Pages: 1 | 2 | 3 | (show all)
Hilmi
Reged: 03/07/10
Loc: Muscat, Sultanate of Oman
choosing my birthday gift! your ideas new
      #5754047 - 03/24/13 01:46 PM
I am buying myself a new scope to replace my Meade LX200r which heavily vignets once I add my Moonlite focuser and once I add my reducer it gives me only f8 even though the spacing is correct.
So I am now considering 1 of 2 scopes. With sale at OPT there is only $20 difference in price. To start with. Lets get one thing clear. I have no interest in Hyperstar, my camera is way too big and I am not planing to change cameras.
OPT version of AT8RC currently on 15% sale.
Pluses
10 inches back focus.
Natively f8
Ships internationally without any use if intermediatary
negatives
No reducer available
Distraction spike (I'm not really partial to diffraction spikes, the distract from the image)
Celestron 8" Edge HD
Pluses
Native reducer
Option to run at f10 if I want narrower field of view
negatives
Moving mirror
International shipping complications
Any advice would be appreciated. Especialy if you happen to have owned both.
Edited by Hilmi (03/24/13 02:00 PM)
Hilmi
Reged: 03/07/10
Re: choosing my birthday gift! your ideas new [Re: Hilmi]
      #5754057 - 03/24/13 01:50 PM
I'm also open to other scope suggestions, but due to the investment I made on the moonlite focuser, I am reluctant to go for a non casagrain design
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #5754156 - 03/24/13 02:26 PM
I haven't used either of them but those two are different enough -will look forward to hear what others think. My only thoughts are that if you don't like spikes (I know I don't) that just leaves the one, I'd say go for something I wanted to start with. The HD has mirror lock from what I'd read - is there still some shift with that?
Hilmi
Reged: 03/07/10
Re: choosing my birthday gift! your ideas new [Re: CounterWeight]
      #5754190 - 03/24/13 02:36 PM
The thing is, I'm under time restrictions to choose. The OPT branded AT8RC carbon fiber is on sale for a limited time.
If it helps, I am considering adding a rotator in the future to further improve my automation.
Hilmi
Reged: 03/07/10
      #5755362 - 03/25/13 01:17 AM
Will I get more responses in the cats and cases forum? I can ask the moderator to move the topic. Thought I would post it here since my primary use is imaging
Edited by Hilmi (03/25/13 02:44 AM)
guyroch
Vendor (BackyardEOS)
Reged: 01/22/08
Loc: Under the clouds!
      #5755388 - 03/25/13 01:42 AM
Pluses
Natively f8
negatives
The AT8RC certainly has an excellent FR/FF.
I use the Astro-Physics Telecompressor CCDT67 on both the AT6RC and AT8RC. It's a reducer but works darn well as a flatner too.
http://www.optcorp.com/astro-physics-ccd-telecompressor-for-f9-f18-telescopes...
I suggest you get the Astro-Physics Part #AP16T to pair with the CCDT67 to ensure you have the proper spacing.
http://www.optcorp.com/astro-physics-2inch-tapered-nosepiece-with-t2-threads....
Guylain
korborh
Reged: 01/29/11
      #5755389 - 03/25/13 01:44 AM
The RC8 is PITA to collimate. Having owned the AT8RC and the Edge (11), I would recommend the Edge8 scope. You can easily work around the moving mirror but beware the RC's finicky collimation.
guyroch
Reged: 01/22/08
Re: choosing my birthday gift! your ideas new [Re: korborh]
      #5755400 - 03/25/13 01:58 AM
Please do tell. I have no issues collimating my AT6RC and/or my AT8RC.
Guylain
Hilmi
Reged: 03/07/10
Re: choosing my birthday gift! your ideas new [Re: guyroch]
      #5755442 - 03/25/13 02:44 AM
Guylain,
From your experience does the scope work without a field flatner when working at f8? Also how tight are the stars? My LX200R almost always gave me bloated soft stars when compared to my televue 60is which gives sharp tight stars.
Korboh, about the collimation difficulty could you please elaborate?
Edited by Hilmi (03/25/13 02:47 AM)
korborh
Reged: 01/29/11
      #5755462 - 03/25/13 02:59 AM
If you are lucky to not need more than minor collimation adjustments then RC8 fine. But if you ever have to adjust the primary and go a bit too far off then the RC is very unforgiving. Especially these cheap RC scopes don't have good and repeatable mechanics. You will also have to invest in high-quality collimation tools (expensive ones). There are other design issues with RC8 that can potentially give you headaches like the primary connected to the focuser and resultant flexure issue.
In contrast EdgeHD is so much more robust and simple proven design. Great for imaging and visual. I dont see *any* advantage of RC8 over Edge8. The mirror of RC8 is *not* fixed as you will realize when you start seeing flexure in imaging.
Hilmi
Reged: 03/07/10
      #5755469 - 03/25/13 03:24 AM
What about back focus? That is the main reason I am moving away from the LX200R. Once my moonlight focuser is in there, I cant use the reducer since it vignets and it also brings the focal length to F8 instead of F6. The reason being that there is not enough back focus to accommodate the focuser and the reducer.
So I figured the real advantage of the AT8RC is that I can accomodate the moonlite focuser, the STT8300 with self guiding filter wheel and potentially a rotator in the future in order to aid in the process of finding guide stars. Since it is natively F8 I dont need the reducer any more.
How much back focus does the EdgeHD provide?
Hilmi
Mike7Mak
Reged: 12/07/11
Loc: New York
      #5755486 - 03/25/13 04:06 AM
I would suggest trying the above on the LX200R. It puts the reducer inside the Moonlight and closer to the visual back opening. I had vignetting problems with reducers mounted after the focuser but not with the CCDT67 inserted into the focuser on a 2" nosepiece.
Hilmi
Reged: 03/07/10
Re: choosing my birthday gift! your ideas new [Re: Mike7Mak]
      #5755492 - 03/25/13 04:19 AM
I feel like the LX200 has been a money black hole. One fix after another. I am reluctant to put anymore money into it. First it was the focuser then the microfocuser, then the mirror lock then the reducer needed an upgrade then now another reducer upgrade.
guyroch
Reged: 01/22/08
      #5755667 - 03/25/13 08:37 AM
Guylain,
You need a field flatner with the AT8RC. The AT2FF works well too.
Guylain
guyroch
Reged: 01/22/08
      #5755688 - 03/25/13 08:58 AM
Now that you mention it... my primary mirror is a tab bit off on the AT8RC... but the AT6RC is perfect. Instead of toying with the primary I decided to buy a tilt adjuster. I Haven't used it yet so I can't comment on it.
http://www.optcorp.com/teleskop-service-m48-tilt-adjuster.html
I'll have to change my statement now... my primary mirror is off and so collimation could be a pain
Guylain
Hilmi
Reged: 03/07/10
      #5755691 - 03/25/13 09:00 AM
What level of pain are we talking about here? Pain as in it takes 3 hours then it stays put for the next 6 months or pain as in every time you set up the scope you have lost collimation and have to spend an hour or two to get it back into alignment?
guyroch
Reged: 01/22/08
      #5755721 - 03/25/13 09:34 AM
For me it's "Pain as in it takes 3 hours then it stays put for the next 6 months"
Guylain
korborh
Reged: 01/29/11
      #5755916 - 03/25/13 11:07 AM
Hilmi, the Edge8 does not have a lot of backfocus to allow a separate crayford focuser. With the new upcoming reduccer, backfocus is even less. So if you really need an external focuser then Edge8 will be an issue. That being said, you can use the primary mirror knob for focusing and it works quite well for imaging (automated with Fmax). The RC8 has generous backfocus but you will have to limit the weight on the focuser tube otherwise its going to cause flexure and collimation issues. Hanging a moonlite +5lbs of imaging gear will not be possible without significant flexure and mechanical issues.
As for pain, I had to get mine professionally collimated after unsuccessfully working on it for a week (~12+hrs.). If you get the RC8 you may want to invest in high quality collimation tools like Howie laser and/or Tak collimation scope. These are very pricey accessories.
cherokawa
Reged: 10/19/08
Loc: Torrance, CA
      #5756313 - 03/25/13 02:39 PM
Just my 2 cents - you could also consider the Vixen VC200L. Fixed primary, 42mm image circle, f/6.4 reducer is available, collimation is not a major pain. I don't own one, but would like to, someday.
Downside - some people don't like the square stars caused by the thick secondary vanes. I think this effect is apparent only on bright stars, but not sure if this is important to you.
Hilmi
Reged: 03/07/10
Re: choosing my birthday gift! your ideas [Re: cherokawa]
      #5756344 - 03/25/13 02:55 PM
I like my stars nice, round and tight That's one of the other reasons I am trying to move away from my current scope. It gives me bloated stars, I don't have enough knowledge to know why. All I know is that my refractor gives me nice tight stars, but my refractor is only 360 mm focal length, so it's not a fair comparison.
12 registered and 9 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, fishonkevin, WOBentley, rflinn68
