johnpd
Reged: 04/13/08
Serious cord wrap on AZ EQ6
      #5783187 - 04/07/13 06:42 AM
I had another occurrence of power cord wrap on my AZ EQ6 last night when using Az Mode. I don't understand why the mount is no longer adjusting for it. There is no setting that I could find in the hand controller that turns it on or off. I have firmware v3.32. Any suggestions?
JohnD
Mike X.
Reged: 06/28/10
Loc: Greece-Athens and Rome-Italy
Re: Serious cord wrap on AZ EQ6 new [Re: johnpd]
      #5783741 - 04/07/13 12:50 PM
You could try to upgrade to firmware 3.34 , SW seems to recommend that for azeq6 ...I hope it helps
HowardK
Reged: 10/20/10
Re: Serious cord wrap on AZ EQ6 new [Re: Mike X.]
      #5783956 - 04/07/13 02:43 PM
No there is no on off setting for cord wrap.
I also had a few wrap problems in altaz......mostly though she was fine...so i have learned to keep a watch out and use a long enough power cord
johnpd
Reged: 04/13/08
      #5785451 - 04/08/13 08:54 AM
Thanks Mike. I will give it a try.
Skrenlin
Reged: 12/13/10
Loc: North Chicagoland area
      #5786364 - 04/08/13 04:37 PM
I know for a fact there doesn't appear to be anti-cordwrap in v3.34. That's the version of firmware I have installed, and my AZ/EQG will happily wrap its cord up (so far always counterclockwise) around itself on consecutive GOTOs.
johnpd
Reged: 04/13/08
Re: Serious cord wrap on AZ EQ6 new [Re: Skrenlin]
      #5787521 - 04/09/13 07:44 AM
Hi Skrenlin,
I looked at the Release Notes for v3.34 and it had no mention of fixing a cordwrap issue so as you said that would not help. I was getting cordwrap in a clockwise direction as that was the direction of the objects I was choosing. I went from an object in the southwestern part of the sky to one in the north and slightly east of the meridian. It continued clockwise instead of rotating counter-clockwise to it. I guess you would have to chose your objects wisely so you don't get a wrap.
JohnD
Skrenlin
Reged: 12/13/10
      #5789127 - 04/09/13 08:54 PM
My first light with the AZ/EQG was at an outreach event. I'd been viewing the moon, then switched to Jupiter as soon as it was visible in the twilight. Once sirius and I *think* it was aldeberan were visible, I did an alignment, plugged in the coords for the panstarrs comet and let people look at that until it vanished into a tree. The mount picked the shortest direction for each of these moves. After the comet vanished, I popped back to Jupiter. Once it got darker, and no public around for the moment, I decided to see if the blue snowball was visible under the library lights. Found it in the tour menu, hit GOTO and watched as the mount turned counterclockwise some 200+ degrees travel from Jupiter. Couldn't see anything at all in the eyepiece, was worried about the cordwrap (now 3/4ths of the way around the mount) so told it to go back to Jupiter. Which it did, continuing counterclockwise. I grabbed the battery and ran around the mount, Chinese firedrill style, until the cords were completely unwrapped. From there I kept my targets around Jupiter the rest of the event.
frolinmod
Reged: 08/06/10
Loc: Southern California
      #5789552 - 04/10/13 02:58 AM
I found the limits to be annoying, so I deleted them all. Perhaps this thing needs limits enabled to avoid cord wrap?
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
Re: Serious cord wrap on AZ EQ6 new [Re: frolinmod]
      #5790040 - 04/10/13 11:10 AM
It sounds like someone forgot about the cord wrap issue that Alt/AZ mounts have when they converted the EQ6 GEM to the AZEQ6. Oops! I would hope that this is being worked on in the firmware as we speak.
johnpd
Reged: 04/13/08
Re: Serious cord wrap on AZ EQ6 new [Re: EFT]
      #5791771 - 04/11/13 04:35 AM
I certainly hope so before I rip the power cord apart.
JohnD
HowardK
Reged: 10/20/10
      #5792181 - 04/11/13 11:43 AM
Is it pssible to contact skywatcher and point out this flaw?
EFT
Reged: 05/07/07
Loc: Phoenix, AZ
Re: Serious cord wrap on AZ EQ6 new [Re: HowardK]
      #5792429 - 04/11/13 01:55 PM
I certainly would, or contact Orion if you have their version.
Jack Huerkamp
Vendor - Waning Moon
Reged: 10/13/05
Loc: Louisiana
      #5794154 - 04/12/13 10:47 AM
John,
I contacted Brian Dernesch of KW Telescopes from where I obtained my SkyWatcher AZ-EQ6 about the cord wrap issue. Here is what he told me:
"When I spoke to SkyWatcher regarding cord wrap- whether or not it occurs or has been looked into- at first I got an ambiguous answer, and then a reply that they are going to fix it! Won't take them long and I will keep you as updated as is possible."
So it looks like SkyWatcher is working on a solution to the cord wrap issue.
Jack Huerkamp
HowardK
Reged: 10/20/10
Re: Serious cord wrap on AZ EQ6 new [Re: Jack Huerkamp]
      #5794881 - 04/12/13 04:44 PM
Thanks Jask for giving hope
HowardK
Reged: 10/20/10
      #5794882 - 04/12/13 04:44 PM
Thanks Jack for giving hope
johnpd
Reged: 04/13/08
      #5795367 - 04/12/13 08:58 PM
Thanks Jack,
Between the cord wraps and the initial problem I had with the All-Star Polar Alignment causing the scope to run into the mount, I am surprised it is still working.
JohnD
johnpd
Reged: 04/13/08
      #5959972 - 07/08/13 02:42 AM
I ran a test in AZ Mode to get some info on the cord-wrap problem to forward to my dealer. Started 2-star alignment with Arcturus (Az=256 degrees) by manually moving in clockwise direction. Selected 2nd alignment star as Vega (Az=65 degrees). Mount slewed clockwise to Vega. Finally I chose Saturn (Az=228 degrees) as my first object. The mount again slewed clockwise to Saturn. At that point the mount had rotated clockwise about 550 degrees and the cords had wrapped around pretty good. In fact the power cord got embedded in a slot under the RA setting circle and was not easy to free. I had a lot of slack in the cords but the power cord got caught up by the Alt adjuster as the mount rotated so it helped to lift the cord up into the slot. I hope Synta can fix this problem before something breaks.
JohnD
HowardK
Reged: 10/20/10
      #5960943 - 07/08/13 05:24 PM
It is a flaw in the software.
Come on synta get it fixed
26 registered and 50 anonymous users are browsing this forum.
