Rumbleripper
Reged: 02/09/13
Best Wedge for CPC Deluxe HD 925 new
      #5726705 - 03/11/13 07:47 PM
Hi Everyone:
Just recently acquired a CPC HD 925 and am looking to get a wedge for the scope. I have read there are a few aftermarket companies that make very good although pricey wedges. Also read that Celestron's previous HD wedge was not very good. However their new wedge from what I gather seems to be better and is less money than the aftermarket ones.
My question is, is the new Celestron HD wedge as good as the others or is it worth spending a little more for the other brands, and if so which of the aftermarket wedges is the best/easiest to use?
Thanks.
Rumble
dragonslayer1
Reged: 02/25/12
Loc: SLC, UT
Re: Best Wedge for CPC Deluxe HD 925 new [Re: Rumbleripper]
      #5727011 - 03/11/13 10:21 PM
I have a CPC 9.25 that I put on the Celestron HD. wedge last year and really like it. I have not tried any other but can only attest to the Celes one and really like it. It is built like a tank as they say
Kasey
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Re: Best Wedge for CPC Deluxe HD 925 new [Re: dragonslayer1]
      #5727152 - 03/11/13 11:43 PM
Someone a while back said they put the heavy in the duty when Celestron built it and they weren't kidding. I get spot on polar alignments with mine.
1965healy
The Snarkster
Reged: 06/23/07
Loc: San Antonio, TX
Re: Best Wedge for CPC Deluxe HD 925 new [Re: CharlesW]
      #5727358 - 03/12/13 02:30 AM
I have the APT wedge on a steel pier for my CPC800 and highly recommend it. Rock solid and simple to use.
Rumbleripper
Reged: 02/09/13
Re: Best Wedge for CPC Deluxe HD 925 new [Re: 1965healy]
      #5727986 - 03/12/13 11:57 AM
Thanks everyone.
Seems like the new Celestron wedge is good enough here, and the cost a bit better then the aftermarket ones. I will probably be ordering one in the next few weeks and report back.
Thanks again.
Rumble
telescopemullet
Reged: 11/16/09
      #5730691 - 03/13/13 04:54 PM
I have a cpc 1100 on the new wedge. It is solid but there is a need for dampening time. If going visual, get an electronic focuser, even the slightest touch and the scope bounces a little.
I have had the scope on the wedge for many, many months now, I hibernate it after every use, to this day, the gotos are spot on in 10mm eyepiece.
Rumbleripper
Reged: 02/09/13
Re: Best Wedge for CPC Deluxe HD 925 new [Re: telescopemullet]
      #5731103 - 03/13/13 08:52 PM
Hey Telescopemullet:
Do you think the dampening is due to the wedge?
Would any of the other wedges have this issue?
Thanks.
Rumbleripper
Reged: 02/09/13
      #5731113 - 03/13/13 08:57 PM
Hi Karen:
Where did you get your APT wedge? Does it need time to settle down after focusing?
Thanks.
1965healy
The Snarkster
Reged: 06/23/07
      #5731349 - 03/13/13 11:20 PM
Ordered it from APT Astro. It's permanently mounted on a steel pier in my observatory. It's really a beast, I would think that there really wouldn't be any issues with it in terms of thermal stability or movement due to "settling". I can tap on it while observing/imaging w/o issues.
1965healy
The Snarkster
Reged: 06/23/07
      #5731360 - 03/13/13 11:24 PM
It seems they are out of business, their link goes to somewhere in the orient.
telescopemullet
Reged: 11/16/09
      #5731454 - 03/14/13 12:25 AM
It is 100% due to the wedge.
Rumbleripper
Reged: 02/09/13
      #5734649 - 03/15/13 06:30 PM
Thanks again everyone. May look at the Mitty wedge as it is the only aftermarket one easily available.
Rumble
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #5734697 - 03/15/13 06:58 PM
I had a Mitty Proline wedge for my old CPC0800 and it was an AWESOME wedge. It weighs a whopping 35lbs and built like a tank.
http://www.optcorp.com/mitty-proline-wedge-for-celestron-cpc-telescopes.html
See images of my old CPC0800 equipment in "Peter's Galleries" in my signature and then click on "Old Equipment".
Peter
astrovienna
Reged: 12/04/06
Loc: The NoVa White Zone
Re: Best Wedge for CPC Deluxe HD 925 new [Re: Peter in Reno]
      #5741312 - 03/18/13 06:09 PM
I use a Milburn deluxe wedge, which is tank-heavy but works great. I got mine off Amart, but I think Ken still sells them.
Kevin
Rumbleripper
Reged: 02/09/13
Re: Best Wedge for CPC Deluxe HD 925 new [Re: astrovienna]
      #5744051 - 03/19/13 09:36 PM
Hi Everyone:
So I found an excellent deal on a new un used Celestron HD wedge so I made the purchase. Should have it within a week and will give my impressions when it arrives.
Thanks to all for your input.
Footbag
Reged: 04/13/09
Loc: Scranton, PA
      #5744743 - 03/20/13 09:32 AM
Hi Everyone:
Hopefully that's the newHD Pro wedge and not the HD wedge. The new version is very nice. I had absolutely no complaints. The old one was worthless for imaging.
Rumbleripper
Reged: 02/09/13
Re: Best Wedge for CPC Deluxe HD 925 [Re: Footbag]
      #5751278 - 03/23/13 07:33 AM
Hi Adam:
Yes it is the new version.
4 registered and 14 anonymous users are browsing this forum.
Moderator:  Brian Risley, panhard, Mitchell Duke, mayidunk
