saemark30
Reged: 02/21/12
High End Components
      #5772920 - 04/02/13 01:13 PM
I'm looking to rebuild a 10" Newtonian. What are the better makers of mirror cells and secondary supports?
Who sells tubes of 12" dia. or so?
Pinbout
Reged: 02/22/10
Loc: nj
Re: High End Components new [Re: saemark30]
      #5773181 - 04/02/13 03:42 PM
a 10" cell is easy enough to make, or you could spend 300 for an aurora precision cell that you still have to glue to your mirror...
draw it up.
then cut it up.
Pinbout
Reged: 02/22/10
Loc: nj
      #5773224 - 04/02/13 04:02 PM
i forgot to say, i could have had the two plates and rocker bars waterjetted out of 1/4" alum for only $40 labor $20 material. I just wanted to make it out of wood this time for the halibut.
saemark30
Reged: 02/21/12
Re: High End Components new [Re: Pinbout]
      #5773296 - 04/02/13 04:41 PM
I bet it looks great in alum too. I could modify an existing cell with rocker bars.
What do you use for a secondary holder and spider Danny?
davidpitre
Reged: 05/10/05
Loc: Central Texas
      #5773362 - 04/02/13 05:03 PM
How thick is your mirror?
Here is a nice cell: http://www.aurorap.com/prod-AZ-mirror-cell.htm, though it requires silicone. Carl Zambuto says silicone works great on these smaller mirrors. I wouldn't be big on it, but I sure wouldn't argue with Carl. I believe Portaball silicones their mirrors in , and few have anything bad to say about that set-up.
JPAstrocraft will also make you a 6 point cell for your 10". He does wonderful work: http://www.jpastrocraft.com/cells.htm ...and you get edge support.
Some of the better secondary mirror supports come from Astrosystems and Protostar.
Protostar sells a nice non-metallic tube. Hastings is likely the least expensive place for aluminum tubes. There are now several places for carbon fiber 12" tubes if that is what you are after.
saemark30
Reged: 02/21/12
Re: High End Components new [Re: davidpitre]
      #5773609 - 04/02/13 06:13 PM
The mirror is around 1 3/8" thick.
Who makes carbon fiber tubes?
They are very expensive.
Would it be practical to make one?
Pinbout
Reged: 02/22/10
Loc: nj
      #5773614 - 04/02/13 06:17 PM
astrosystems for secondary spiders
Pinbout
Reged: 02/22/10
Loc: nj
      #5773633 - 04/02/13 06:27 PM
Optical Support - $229
but they're temporarily off line 6-12 months.
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
      #5773644 - 04/02/13 06:32 PM
Mirror Cells, cell parts, and knowledge about them:
http://web.telia.com/~u41105032/spider/spider2.htm
http://astrosurf.com/altaz/astatic.htm
http://aurorap.com/prod-mirror-cell.htm
http://www.bellevillesprings.com/belleville-washers.html
http://www.davidlewistoronto.com/plop/design.htm
http://www.dobstuff.com/mirrorcell.htm
http://www.cruxis.com/scope/mirroredgecalculator.htm
http://www.mcmaster.com/#belleville-disc-springs/=gmve8g
http://www.greenhulk.net/forums/showthread.php?t=104558&page=2
http://www.meridiantelescopes.com/primary.htm#primarymirrorcell
http://www.atmsite.org/contrib/Holm/Plop_optimized_cells/index.html
http://www.cruxis.com/scope/mirrorcooling.htm
http://www.oneilphoto.on.ca/news.htm
http://www.opticalsupports.com/
http://astrosky.homestead.com/price.html
http://www.universityoptics.com/telescope-making-supplies.html
I do not recommend a full-tube scope, even if the scope will be housed permanently in an observatory. If Alt-Az, the center of gravity will be too high, a rigid-enough structure will weigh a huge amount in any size over 12", and mirror cell design will make insertion of the mirror and cell difficult because of weight. In a truss design, the structure can be very rigid yet significantly lighter. And, the scope will be easier to construct and transport.
This is less of a problem for a 10", but even then, finding a rigid non-steel tube of 12" I.D. will be difficult and expensive. You could almost make the entire housing for the price of a tube, if the tube is fiberglass or phenolic materials. Carbon fiber would be difficult to find, and an aluminum tube will be fairly heavy if you find one that big.
There are just so many advantages to the truss design, I can't recommend a tube for your scope. 8" and smaller, maybe. But the only reason to have a 10" tubed scope is because it came that way, IMO.
Edited by Starman1 (04/02/13 06:37 PM)
rgconner
Reged: 03/17/13
Loc: Sacramento, CA
Re: High End Components new [Re: Starman1]
      #5773669 - 04/02/13 06:45 PM
Carbon tubes are easy to come by on the web...
but you are looking at around $1200 or more.
Pinbout
Reged: 02/22/10
Loc: nj
      #5773918 - 04/02/13 08:16 PM
you can get a wood 12" tube
Aitwood Anerson for $127
Pinbout
Reged: 02/22/10
Loc: nj
      #5773926 - 04/02/13 08:18 PM
don astrosky and optical support are down not out but astrosky won't be back till 2015.
Pinbout
Reged: 02/22/10
Loc: nj
      #5773941 - 04/02/13 08:30 PM
shapes unlimited also sells cardboard tubes
you have to order their standard sizes
but I got a 10in x 96in which they cut in half for ~$70
Daud
Reged: 08/05/06
Loc: AZ, Scottsdale
      #5774234 - 04/02/13 09:51 PM
What about cost and source for carbon fiber trusses ?
Starman1
Reged: 06/24/03
Loc: Los Angeles
Re: High End Components new [Re: Daud]
      #5774328 - 04/02/13 10:32 PM
Saw one quote recently for about $180 per foot.
herrointment
Reged: 03/12/11
Loc: North of Hwy. 64
      #5774451 - 04/02/13 11:38 PM
Danny...way cool links. Thanks!
Pinbout
Reged: 02/22/10
Loc: nj
Re: High End Components new [Re: herrointment]
      #5774528 - 04/03/13 12:27 AM
both places will veneer the tubes for ya if ya don't won't to bother with that type of work.
Chucky
Reged: 04/16/10
Loc: Dublin, Ohio
      #5774764 - 04/03/13 06:57 AM
Anyone remember California Tubular Designs from ....oh say 10-12 years ago? Mark Wagner used to do some pretty cool custom tubes. I use one for my 10 inch F6. Is really nicely constructed with strong, good looking covering. Has strengthening end rings too.
gaz-in
Reged: 12/17/07
      #5774800 - 04/03/13 07:48 AM
Chatting with Steve Swayze last weekend. He too speaks highly of siliconing mirror to cells.
davidpitre
Reged: 05/10/05
Loc: Central Texas
      #5774840 - 04/03/13 08:20 AM
I have a hard time with this cell for a standard (not conical) mirror. The 10" has 4 fixed points for bottom support. How is this a good idea?
21 registered and 23 anonymous users are browsing this forum.
