Telaeus
Reged: 05/19/09
Celestron AVX slewing problem new
      #5767858 - 03/30/13 11:19 PM
Hey folks. I think I may have a defective mount, but I wanted to check here to see what people think. I've never owned a tracking mount before and want to make sure I'm not messing anything up.
I followed the instructions as far as setting up the mount, mounting the OTA, balancing, etc. When I get to the alignment phase, I set everything up, pointed north, etc... then selected two-star alignment.
No matter what star I select, it slews "sideways" (whatever the technical term would be - as if using the left/right slew arrows), and then stops. It never moves as if the north/south slew buttons were used. It sits there saying it's slewing to whatever star I tried. Also, manually using the slewing buttons works east/west but not north/south. Not even motor noise.
I do see the buttons are registering that I'm pushing them (it seems to display the motor speed in the top right when you push them).
Bad mount, or is there anything I could be doing wrong that wouldn't let me manually slew north/south or even have motor noise?
Thanks.
Telaeus
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: Celestron AVX slewing problem new [Re: Telaeus]
      #5767905 - 03/30/13 11:55 PM
Is it possible that you forgot to install the dec motor cable?
Telaeus
Reged: 05/19/09
Re: Celestron AVX slewing problem new [Re: jrcrilly]
      #5767967 - 03/31/13 12:44 AM
You see... that's why I decided to write here. Because I know enough to know I screw up sometimes. Next time I'll try it with the cable installed. lol.
Reged: 04/30/03
Loc: NE Ohio
Re: Celestron AVX slewing problem [Re: Telaeus]
      #5767968 - 03/31/13 12:46 AM
I'm glad that's all it was. Bear in mind that much of the time, when we know an easy operator-error answer, it's because we have done it ourselves!
10 registered and 38 anonymous users are browsing this forum.
