SeptemberEquinox
Reged: 01/29/12
Celestron AVX shaky and noise issue, HELP
      #5759824 - 03/27/13 09:22 AM
Goood morning forum,
I want to ask you guys first before I call Celestron. I bought a Celestron AVX about a month ago, so far everything was great. Since last Friday, I feel like im having couple issues with this mount.
1. It's so shaky. Its never been this shaky before on this mount. I always balance my scope on my mount before observing. Once I go over 100x, it's very shaky. It looks worse than when I had CG4. My scope only weights 16 pounds. Meade 2" star diagonal and high power eyepieces I own do not weight more than 2 pounds. I'm pretty sure I'm not pushing its weight capacity for visual observing. I only need 1 counter weight that came with the mount which is located in near center of a shaft.
2. It's gotten louder. The mount is LOUD. I don't remember it being this loud.
What's wrong with my mount? This isn't normal, is it?
Edited by SeptemberEquinox (03/27/13 11:24 AM)
zawijava
Reged: 10/06/07
Loc: Wells, Maine 04090
Re: Celestron AVX shaky and noise issue, HELP new [Re: SeptemberEquinox]
      #5759882 - 03/27/13 09:57 AM
Are you certain you are balanced? On my AVX, both the RA and DEC axis are quite stiff, but more so the DEC. I had to find the balance point of my OTA "off the mount" in order to get balanced in DEC. Are both motors LOUD or just one?
Also, are you using the tripod that came with the mount? Are you using it at it tallest position, legs fully extended? If so, have you tried it at it's shortest position, legs fully retracted, to see if the vibrations are less pronounced? -Tim
SeptemberEquinox
Reged: 01/29/12
Re: Celestron AVX shaky and noise issue, HELP new [Re: zawijava]
      #5759935 - 03/27/13 10:23 AM
Zawijava, Thank you for your reply,
DEC motor is loud. Tripod legs are not fully extended, always about half way out. And yes I'm using the tripod that came with the mount.
I'm pretty sure it's balanced. I will take little bit more time to balance the mount.
on Friday, I noticed the shakiness. So on Monday I took more time to make sure it is balanced. I hope nothing is wrong with the mount.
Edited by SeptemberEquinox (03/27/13 11:49 AM)
orlyandico
Reged: 08/10/09
Loc: Singapore
      #5760102 - 03/27/13 12:05 PM
Are you talking about continuous vibration when tracking? Or it just takes forever to settle after touching it?
If it's continuous vibration it might be a firmware bug. Such an issue was reported on certain CGEM beta firmwares..
SeptemberEquinox
Reged: 01/29/12
Re: Celestron AVX shaky and noise issue, HELP new [Re: orlyandico]
      #5760127 - 03/27/13 12:17 PM
It vibrates when I'm observing with high a eyepiece while it's tracking. Touching anywhere on my scope will vibrate the view
Senator48
Reged: 03/12/12
Loc: New Jersey
      #5760192 - 03/27/13 12:50 PM
Are you sure that the vibration at high magnification isn't due to atmospheric turbulence? I know that my C6 SCT is quite prone to this when I push the magnification on nights with less stable atmospheric conditions. Once I get north of 200X it becomes much more apparent.
zawijava
Reged: 10/06/07
      #5760394 - 03/27/13 01:55 PM
Check for a very secure, tight fit of AVX to the tripod; very secure tight fit of OTA in the saddle; both the DEC and RA clutch knobs secure and tight; good balance in both axis.
If you are not touching the mount while viewing at high power is the image fairly steady? If so, then when you touch the scope to focus does the image jump all around?.....that's likely due to the the size/length of your OTA on that mount. -Tim
      #5763288 - 03/28/13 10:09 PM
It is a loud mount.
Shaky how?
There are a number of different kinds of shaky with a number of different causes.
The most common sources are: (1) mount head is not firmly screwed onto the tripod junction, (2) bolts holding tripod legs to tripod junction have gotten loose, (3) spreader is not firmly clamped against the legs, (4) azimuth adjustment bolts not tight against "N" post, (5) OTA not properly balanced, and probably a few more I'm forgetting. It's highly unlikely to be a mount issue if it wasn't shaky earlier and is shaky now. Almost certainly a set-up issue, which is good news.
SeptemberEquinox
Reged: 01/29/12
Re: Celestron AVX shaky and noise issue, HELP new [Re: jrbarnett]
      #5763357 - 03/28/13 10:54 PM
(1) mount head is not firmly screwed onto the tripod junction!!!!!!!
It got loose some how, I hope that will fix the problem. One other thing about declination motor is that, it is quiet, but there is a spot when it rotates noise changes, it gets loud. I recorded, I will post it on YouTube shortly.
Thank you for your replies
Edited by SeptemberEquinox (03/28/13 10:55 PM)
      #5763368 - 03/28/13 11:01 PM
Bravo! I bet that snugs it up and quells your shaking. Been there, done that.
As for the noise in a particular range of travel, that might be when the load changes sides (i.e., crossing the Dec axis balance point). Be sure to check your balance in both RA and Dec axes with the scope set up as you'd use it (finder, diagonal and eyepiece installed).
Best of luck!
- Jim
SeptemberEquinox
Reged: 01/29/12
      #5763420 - 03/28/13 11:43 PM
Hey Jim,
I did the test without a scope nor a counter weight. It's taking forever to load up my video.
SeptemberEquinox
Reged: 01/29/12
      #5763460 - 03/29/13 12:25 AM
http://www.youtube.com/watch?v=JUHp_dzp7XA
Is something wrong or is this normal?
And Please check out my other video. LOL
Edited by SeptemberEquinox (03/29/13 12:27 AM)
buddyjesus
Reged: 07/07/10
Loc: Davison, Michigan
      #5763537 - 03/29/13 01:56 AM
i dont have a motorized mount, but guessing doesn't hurt. Maybe the lubrication needs to be worked around a bit in that axis to smooth it out?
SeptemberEquinox
Reged: 01/29/12
Re: Celestron AVX shaky and noise issue, HELP new [Re: buddyjesus]
      #5764551 - 03/29/13 12:28 PM
What kind of lube should I use? Lithium or Silicone? I'm scared to take these apart
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
      #5764600 - 03/29/13 12:56 PM
Super lube A little goes a very long way.
zawijava
Reged: 10/06/07
      #5764778 - 03/29/13 01:55 PM
I wouldn't take it apart just yet. Just loosen the clutches and spin each axis completely around a couple dozen times in both directions, see if that helps[take scope and cwt off first]. Plus make sure the black collar on the cwt shaft is not rubbing against the DEC housing. Make certain the black collar is screwed onto the cwt shaft as far as it will go or else it can bind against the dec housing and cause drag. This may be why you DEC motor sounds like it's working harder in certain spots in your video. -Tim
Reged: 07/06/07
      #5765217 - 03/29/13 04:45 PM
Forget the lube business. That will not help, and these mounts work best with very little lubrication, anyway. The "loud" is because of the motor housings and will be worse in cold weather and with a low battery.
SeptemberEquinox
Reged: 01/29/12
Re: Celestron AVX shaky and noise issue, HELP new [Re: rmollise]
      #5766288 - 03/30/13 08:25 AM
"Just loosen the clutches and spin each axis completely around a couple dozen times in both directions, see if that helps[take scope and cwt off first]"
That worked. I rotates few times. Mount head feels a bit stiffer, too. I doubt there will be any shaking issue. I can't wait until next clear night. Thank you very much
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5767002 - 03/30/13 02:50 PM
Overall, it sounds pretty normal to me for a mount in this class. One thing to make sure of is that you are not applying too much pressure to the clutch. If you crank down too hard on the clutch you will slightly deform the ring gear as well as push the head off center a bit. This will cause the worm to be tight in some areas and loose in others which will in turn make the mount more noisy in some areas than others. Clutch tightness on a well-balanced mount should be just enough to keep the axis from slipping when lightly bumped and that's all.
29 registered and 50 anonymous users are browsing this forum.
