General Astronomy >> General Observing and Astronomy
orion61
Reged: 10/20/07
Loc: Birthplace James T Kirk
Homemade Dec finder tool
      #5760970 - 03/27/13 06:13 PM Attachment (21 downloads)
If you ever want to see what your EQ or Fork mount is set to here is a simple cheap tool to make. Don't trust the glued on sticker on your mount!!
Use a Protractor a bit of Fishing Line and small sinker.
Make sure to tie the line loose to swing through the protractor, set your tube to 90 degrees and place this on the tube, Gravity will do the rest!
orion61
Reged: 10/20/07
Re: Homemade Dec finder tool new [Re: orion61]
      #5760974 - 03/27/13 06:13 PM Attachment (18 downloads)
pic 2
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
      #5761187 - 03/27/13 08:04 PM
How about determining declination when the optical axis in not on or near the meridian? Trigonometry required.
To set a declination circle, I'd spin the mount in RA, looking for the least field motion when the OTA is aimed closest to the mount's polar axis, then set to +90. Thereafter, the circle will be sufficiently accurate (unless horribly small), and moreover will work at all scope orientations.
orion61
Reged: 10/20/07
Re: Homemade Dec finder tool new [Re: GlennLeDrew]
      #5761198 - 03/27/13 08:12 PM
didn't want to get too complicated.. but good point..
m echanical/optical axis must be correct,
also use on the bottom of the wedge plate...
ylem
Reged: 01/27/09
Loc: Monroe, NC
      #5765696 - 03/29/13 08:34 PM
What no batteries or microprocessor?
what's happening to this hobby
Jeff
1 registered and 9 anonymous users are browsing this forum.
Moderator:  cildarith, panhard, tecmage
