patrick2874
Reged: 02/05/13
Loc: memphis,tn.
looking for sct thread to 1.25" adapter new
      #5775354 - 04/03/13 11:35 AM
im not sure if im goin to lose my mind or hair first.i own an sct with a zhumell dual speed focuser and just purchased a 2" dielectric diagonal.im trying to do ap.i purchsed a meade variable projection adapter(for sct) which means it has the 35mm female threads.im trying to find an adapterto 1.25 nose so i can also use it on my reflector.does anyone know what they would call it or who would sell it..im about to get the tig welder or go to home depot if i cant find something. so any leads are greatly appreciated.
hdt
Reged: 11/10/07
Loc: N35°10' W106°32'
Re: looking for sct thread to 1.25" adapter new [Re: patrick2874]
      #5775459 - 04/03/13 12:34 PM
I'm slightly confused as to what you need, though--the standard visual back is a SCT-to-1.25" adapter. Think you can sketch roughly what you're trying to do, then, take a picture of your sketch and upload? Are you trying to replace your eyepiece with your lens-less DSLR? Are you trying to point your DSLR (with lens)at your eyepiece and take a picture? Are you trying to remove the diagonal, and attach the DSLR (lens-less) to the telescope in the shortest way?
I'm pretty sure that the CN sponsors carry what you need for any of the above cases. Check the CN primary sponsor, Astronomics, then, agenaastro and scopestuff.
Best of luck!
patrick2874
Reged: 02/05/13
Loc: memphis,tn.
Re: looking for sct thread to 1.25" adapter new [Re: hdt]
      #5775505 - 04/03/13 12:54 PM
i agree a standard sct outputs 1.25. however the meade variable projection adapter screws onto that visual back.i want that projection adapter to have a 1.25 nose on it so i can use it in a barlow or my reflector tele.i have the portion that hooks to my dslr and that is great but i need the end that plugs into the tele.
hdt
Reged: 11/10/07
Re: looking for sct thread to 1.25" adapter [Re: patrick2874]
      #5775568 - 04/03/13 01:27 PM
Something like this? http://www.scopestuff.com/ss_tafp.htm
patrick2874
Reged: 02/05/13
Loc: memphis,tn.
      #5776029 - 04/03/13 05:34 PM
possibly it needs to have a 35mm dia threaded portion.i will attempt to contact them to find out
patrick2874
Reged: 02/05/13
Loc: memphis,tn.
      #5776117 - 04/03/13 06:12 PM
thanks guys i contacted the guys at scope stuff in tx. they knew exactly what i needed and its now on its way home thanks soooo much for the lead
18 registered and 28 anonymous users are browsing this forum.
Moderator:  Dave M, fishonkevin, WOBentley, tecmage
