maroubra_boy
Vendor - Gondwana Telescopes
Reged: 09/08/09
Loc: Sydney, Australia
CG-4 & EQ3, same mount? new
      #5752606 - 03/23/13 08:15 PM
Hi all,
Are the Celestron CG-4 & the EQ3 the same mount with a different name? I've got an EQ3 & want to put clock drive on it, & I've come across a dual axis set for a CG-4 at a good price. Any thoughts?
Alex.
joelimite
Reged: 09/01/08
Loc: Fayetteville, AR
Re: CG-4 & EQ3, same mount? new [Re: maroubra_boy]
      #5752961 - 03/23/13 11:17 PM
Don't quote me for certain, but my understanding is they are one and the same.
mdowns
Reged: 06/12/10
Loc: Englewood,FL
      #5752972 - 03/23/13 11:22 PM
Can you post a pic?
watcher
Reged: 11/21/07
Loc: St. Louis, MO
      #5757164 - 03/25/13 10:40 PM
They are indeed the very same mount. just a difference in the legs. The drives will work for either.
maroubra_boy
Reged: 09/08/09
Re: CG-4 & EQ3, same mount? [Re: watcher]
      #5757341 - 03/26/13 01:09 AM
Thanks for that folks. That's all I needed to read,
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #5765767 - 03/29/13 09:24 PM
Alas, the Celestron German mount #4 is everyone else's EQ-3. The CG-3 is, you guessed it, an EQ-2. And the CG-5 an EQ-4. Wonder what the CG-1 and 2 were?
Reged: 06/16/04
Re: CG-4 & EQ3, same mount? new [Re: watcher]
      #5765846 - 03/29/13 10:12 PM
I have never verified this but if I remember correctly, there were at least 2 versions of the EQ-3 mount and they required different drives.
I have an older EQ-3, its more than 10 years old, it's fitted with Celestron CG-4 drives. The stepper motor drives that are used with these mounts are slow and if there is any slop, they are frustratingly slow. I finally unhooked the Declination drive and replaced it with a slow motion cable.. must faster and more accurate.
If I were to do it over again, I would buy the single axis drive.
watcher
Reged: 11/21/07
Loc: St. Louis, MO
Re: CG-4 & EQ3, same mount? new [Re: Jon Isaacs]
      #5765853 - 03/29/13 10:25 PM
Single axis drive is definitely the way to go IMO.
Jon. Thanks for the info. Anybody know if this is a fact? I didn't think the design was that old. I thought that before the current EQ-3 design, meant you had a Polaris.
25 registered and 33 anonymous users are browsing this forum.
