hfjacinto
I think he's got it!
Reged: 01/12/09
Loc: Land of clouds and LP
Re: Binos or telescope for high light pollution area? new [Re: Wordslinger]
      #5758226 - 03/26/13 01:13 PM
I've never used the StarBlast 4.5, but 4.5" is small for a Newtonian and the mount is a little wobbly in my opinion. I think this is a better scope for you:
http://www.telescope.com/Telescopes/Dobsonian-Telescopes/pc/1/12.uts
This is better for NJ (as it has push to)
hfjacinto
Reged: 01/12/09
Re: Binos or telescope for high light pollution area? new [Re: hfjacinto]
      #5758230 - 03/26/13 01:15 PM
Meet me up at AAI and before you know it, you will be buying a 150MM APO on an Paramount with a whole set of Ethos and you'll be doing AstroPhotography
KWB
Reged: 09/30/06
Loc: Westminster,Co Elev.5400 feet
Re: Binos or telescope for high light pollution area? new [Re: Jon Isaacs]
      #5758259 - 03/26/13 01:30 PM Attachment (6 downloads)
When used in a light polluted location such as my suburban backyard,these little Maks still offer a lot of potential viewing targets that could keep me busy for a long time,even if I didn't own another telescope. For viewing the planets,the Moon and splitting double stars,the little Mak does a pretty decent job and is a breeze to get in and out of doors. I set it out about an hour to prior to use for thermal stability. Even though aperture limited at 90mm,IMO it can do most anything my 90mm F/10 acro can do,and do it in a more user friendly manner as to viewing objects near the zenith without me having to come out of my viewing chair,or make any radical adjustments as to the viewing height of the tripod or that chair.
In this image the little scope is sitting on an EQ1 mount. Tabletop mounts don't work out for me,either. As an all-around telescope,it is not IME,but for what it specializes at doing,not a bad choice in first telescope for someone wanting a very compact and relatively low cost setup for use in the big city.
Tony Flanders
Reged: 05/18/06
Loc: Cambridge, MA, USA
      #5758346 - 03/26/13 02:27 PM
I looked at the Starmax 90, but a table-top scope won't work for me at this time. I need a tripod.
That's definitely an issue. As Jon says, these scopes work beautifully atop good, solid tripod legs. But if you don't already own such tripod legs, they would be a substantial extra cost.
If you're handy, you could build a wooden support for very little money indeed.
I was actually looking at the Orion StarBlast 4.5 on sale with a tripod included. It's a little more than I wanted to spend, but I'm assuming I won't need anything else to get started.
As you say, you would probably want to add another eyepiece (or more likely a Barlow) right off the bat for planetary observing. I must admit that I much prefer the StarBlast on its tabletop mount rather than an equatorial mount.
Reged: 06/16/04
Re: Binos or telescope for high light pollution area? new [Re: Tony Flanders]
      #5758357 - 03/26/13 02:34 PM
Tony:
Since you are familiar with the Starblast, what do you think of it as scope intended primarily for planetary and other high magnification viewing?
The equatorial version comes with 15mm and 6mm Expanse eyepieces. The 6mm provides 75x, a 2X Barlow would double that to 150x, a nice place to be... If that Barlow were an Orion SHorty or other GSO Barlow, it could be also used as as 1.5x Barlow with only a tiny amount of hassle.
Tony Flanders
Reged: 05/18/06
      #5758374 - 03/26/13 02:46 PM
It works surprisingly well, but it certainly wouldn't be my first choice. I find that the biggest problem is focusing. At f/4, with a characteristically coarse and somewhat sticky Chinese focuser, getting precise focus is a bit of a hit-or-miss affair. For that reason, I rarely use mine above 90X.
The XT-4.5 is a wonderful planetary scope, but significantly more expensive.
Bugsi
Reged: 09/20/07
Loc: Sunnyvale, CA
      #5758443 - 03/26/13 03:23 PM
Lots of good advice here. I'd just add the following: The moon & galaxies, and the planets have kind of opposite needs. The moon is really big, and low magnification provides plenty to look at. Galaxies require dark skies and lots of aperture. A Dob would be a good choice if you hadn't mentioned planets. Planets are small, and you'll want more magnification. (As noted, they will still be frustratingly small.) -That kind of rules out a Dob.
The Orion Starmax 90 on an EQ-1 that has been suggested is a reasonable choice. Long focal length, and the German Equatorial Mount will allow you to rotate one axis with a slo-mo control to keep planets in view. I wouldn't recommend an Alt-Az mount if you're going to be looking at planets. A small Mak like the Starmax 90 can also be used with a correct-image 45-degree prism for terrestrial use.
I found the Starmax 90 to be particular about eyepieces, with some of my favorites exhibiting intolerable kidney-beaning. If you get one of these scopes, it will come with at least a 25mm Plossl. I'd recommend joining a club and trying out other people's eyepieces, or lacking that, ask on here which eyepieces other Starmax 90 owners prefer.
Tony Flanders
Reged: 05/18/06
Re: Binos or telescope for high light pollution area? new [Re: Bugsi]
      #5758459 - 03/26/13 03:29 PM
A Dob would be a good choice if you hadn't mentioned planets. Planets are small, and you'll want more magnification. That kind of rules out a Dob.
Why does it rule out a Dob? Even the smallest Dobs deliver better high-power images than the Starmax 90 -- which is itself no slouch.
Granted, it's nice to have motor tracking at high magnifications. But in all other ways Dobs make superb planetary telescopes.
Reged: 06/16/04
Re: Binos or telescope for high light pollution area? [Re: Bugsi]
      #5759436 - 03/27/13 12:08 AM
Tony commented on this, I also think it needs a comment.
The planets are small, Jupiter is about 40 arc-seconds across, so to see the details, magnifications of 150x or more are desirable, generally somewhere between 150x and 250x possible. This is primarily determined by the stability of the atmosphere, the "seeing."
The amount of detail that can be seen also depends on the quality and size of the telescope. Larger apertures provide better resolution and better planetary contrast. In general, this favors a scope in the 8-12 inch range. A 10 inch Newtonian can provide more detailed and better resolved planetary views than even the best 4 inch scope.
The only issue I can see that might be of concern is the need to manually track most Dobsonians. I don't consider this an issue, it does take a short while to learn to manually track a Dobsonian but what I find is that people seem to learn it quickly, tracking at 200x without much difficulty within a few minutes. To feel confident, it takes longer but it's not difficult for most.
When I want the best planetary viewing, when I want to split the tightest double stars, I almost always choose a Dobsonian. Granted I am skilled at tracking by hand but planetary views are at relatively low magnifications compared to what is possible..
kenrenard
Reged: 12/13/12
Loc: Dunmore, PA
      #5759645 - 03/27/13 07:07 AM
Jon,
I want to add the small knob on most dobs now make tracking even easier. After reading your post a few months ago I added a knob to my XT8. Your recommendation was to keep one hand on the knob and the other hand on the side support. This is a great way to view at higher powers. I was able to show my brother-in-law to track in one try.
Once you get your hands in the right spot it becomes natural.
Ken
Wordslinger
Reged: 03/25/13
Loc: NJ
Re: Binos or telescope for high light pollution area? new [Re: kenrenard]
      #5767578 - 03/30/13 08:42 PM
I decided to go with a pair of Garrett Gemini 10x50 LW binoculars for the time being. I also purchased the Guide to the Stars chart and NightWatch. I'm going to take some time to read about astronomy and learn the stars.
I want to know more about scopes before I buy one, this way I'll know what I'm buying and which scope truly meets my needs. If the hobby sticks, I can justify raising my budget.
Thanks again for all the helpful replies. This forum is an immense resource.
Update: I received an email from Garrett. They ran out of the 10x50s and upgraded me to the 12x60s at no extra cost. Is that size manageable handheld?
Edited by Wordslinger (03/30/13 09:35 PM)
Radom
Reged: 06/15/04
Loc: Central Oklahoma
      #5767730 - 03/30/13 10:14 PM
Manageable as can be. I have those exact binos and love them. Even though I have since obtained a couple of considerably more 'serious' binoculars I still keep the Garretts close at hand all the time. However, the single most bestest thing I have to enhance bino use is a parallelogram mount. The difference between with & without is HUGE.
Wordslinger
Reged: 03/25/13
Loc: NJ
Re: Binos or telescope for high light pollution area? new [Re: Radom]
      #5767839 - 03/30/13 11:11 PM
I ordered the metal L-mount with them. My tripod isn't the best though. It holds a Canon Digital Rebel okay, but it can be kind of shaky.
http://www.bestbuy.com/site/Dynex%26%23153%3B+-+60"+Universal+Tripod/824...
Radom
Reged: 06/15/04
      #5767888 - 03/30/13 11:38 PM
You're gonna like the Garretts. And any mount at all is quite worth it.
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
      #5767917 - 03/31/13 12:05 AM
I use both binoculars and a telescope for viewing. I enjoyed the view of Panstarr better in my binos than my telescope. This is not an either or situation--but both. It would be fine to begin with binoculars, then segway to a telescope. Even if you buy a telescope, you will use the binoculars.
3 registered and 25 anonymous users are browsing this forum.
Moderator:  zjc26138, WOBentley, kkokkolis
