system, but looks like it requires a laptop to drive it. Is there an option that is standalone? In other words, "talks" to the mount directly? I saw the Celestron guider which does this, but does it work with mounts from other manufacturers?
My initial uneducated instincts tell me either the Orion Atlas EQ-G or the Celestron CGEM could be the way to go. But, from what I have read so far, the Orion mount wins for the drive, but Celestron wins for guiding.
Anybody have any thoughts on this?
Mike X.
Reged: 06/28/10
Loc: Greece-Athens and Rome-Italy
Re: Advice Requested -- What type mount to get new [Re: tclehman1969]
      #5744496 - 03/20/13 04:35 AM
Hello tclehman,
I don't know about guiding and CGEM.I mean if it actually wins or not over Atlas.
most probably the two mounts are virtually equivalent.
I guess till Celestron comes out with a fix for the cogging issue reported by many users on the CGEM..the Orion option, at least psycologically is the safest one.
Edited by Mike X. (03/20/13 04:37 AM)
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Advice Requested -- What type mount to get new [Re: Mike X.]
      #5744542 - 03/20/13 06:23 AM
the Atlas also doesn't have the 8/3 gearbox harmonic of the CGEM.
RogerRZ
Whatta you lookin' at?
Reged: 01/09/06
Loc: West Collette, NB, Canada
Re: Advice Requested -- What type mount to get new [Re: orlyandico]
      #5744551 - 03/20/13 06:43 AM
It also works very well with eqmod, if you don't mind being tethered to a PC...
tclehman1969
Reged: 05/18/10
      #5744762 - 03/20/13 09:49 AM
Forgive me, 8/3 harmonics?
tclehman1969
Reged: 05/18/10
Re: Advice Requested -- What type mount to get new [Re: RogerRZ]
      #5744777 - 03/20/13 09:56 AM
I read about EQMod, but when out in the field, I don't want to be tethered to a laptop. Looks like Celestron has a guider that runs without a laptop, curious if there are others that can, too. And if there are, what mounts will they work on?
Mkofski
Reged: 07/19/11
Loc: Greenfield, Indiana, USA
      #5744784 - 03/20/13 10:01 AM
If portability is a requirement you May want to look at the ioptron's iEQ45 or maybe the 30.
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
      #5744788 - 03/20/13 10:03 AM
There are others currently available (SBIG SG-4 is an example), and quite a few available only second hand (Meade 201XT, 208XT, 216XT, SBIG ST-4, STV). All are compatible with any mount having an autoguide port. That includes most available mounts.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Advice Requested -- What type mount to get new [Re: jrcrilly]
      #5744792 - 03/20/13 10:06 AM
the celestron nexguide can't do subpixel guiding though. you need an SBIG SG-4, Lacerta MGEN, or similar.
the 8/3 harmonic is an irrational (8/3 = 2.66666667) periodic error that can't be removed by periodic error correction.
Reged: 04/30/03
Loc: NE Ohio
      #5744797 - 03/20/13 10:11 AM
That's an important issue if guiding with a separate guidescope of short focal length. It's not, if using an off-axis guider. Personally, I wouldn't consider imaging through an SCT without an OAG for many reasons.
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5744811 - 03/20/13 10:22 AM
John, i know someone with a nexguide and OAG. the sensitivity of the chip is poor, it has trouble getting guide stars. with a CGEM or EQ6 class mount it might not be possible to use 4+ second guide exposures.
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
      #5744853 - 03/20/13 10:49 AM
Losmandy G11 works well for me. Transportable, stable, good tracking.
Ed
Reged: 04/30/03
Loc: NE Ohio
      #5744892 - 03/20/13 11:11 AM
That would be a real problem with an OAG!
Wmacky
Reged: 11/24/07
Loc: Florida
      #5744927 - 03/20/13 11:33 AM
My advice?
For astrophotography, I would recommend the Atlas EQ6. If your looking for better, and have more funds, the next mount you should consider is the AP Mach One. That's a big jump, but my current thinking eliminates all Mid range mounts as viable options. Anything more expensive than the EQ6 is to much risk unless getting AP quality.
Therefore -
Start with a EQ-6
Then
Start saving for a Mach One!
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Advice Requested -- What type mount to get new [Re: Wmacky]
      #5745039 - 03/20/13 12:22 PM
+1 ^
I could have saved a lot of cash if I had followed the above advice.
There is a bit of upgrading you can do to an EQ6 - buy an Aeroquest worm for it, or if you are feeling flush, buy a matched Aeroquest worm and ring gear for the RA. Still under $500 additional.
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
      #5745058 - 03/20/13 12:33 PM
Why does your ota weigh so much?
I'd go cheap. Get a focal reducer for you OTA. Get a orion mini autoguider package (doesn't weigh much at all) and get the Celestron advanced VX mount.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: Advice Requested -- What type mount to get new [Re: Whichwayisnorth]
      #5745941 - 03/20/13 06:50 PM
Here is what a Hypertuned Atlas can do.
shams42
Reged: 01/05/09
Loc: Kingsport, TN
Re: Advice Requested -- What type mount to get new [Re: Lane]
      #5746408 - 03/20/13 10:06 PM
Good advice but I would also add the Takahashi EM-200 or NJP if you can find either of those used. They are equal to the Mach 1 in quality, with the EM-200 having less capacity and the NJP having substantially more.
So yeah, I totally agree that your options are:
1) Atlas
or
2) Mach 1 / EM-200 / NJP
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: Advice Requested -- What type mount to get new [Re: shams42]
      #5746444 - 03/20/13 10:16 PM
+1 G11.
andysea
Reged: 09/03/10
Loc: Seattle, WA
      #5746467 - 03/20/13 10:24 PM
I can't say bad things about my NJP, however it seems that Takahashi mounts are a little outdated when compared to what the more modern mounts can do. Of course there is something to be said about the simplicity and top notch craftsmanship of Takahashi products.
6 registered and 34 anonymous users are browsing this forum.
