jnewton
Reged: 12/20/07
Does your reflector give "refractor like" images?
      #5772204 - 04/02/13 06:31 AM
I am curious on this topic as I sometimes see that claim by scope makers. I am especially curious as to honest opinions regarding the <f/4 large dobs. We all know you get a brighter image and can see more, but does anyone feel that you get as crisp an image as an APO?
azure1961p
Reged: 01/17/09
Loc: USA
Re: Does your reflector give "refractor like" images? new [Re: jnewton]
      #5772239 - 04/02/13 07:11 AM
Well that's a loaded question. A ten inch f/4 is going to have a larger CO than a 20" and this will affect contrast. Next, at twenty inches there's no apo that can compete with it.
I think the short answer is longer focus reflectors can give refractor like images but you still kno you re looking through a reflector. Thermal cooling is needed and if you want to be a stickler, so are curved spiders. There's some contention here but I don't think any reflector will ever be the equivalent of a good apo of like sized aperture in the sizes commercially available.
Pete
Edited by azure1961p (04/02/13 07:12 AM)
Jarad
Reged: 04/28/03
Loc: Atlanta, GA
Re: Does your reflector give "refractor like" images? new [Re: azure1961p]
      #5772256 - 04/02/13 07:36 AM
Depends on what you mean by "refractor like".
The one thing that refractors tend to do very well that reflectors can't is show really bright objects against a pure velvet black background. In a reflector, you are going to have some type of diffracton effect (an even glow from the CO, plus spikes from a straight spider or more even glow from a curved spider).
I can get that "refractor-like" look on things like M13, because the diffraction is faint enough that I can't see it. But on Venus, Jupiter, Sirius, or the moon reflectors can't quite get that razor sharp blackness.
That being said, the extra aperture does let a good reflector show more detail than a refractor. So yes, Jupiter throws some glow around it in my 14.5" that isn't there in my 4" apo, but there is no comparison in the amount of low-contrast surface detail on the planet itself - the 14.5" blows the small apo away.
Jarad
azure1961p
Reged: 01/17/09
Loc: USA
Re: Does your reflector give "refractor like" images? new [Re: Jarad]
      #5772264 - 04/02/13 07:46 AM
I think Jarad makes a key point here, refractor like or not, a large enough f/4 will handedly outdo all commercial apos currently sold. It might be served a little differently but the angular resolution gets to a point the 4" or even a 7" can't make up for the difference on contrast alone.
Pete
Darren Drake
Reged: 10/09/02
Loc: Chicagoland
      #5772338 - 04/02/13 08:44 AM
I think one of the main reasons people think that refractors are a step above newts is that they have better thermal management properties by design. The light path is protected from the observers body heat and the light only goes through the tube once. This in addition to the fact that most refractors are smaller apertures make for more steadily stable images so much more often than in newts.
kfrederick
Reged: 02/01/08
Re: Does your reflector give "refractor like" images? new [Re: Darren Drake]
      #5772394 - 04/02/13 09:12 AM
http://www.dgmoptics.com/index.htm That pic says it for me . Stars do not have spikes/ The background darkness are two easy to see in a unobstructed telescope . In the HST images just think of all the detail hidden by those spikes . Just my thoughts .
Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
Re: Does your reflector give "refractor like" images? new [Re: kfrederick]
      #5772458 - 04/02/13 09:48 AM
I unabashedly claim that my Intes 6" f/8 Mak Newt, with a 16% central obstruction and no spider to smear light gives a totally 'refractor-like' view on ANY object, bright or dim.
And it only cost $1000....
Dave
RogerRZ
Whatta you lookin' at?
Reged: 01/09/06
Loc: West Collette, NB, Canada
Re: Does your reflector give "refractor like" images? new [Re: Cotts]
      #5772562 - 04/02/13 10:43 AM
I have a 6.5" f/5.5 MN65 that does a fair job at impersonating a refractor (except for the eyepiece position ).
Reged: 06/16/04
Re: Does your reflector give "refractor like" images? new [Re: RogerRZ]
      #5772641 - 04/02/13 11:17 AM
A few thoughts:
Does refractor-like mean large Airy disks with a healthy dose of field curvature and maybe even some chromatic aberration? Does it mean relatively small exit pupils and relatively slow focal ratios?
Or does "refractor-like" mean a essentially perfect view, one free of field curvature, coma, astigmatism, chromatic aberration, with Airy Disks that are impossibly small?
I think under the right circumstances, essentially perfect views are possible with a Newtonian, I think most refractors do not give "refractor-like" views. Even the NP-101 with it's seemingly perfect color correction and flat field is too underpowered.
In terms of perfect views, I think a 12.5 inch F/6 tube Newtonian in the mild San Diego climate fitted with good fans and a careful observer does a good job... The 31mm Nagler + Paracorr + 12.5 inch F/6 + dark skies... clean and sharp across the FOV, no field curvature... coma undetectable. Contrast... can be amazing.
I no longer use the term "refractor-like" because refractors have their own set of aberrations and most are underpowered. I use "near-perfect" to describe those pristine, totally amazing views..
Most scopes are able to produce near perfect views of some set of objects and are not so hot on others.
Jeff Porter
Reged: 09/03/10
Loc: Utah
      #5772643 - 04/02/13 11:17 AM
Only when I set it up in such a way that it looks like a refractor. Unfortunately I can only see the grass in this configuration.
In all seriousness all three of my reflector scopes give great views. To achieve this you need good optics to reduce light scatter for a black background, solid collimation, and thermal control. At that point only the atmosphere will limit your views.
Jeff P
Aquatone
Reged: 03/23/06
Loc: California Bay Area
Re: Does your reflector give "refractor like" images? new [Re: Jeff Porter]
      #5772744 - 04/02/13 12:00 PM
If in terms of "refractor like" one means tight pin-point stars against black with a high degree of contrast with no scatter or softness, then I have recently undergone a conversion. I now have no doubt that a well designed (and collimated!) reflector can produce at least a comparable visual experience. The sharpness, clarity of detail, and lack of scatter, in my Lockwood 24" F/3.3 (22.9% obstruction) under the right viewing conditions is easily comparable to any of my refractors, and obviously superior in terms of angular resolution and light gathering ability. I do take the time to properly collimate to a high degree of precision but the rewards are high. Of course there is no comparable refractor in this size range so a strict comparison is not quite fair or valid. However the question is about the aesthetics of the view in < F/4 large Newtonians.
I am second to none in my love for refractors and own both an AP130 and AP160, but the latter is mainly used as an imaging instrument these days. I now use my refractors as much for their "grab and go" convenience as I do for the aesthetics of the views.
Chris
ed_turco
Reged: 08/29/09
Loc: Lincoln, RI
      #5772764 - 04/02/13 12:08 PM
I disagree with the statement that no Newt can equal an equal aperture APO. But it will take a lot of very creative thinking and some hard work to do the job.
Some time soon, I will prove my point, period.
And judging from the bashing I got on the Refractor Forum a while back, no APO owner will ever admit it.
I do concede that an ordinary Newt, as currently envisioned, cannot equal an equal aperture APO. It just ain't gonna happen! And comparing a large Newt to a small APO is comparing apples to oranges.
As usual, I will add no further comments to this thread; I have work to do.
Ed
Reged: 06/16/04
Re: Does your reflector give "refractor like" images? new [Re: ed_turco]
      #5772852 - 04/02/13 12:41 PM
Maybe comparing apples to peas?
Galicapernistein
Reged: 09/24/07
Loc: Detroit Michigan
Re: Does your reflector give "refractor like" images? new [Re: Jon Isaacs]
      #5772902 - 04/02/13 01:07 PM
Edited by Galicapernistein (04/02/13 01:17 PM)
Mike B
Starstruck
Reged: 04/06/05
Loc: shake, rattle, & roll, CA
Re: Does your reflector give "refractor like" images? new [Re: Aquatone]
      #5772939 - 04/02/13 01:18 PM
I will very much look forward to this, Ed!
If in terms of "refractor like" one means tight pin-point stars against black with a high degree of contrast with no scatter or softness...
That's my impression of what is typically being compared, and i'd agree that, with some effort, one can get fairly close with a Newtonian. My Starsplitter Dob does a fairly good job at this, generally putting a nice point to stars!
But i sometimes observe with a fellow who owns an AP155, and IT has the "refractor-like views" that are being discussed here! So the view aesthetic in each system is going to be different... and "different" doesn't mean bad. Just different. As Jon has said, a Newtonian isn't aimed so much at achieving a "refractor-like" aesthetic- why would it be? That's not where it works best. It's designed to collect more photons in a manageable & affordable package. The goal is to let it do so, while optimizing it's system... let the views become what they are, naturally.
I s'pose, if one were inclined to do so, one could always fit an aperture mask on their Newt- bypassing the CO & vanes so as to obtain the almighty "refractor-like" views. But then ya got a 4" scope.
When seeing conditions (ground & aloft) are poor, the "refractor-like" abilities of a larger Dob are not gonna be there- oh yeah, it'll still go deeper & resolve (most things) finer than a smaller Apo, in general, but you will KNOW you're looking thru a reflector... by the aesthetics (or lack thereof, if you will ) of the view.
There are objects & conditions i've seen where the fine planetary detail (Jupiter is a good example) is better portrayed in the Apo, yet more often i've seen where the Dob's view of Jupiter is at least equally detailed to the Apo's, while also bigger & brighter.
But when the air is good- in/around the Dob, as well as above it- even the view's aesthetics can be mighty close. And what can be seen & resolved... not close at all; the Dob just walks off with it... especially on deepsky.
Mike B
Starstruck
Reged: 04/06/05
Re: Does your reflector give "refractor like" images? new [Re: Galicapernistein]
      #5772943 - 04/02/13 01:19 PM
Or, perhaps, comparing apples to appease?
rgconner
Reged: 03/17/13
Loc: Sacramento, CA
Re: Does your reflector give "refractor like" images? new [Re: Mike B]
      #5772963 - 04/02/13 01:29 PM
Does your F350 perform like my Porsche?
Depends, are we racing, or hauling rocks?
Mike B
Starstruck
Reged: 04/06/05
Re: Does your reflector give "refractor like" images? new [Re: rgconner]
      #5772989 - 04/02/13 01:37 PM
... or racing where? Highway or off-road?
Excellent analogy!
kfrederick
Reged: 02/01/08
      #5773001 - 04/02/13 01:53 PM
For sure a perfect newt can make anyone happy . The problem is spherical lens surfaces are not that hard to mass produce. The parabolic surface is Harder to have perfect .
dan_h
Reged: 12/10/07
      #5773098 - 04/02/13 02:55 PM
True, a spherical lens surface can be machine finished, to a certain degree. But there is more to a lens than a single spherical surface. As a minimum there are four surfaces, two thicknesses and wedge errors, one air space, and four close tolerance radii to be controlled. All of these are interdependant to a point and so the final overall precision may actually be more difficult than a single parabolic mirror surface.
The fact is, if you want top notch performance from either a lens or a mirror, you need a qualified optician to provide the final touches.
dan
Edited by dan_h (04/02/13 03:22 PM)
11 registered and 17 anonymous users are browsing this forum.
Moderator:  ausastronomer, Knuklhdastrnmr, Phillip Creed, JayinUT
