RandallK
Reged: 11/10/06
Loc: Nanaimo, B. C. Canada
A Very Reliable Guidescope new
      #5780857 - 04/05/13 11:13 PM Attachment (38 downloads)
I have posted this before but thought I would refresh the post. For 2 years now I have been using my Imaging Source DMK21 monochrome webcam for planetary imaging and guiding. I consider it the most valuable tool in my arsenal.
The guide scope conisists of an Antares 7 X 50 finderscope (with the right angle removed), and Angea Astro Blue Fireball extension, and a DMK21 monochrome webcam. The bracket is from Scope Stuff. This combination has a very low profile, very light weight and NO flexture. It has a SYNTA type dovetail that is secured with a Synta type bracket. The one screw in the bracket holds this light weight system very securely. Beacuse of the very sensitive Sony CCD on the DMK, I have had very few problems in finding a guide star. I use it on my 80mm APO refractor and on my Meade 8" SCT. I use PHD guding and only had to make some initial adjustments with no further tinkering. Maybe it's just luck that I made up this combo with great success, but I'll take it!
Edited by RandallK (04/05/13 11:16 PM)
bardo
Reged: 09/13/09
Loc: US
Re: A Very Reliable Guidescope new [Re: RandallK]
      #5780960 - 04/06/13 12:27 AM
I got the same mount and I'm plagued with flexure. I have been meaning to drill more holes for additional set screws to try and remedy the problem. Right now I use zip ties to help keep it more secure and even then I really can't go over about 5 minutes.
jbalsam
Reged: 07/06/12
Loc: Darnestown, MD
Re: A Very Reliable Guidescope new [Re: bardo]
      #5787953 - 04/09/13 12:25 PM
Bardo -
Are you sure that what is keeping your exposures under 5 minutes is flexure in the guidescope? There are other things that even a perfect guider can't correct for (like field rotation due to polar alignment being a bit off, especially if you're shooting near the pole).
Taylor
Reged: 07/10/05
Loc: Owasso, OK
Re: A Very Reliable Guidescope new [Re: jbalsam]
      #5788199 - 04/09/13 01:59 PM
What model of blue fireball adapter are you using?
Is this setup better than the 50mm Orion auto guider package?
RandallK
Reged: 11/10/06
Re: A Very Reliable Guidescope [Re: Taylor]
      #5790800 - 04/10/13 05:25 PM
It's the Blue Fireball 1.25" Eyepiece Extension Tube with 1" Extension. I don't know if it's better than the Orion. All I know is that this set-up works perfectly for me. I use it with PHD guiding. It's lightweight, small and has no flexure. The Sony monochrome CCD chip is very sensitive and captures a lot of guide stars.
30 registered and 26 anonymous users are browsing this forum.
