ibase
Vendor Affiliate
Reged: 03/20/08
Loc: Manila, Philippines 121*E 14*N
1st look at Baader Classic Orthos/Q-Turret/Barlow
      #5783159 - 04/07/13 06:12 AM
New Baader Classic Orthos 6, 10, 18mm & 32mm Plossl
BCO & BGO 6mm's
Click here for blog post review. Thanks.
Best,
hfjacinto
I think he's got it!
Reged: 01/12/09
Loc: Land of clouds and LP
Re: 1st look at Baader Classic Orthos/Q-Turret/Barlow new [Re: ibase]
      #5783585 - 04/07/13 11:22 AM
Great review Hernando
leonard
Reged: 10/19/07
Loc: West Virginia
      #5783645 - 04/07/13 11:55 AM
Thank You , Leonard
Scanning4Comets
Markus
Reged: 12/26/04
Loc: Ontario, Canada
Re: 1st look at Baader Classic Orthos/Q-Turret/Barlow new [Re: leonard]
      #5783672 - 04/07/13 12:11 PM
Always a pleasure to read your reviews Hernando !
I'm a wide field / long eye relief person myself, but after reading your review, I wouldn't mind trying out an Ortho sometime! I have been dead-set against them, but if the views deliver, I guess that is all that matters.
ibase
Vendor Affiliate
Reged: 03/20/08
Re: 1st look at Baader Classic Orthos/Q-Turret/Barlow new [Re: hfjacinto]
      #5783758 - 04/07/13 01:01 PM
Thanks Helder.
Best,
ibase
Vendor Affiliate
Reged: 03/20/08
      #5783760 - 04/07/13 01:01 PM
Thank You , Leonard
Thanks too.
Best,
ibase
Vendor Affiliate
Reged: 03/20/08
Re: 1st look at Baader Classic Orthos/Q-Turret/Barlow new [Re: Scanning4Comets]
      #5783778 - 04/07/13 01:08 PM
Thanks Mark!
Mark I know you've tried a lot of eyepieces, been following your ever-changing parade of EP's and a joy to read your reviews as well. Yes you should give the BCO's a spin one of these days, there's nothing like trying out a new line of EP's as you may very well know. Thanks!
Best,
russell23
Reged: 05/31/09
Loc: Upstate NY
      #5783891 - 04/07/13 02:13 PM
Great review Hernando. How far does the barlow extend into the eyepiece? Will it thread on other 1.25" eyepieces as well? Or does it have special threads?
Dave
John Huntley
Reged: 07/16/06
Loc: South West England
Re: 1st look at Baader Classic Orthos/Q-Turret/Barlow new [Re: russell23]
      #5783929 - 04/07/13 02:29 PM
Very interesting to read your views on these Hernando.
I was loaned a set a couple of months back and I'd agree with your assessment of them. I do find the 6mm BGO controls light scatter a little better than the BCO 6mm and the BCO 18mm seems to have slightly better light transmission than the BGO equivalent. The 32mm Classic Plossl is a decent 32mm plossl but not a great one, in my opinion. The Q-Turret barlow is really good although the optical element can't be used in eyepieces with a lower lens set in their barrels - you need around 13mm clear inside the eyepiece barrel to fit the Q-Turret optical element.
Thanks for posting the link
Edited by John Huntley (04/07/13 02:30 PM)
desertlens
Reged: 12/06/10
Loc: 36N 105W
Re: 1st look at Baader Classic Orthos/Q-Turret/Bar new [Re: ibase]
      #5784118 - 04/07/13 03:41 PM
Hernando, Thanks for your time and effort with this review. The photos were informative. I was curious about how they would look "dewinged".
buddyjesus
Reged: 07/07/10
Loc: Davison, Michigan
Re: 1st look at Baader Classic Orthos/Q-Turret/Bar new [Re: desertlens]
      #5784961 - 04/07/13 10:33 PM
nice review. i look forward to hearing a long tern review, like month or two post purchase. Enough time to get an above average seeing night that might show one line definitively better.
i read your blog regularly also btw
ibase
Vendor Affiliate
Reged: 03/20/08
      #5785209 - 04/08/13 02:11 AM
Thanks Dave. Here are the measurements on the Q-barlow cell. 10mm for the snout & 3mm for the standard 1-1/4" thread, like what John said, 13mm clearance is needed on the 1-1/4" EP sleeve.
The threading is standard for 1-1/4" EP's and I've just tried it on TV 20mm plossl, BGO 7mm, Faworski 7mm (needs some squiggling to get inside), Celestron 7mm volcano top ortho, Celestron 20mm/32mm plossl etc. However, it will not work without the 13mm clearance such as on the Meade UWA 6.7mm (only 6mm clearance):
In which case the barlow body needs to be employed (Same case with an 82ES14mm mushroom type) .
Works great this way on the Meade 6.7mm. This is a short barlow and may vignette on longer focal length EP's.
Best,
ibase
Vendor Affiliate
Reged: 03/20/08
Re: 1st look at Baader Classic Orthos/Q-Turret/Barlow new [Re: John Huntley]
      #5785211 - 04/08/13 02:13 AM
Thanks John, and thanks too for the additional insights on the BCO/BGO 6/18/32mm's. You're right, the barlow element cell needs 13mm clearance for threading onto the EP's 1-1/4" filter thread.
Best,
ibase
Vendor Affiliate
Reged: 03/20/08
      #5785213 - 04/08/13 02:16 AM
Thanks too Craig. The dewinged BCO looks pleasantly good to my eye.
Best,
ibase
Vendor Affiliate
Reged: 03/20/08
Re: 1st look at Baader Classic Orthos/Q-Turret/Bar new [Re: buddyjesus]
      #5785215 - 04/08/13 02:18 AM
Thanks, and you're right, more sky time with the EP's will make for a better judgement on how they fare in comparison with other EP's; yes, will update the blog post as time passes by when more tests are made possible, weather-permitting.
Thanks too for regularly visiting the blog.
Best,
Ain Soph Aur
Reged: 08/11/11
Loc: West Tennessee
      #5786482 - 04/08/13 05:35 PM
Very nice review, Hernando!
I haven't tried the BCO's but do have a Q-Turret + Q-Barlow that I use with my Brandon set and the combination is fantastic and is even light-weight enough to use on my vintage refractors. I really like that the turrent is a straight thru design rather than a mirror or prism design, and the integral barlow is awesome. With a set of 1.25" parfocal eyepieces, the combination cannot be beat for convenience.
russell23
Reged: 05/31/09
Loc: Upstate NY
Re: 1st look at Baader Classic Orthos/Q-Turret/Bar new [Re: Ain Soph Aur]
      #5786780 - 04/08/13 08:25 PM
Hernando,
Thanks for the photos and explanation on the barlow.
Dave
ibase
Vendor Affiliate
Reged: 03/20/08
      #5786998 - 04/08/13 10:05 PM
Thanks Brandon!
Your observations about the Q-Turret + Q-Barlow is true. The optical quality of the barlow is very good, and although I have yet to make more tests on it, the impression is that its performance is at least at par with my TV 2x/3x barlows. The turret as you say gets an A for convenience for me too, similar in a way to using a zoom.
Best,
ibase
Vendor Affiliate
Reged: 03/20/08
Re: 1st look at Baader Classic Orthos/Q-Turret/Bar new [Re: russell23]
      #5786999 - 04/08/13 10:06 PM
Hernando,
Dave
You're welcome Dave.
Best,
denis0007dl
Reged: 04/17/12
Loc: Croatia
      #5787301 - 04/09/13 02:45 AM
Great review Hernando!
20 registered and 36 anonymous users are browsing this forum.
Moderator:  ausastronomer, droid, Scott in NC
Calendar Event: 04/07/13
