bm_too
Reged: 05/08/09
Loc: Ontario,Canada
Re: PiAstroHub: RaspberryPi for Autoguiding+DSLR+GOTO [Re: anat]
      #5745332 - 03/20/13 03:00 PM
Interesting project. I am not much of a web programmer, do you have your webinterface control code posted somewhere ?
Barry
patdut63fromFr
Reged: 07/31/07
Loc: France
Re: PiAstroHub: RaspberryPi for Autoguiding+DSLR+GOTO new [Re: bm_too]
      #5754085 - 03/24/13 02:01 PM
Hello Anat and everybody,
I am very interested in this project and follow for 3weeks.
I just ordered a raspberry pi.
I'd like to know if it is possible to connect a DMK cam on the raspberry pi. Would there be any power issue with the cam ?
kind regards
Pat
anat
Reged: 06/03/04
Re: PiAstroHub: RaspberryPi for Autoguiding+DSLR+GOTO new [Re: patdut63fromFr]
      #5774703 - 04/03/13 04:39 AM
Hello,
I will release the codes soon after some tests from beta testers. Recently, I use the MK808 dual core Android TV stick for this project because it is much faster, smaller and cheaper overall. I am not sure about DMK cameras. To use it for autoguiding, you may need to look at GoQat which supports the camera.
http://canburytech.net/GoQat/index.html
I successfully compiled GoQat on Raspberry Pi some time ago.
Best regards,
Anat
Edited by anat (04/03/13 04:41 AM)
ccs_hello
Reged: 07/03/04
Re: PiAstroHub: RaspberryPi for Autoguiding+DSLR+GOTO new [Re: anat]
      #5778245 - 04/04/13 06:08 PM
Anat,
Are you running MK808 on Linux or Android?
I am assuming for this project, you are fork-lifting the whole thing to make it Linux for easier to support??
BTW, if it ends up to be not the optimal solution, one can always change it back to XBMC video player .
On that front, will RaspberryPi or MK808 be a better dual-use solution?
Clear Skies!
ccs_hello
patdut63fromFr
Reged: 07/31/07
Loc: France
Re: PiAstroHub: RaspberryPi for Autoguiding+DSLR+GOTO new [Re: ccs_hello]
      #5779612 - 04/05/13 01:05 PM
Hello all,
I have tested my all new raspberrypi to drive my orion atlas mount using skysafari. It works very fine. But the 2 usb ports are occupied one by the usb wifi dongle the other by the Raspberry which handle the mount. To answer a question I have seen somewhere: the handle is needed to make it works.
So there is no other room to connect a cam.
The amount of the installation to drive an Orion Atlas mount is as follow:
raspberry B 42
box for rpi 10
wifi dongle 10
usb/RS232 14
for a total of 76 (100$) which is the half price of the skyfi orion device (in Europe).
Unfortunately I have read somewhere that the usb inteface is unique and the 2 plugs share the same interface. So there is nothing to wait in term of performance. But maybe it is sufficient for autoguiding.
Anat you are true, the MK808 looks to be a better alternative, wifi, bluetooth are included in device. But unfortunately there is only one usb plug. It would have been fun to make acquisition with the same device as the one that autoguide and drive the mount. But it seems not to be done even with the MK808.
patdut63fromFr
Reged: 07/31/07
Loc: France
      #5779616 - 04/05/13 01:08 PM
Anat, I have a question for you, what you done to successfully compile GoQat on the raspberry.
Thanks for your answer.
ccs_hello
Reged: 07/03/04
      #5781266 - 04/06/13 08:27 AM
Ouch, that MK808 has so many cousins:
http://dl.miniand.com/tecknight/RK3066Devices.html
Buying the right type (for picuntu) would be quite a challenge.
Clear Skies!
ccs_hello
ccs_hello
Reged: 07/03/04
      #5781790 - 04/06/13 12:38 PM
808's little brother info MK802
http://en.wikipedia.org/wiki/Android_Mini_PC_MK802
Anyway, $40-ish price tag (808 cloned version) for a 1.5GHz A9 quad core, 1GB RAM, 8GB NAND flash, HDMI out, USB, USB OTG, WiFi, and Bluetooth all included is not bad. Not bad at all.
Clear Skies!
ccs_hello
anat
Reged: 06/03/04
      #5787294 - 04/09/13 02:34 AM
Anat,
Clear Skies!
ccs_hello
Yes. I run Ubuntu (PreAlpha 0.3) on MK808. It is very stable. MK808 is a better solution.
anat
Reged: 06/03/04
      #5787297 - 04/09/13 02:37 AM
Clear Skies!
ccs_hello
The best RK3066 module in my opinion is the original MK808 with the RK901 wifi chip. The wifi chip works in linux for client, access point, and adhoc modes. I got several MK808 sticks from
http://www.geekbuying.com/item/MK808-Dual-Core-Android-4-1-Jelly-Bean-TV-BOX-...
It is the right one.
anat
Reged: 06/03/04
      #5787299 - 04/09/13 02:42 AM
Hello all,
raspberry B 42
box for rpi 10
wifi dongle 10
usb/RS232 14
Congrats for the Skyfi setup !
Both Raspberry Pi and MK808 works with a powered usb hub. In my setup I use:
QHY6 for autoguiding
QHY8L or DSLR for image capturing
USB-serial adapter for mount control
USB sound adapter
connected to a hub without any problem.
anat
Reged: 06/03/04
      #5787302 - 04/09/13 02:45 AM
These are steps to compile GoQat:
sudo apt-get install gawk
sudo apt-get install libgtk2.0-dev
sudo apt-get install libgoocanvas-dev
sudo apt-get install libxpa-dev
sudo apt-get install saods9
sudo apt-get install grace
sudo apt-get install libunicap2-dev
sudo apt-get install autoconf
>>> Install GoQat
tar -xvf goqat-0.9.8.tar.gz
cd goqat-0.9.8
./configure
make
sudo make install
anat
Reged: 06/03/04
      #5789596 - 04/10/13 04:16 AM
I am ready to release the source codes. Thank all testers and developers for your support.
https://sourceforge.net/projects/iastrohub/
Now a tablet can control the autoguider, CCD, DSLR, and mount via a tiny hub I recommend MK808 (original with RK901 Wifi chip).
Best regards,
Anat
pfile
Reged: 06/14/09
      #5875002 - 05/20/13 11:56 PM
so have you tried openPHD again? it seems like they have made a lot of progress recently.
anat
Reged: 06/03/04
Re: PiAstroHub: RaspberryPi for Autoguiding+DSLR+GOTO new [Re: pfile]
      #5875159 - 05/21/13 05:14 AM
I have never tried openPHD after using Linguider. Linguider is super fast on Arm devices.
pfile
Reged: 06/14/09
      #5876876 - 05/21/13 08:29 PM
i'll check it out. just browsing thru the files you've uploaded, it seems like mount control is done thru CdC with the INDI interface, is that correct?
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
Re: PiAstroHub: RaspberryPi for Autoguiding+DSLR+GOTO [Re: pfile]
      #5881903 - 05/24/13 10:07 AM
Can it control an SBIG camera?
pfile
Reged: 06/14/09
Re: PiAstroHub: RaspberryPi for Autoguiding+DSLR+GOTO [Re: Raginar]
      #5882328 - 05/24/13 01:28 PM
i have been looking into this - i don't think so. however, hacking in sbig http support might be "easy", but that only works on STT and STX cameras.
i think the main problem is that INDI is way behind ascom. maybe these little single-board computers will change that though.
Raginar
Reged: 10/19/10
Loc: Rapid CIty, SD
      #5883760 - 05/25/13 10:48 AM
Darn. I'm sure hacking in an HTTP server wouldn't be too bad. I just find SBIG's lack of an ASCOM driver to be a real PITA.
pfile
Reged: 06/14/09
      #5884503 - 05/25/13 06:36 PM
well, it's easier because it's an http client. it could probably be done with a perl script, actually.
and libcurl is really good for getting http support into a program... like phd.
what does an ascom driver buy you for a camera? meaning, are there camera control packages out there that only interface with ascom-compatible cameras?
5 registered and 6 anonymous users are browsing this forum.
Moderator:  richard7, kkokkolis
