ubermick
Reged: 04/12/12
Loc: San Rafael, CA
Mundane topic... AAA batteries for lasers?
      #5776569 - 04/03/13 09:47 PM
Here's a quick question for folks... I have a basic 5mW laser pointer that I use at star parties, when with my mother in law (no, I don't shoot her in the eye despite that being tempting!) or even walking the dog, pointing out things of interest to my wife who's REALLY getting into the hobby.
Alas, it goes through batteries fast. I bought a pack of Costco AAA Duracell batteries a while back, and am already halfway through the package. I honestly don't use it that much, but I find that even after a few minutes of use, the beam has degraded noticably, and at an average star party/outreach event, the batteries are completely toast come the end of the evening.
Does anyone have any recommendations on a quality battery (and I suppose charger) for these things?
Edited by tecmage (04/03/13 11:48 PM)
Jarrod
Reged: 01/20/13
Loc: SE USA
Re: Mundane topic... AAA batteries for lasers? new [Re: ubermick]
      #5776761 - 04/03/13 11:29 PM
I have had good luck with the energizer rechargeable NiMH AAAs.
Another option is to see if they make lithium batteries in AAA size. Those can have up to 9x the capacity of alkaline depending on which ones you get. They aren't rechargeable though.
Edited by Jarrod (04/04/13 05:28 PM)
WarmWeatherGuy
Reged: 08/27/11
Loc: Orlando, FL 28° N, 81° W
      #5776964 - 04/04/13 02:34 AM
I have multiple green laser pointers. One of them seems to kill the batteries even when I don't use it. There must be some slight drain on the battery even when not turned on. Try taking the batteries out when not using it.
I found some lithium AAA batteries at Walmart. I haven't killed them yet so I can't say how much better they might be.
BSJ
Reged: 12/22/08
Loc: Grand Isle, VT
Re: Mundane topic... AAA batteries for lasers? new [Re: WarmWeatherGuy]
      #5777186 - 04/04/13 08:55 AM
Plain old Rayovac's work for a long time in my two lasers...
hfjacinto
I think he's got it!
Reged: 01/12/09
Loc: Land of clouds and LP
Re: Mundane topic... AAA batteries for lasers? new [Re: BSJ]
      #5777235 - 04/04/13 09:41 AM
All the rechargeables I ever got never lasted too long. I changed to lithium and the laser pointer works much better and longer.
Adam Taylor
insignificant bystander
Reged: 11/11/10
Loc: Arizona
      #5778036 - 04/04/13 04:10 PM
Fellow Liverpool FC supporter,
Have you only used your laser in cold temperatures?
rdandrea
Reged: 06/13/10
Loc: Colorado, USA DM59ra
Re: Mundane topic... AAA batteries for lasers? new [Re: Adam Taylor]
      #5778127 - 04/04/13 04:50 PM
I use AAA lithiums that I got either at Walmart or my local hardware store--I don't remember where now. They really last. They do better in the cold, too.
richsvt
Reged: 01/09/09
Loc: North Shore of Boston
Re: Mundane topic... AAA batteries for lasers? new [Re: rdandrea]
      #5778153 - 04/04/13 05:12 PM
I only use either lithium primaries or NIMH as rechargeables. I will never use regular alkalines in anything that is expensive as they are prone leak. Try Battery Junction as there are always good deals to be had...excellent service.
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: Mundane topic... AAA batteries for lasers? new [Re: richsvt]
      #5778316 - 04/04/13 06:40 PM
Non-rechargeable lithium batteries will last longest.
Rechargeables put out less voltage, so either won't operate or will produce a weaker beam.
Keep the laser warm, as in an inside pocket, when not in use. This will make the output of the batteries stronger and warm the diode for stronger output.
If the laser is stone cold, warm it before turning it on.
Use the laser when pointing, but not when talking about what you pointed at. I use a green laser pointer when showing the sky to newbies, but it is on only about 25% of the time I'm talking about what I pointed at.
Aquarist
Reged: 08/27/12
Loc: Illinois
Re: Mundane topic... AAA batteries for lasers? new [Re: Starman1]
      #5780249 - 04/05/13 05:52 PM
Lithium works best for me. I cannot say one brand is better than another.
core
Reged: 02/23/08
Loc: Mostly in Norman, OK
Re: Mundane topic... AAA batteries for lasers? new [Re: Aquarist]
      #5780328 - 04/05/13 06:47 PM
I've had very good experience with Sanyo Eneloop batteries in my AAA size GLP's; I don't have the GLP 'on' for more than a couple of seconds at a time. Low temps seem to affect the GLP laser unit more than the batteries' ability to output the required current, and a pack of handwarmer usually keeps it warm enough when temps dip below ~60F
KD58
Reged: 11/23/12
Loc: West Texas
Re: Mundane topic... AAA batteries for lasers? new [Re: core]
      #5781557 - 04/06/13 11:02 AM
Another Liverpool FC supporter here. They do drain the battery quick but Duracell rechargeable batteries are doing the trick for me.
Greyhaven
Reged: 05/11/04
Loc: Greater downtown Maine
      #5781889 - 04/06/13 01:42 PM
A dummy battery ( wood dowel diameter to match and cut to length positive and negative wires attached to match original battery a small hole drilled on the side of laser pointer to allow long enough wires to allow mobility needed and for those using a celestron power tank a quick attachment to the 3volt accessory port and there should be plenty of power for normal use, at least it worked for me until someone walked away with it one night. They must have mistaken it for an electric pen with 8 foot leads.
Don't have a laser now and don't plan on replacing it. Just another toy.
Be Well
Grey
17 registered and 22 anonymous users are browsing this forum.
Moderator:  tecmage, rflinn68
