Eddgie
Reged: 02/01/06
Can someone with a CAD program assist me? new
      #5792224 - 04/11/13 12:05 PM Attachment (30 downloads)
I want to do some drawings that show how contrat is affected on extended images based on how the diameter of the Airy Disk of a star decreases with aperture.
To do this, I need to have pictues of the Airy Disk images I am attaching (I can email the original file) that have a transparent background.
The idea is to use some blown up images of planets and show how the Airy Disks from the smaller apeture spreads the energy from any geometric point on the extended target to a further distance than with a larger aperure.
To do that, I want to use Airy Disks images with a transparent background rathar than a black background so that the Airy Disk and the rings can be super-imposed over the background image.
Does anyone have a program that can convert these Airy Disk images so that any area in each frame that is black will be converted to being transparent?
Thanks in advance...
Agian, if you need the original image, just PM me your email address and I can send it to you, and then you will have my address to return it.
Again, thanks....
Edited by Eddgie (04/11/13 12:28 PM)
Reged: 06/16/04
Re: Can someone with a CAD program assist me? new [Re: Eddgie]
      #5792344 - 04/11/13 01:12 PM
Eddgie:
I think such a venture would be worthwhile. Generating a planetary image by summing the disks and diffraction rings could be informative. I am not sure you need a Cad program for this, Cad programs generally are vector based and have minimal image handling capabilities.
But if you want to give it a try, there is a program called Draftsight which is a free 2-D CAD program made by Dassault Systemes, Dassault's main product is Solid Works which is a very popular and powerful 3-D modeling program, Draftsight seems to be also a serious and capable program.
HunterofPhotons
Reged: 04/26/08
Loc: Rhode Island, USA
      #5792636 - 04/11/13 03:43 PM
Do you have PhotoShop?
dan k.
Eddgie
Reged: 02/01/06
Re: Can someone with a CAD program assist me? new [Re: Jon Isaacs]
      #5792900 - 04/11/13 05:17 PM
Thanks for the encouragement.
I will look into the software. If it is free, I can at least try it.
I am hoping there is such a thing as a "Transparent" fill, where I can select the black background and convert it to transparent.
I could never do the entire planet, but what I though I would do would be to blow up a picture of Jupiter and scale some small feature on it (like a low contrast festoon) so that I could super-impose the diffraction patterns directly on to the image at the right scale, so that people could see how the size of the diffraction pattern determines how contrast can be lowered over a very large angular area due only to the size of the diffraction pattern of a small aperture.
I realize that it would only be an aproximation of what is happening, but it would hopefully convey an understanding of why contrast transfer increses with aperture.
Thanks again. Will see if I can find it and make it work.
Eddgie
Reged: 02/01/06
Re: Can someone with a CAD program assist me? new [Re: HunterofPhotons]
      #5792901 - 04/11/13 05:18 PM
Sorry, I do not.
Do you know if this function is available in Photoshop? I have a neighbor that is a professional photographer and I know he has the program...
Pinbout
Reged: 02/22/10
Loc: nj
      #5793061 - 04/11/13 06:51 PM
You have to play with the transparency maps for the layers in photoshop. Change it from normal to multiply or screen or overlay. Cad won't do what you want.
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Can someone with a CAD program assist me? new [Re: Pinbout]
      #5793072 - 04/11/13 06:59 PM
Indeed, this is all about rasterized images, which Photoshop or the open source 'equivalent', GIMP, handles with panache.
And a very useful project I heartily endorse.
Pinbout
Reged: 02/22/10
Loc: nj
Re: Can someone with a CAD program assist me? [Re: Eddgie]
      #5793385 - 04/11/13 10:07 PM Attachment (13 downloads)
here's your image as a screen transparency over top of jupiter
HunterofPhotons
Reged: 04/26/08
      #5794297 - 04/12/13 11:58 AM
You have to play with the transparency maps for the layers in photoshop. Change it from normal to multiply or screen or overlay.....
What Danny said.
As with most procedures in PhotoShop there are several paths to the same goal. You can also select the areas you want to make transparent with the magic wand or some such, and under 'Help' select 'export as transparent image'. This may only be available for 8-bit images.
dan k.
oo_void
Reged: 11/13/09
Loc: San Francisco, CA
      #5794510 - 04/12/13 01:51 PM
Though there is cost associated with it ($300) and a learning curve, but if you have any coding aptitude, writing some custom functions in PixInsight would be great for experiments like this.
GlennLeDrew
Reged: 06/18/08
Re: Can someone with a CAD program assist me? new [Re: oo_void]
      #5796530 - 04/13/13 12:20 PM
Edggie,
I'm curious to know if Danny's efforts here have proved helpful. This thread is otherwise hanging in limbo...
Crow Haven
Reged: 01/09/09
Loc: Oregon USA
      #5797210 - 04/13/13 05:33 PM Attachment (4 downloads)
Another way to create the airy discs is to construct the pattern with Photoshop Elements (the cheaper $70 program) on a transparent background and save the file as a .png file that can then be brought into any photo manipulating program you have that can handle .png files as well as .jpg files. There you can add your jpg planet image and then overlay the airy disc png file, scale it to whatever size you want, enhance its opacity, etc. and save the final image as a jpg.
I played with this idea using the first of your airy discs and drew in Photoshop Elements one that seems close. The attached image is of the transparent airy disc png file overlaying a colored bkg for example.
---Maya
Crow Haven
Reged: 01/09/09
Loc: Oregon USA
Re: Can someone with a CAD program assist me? new [Re: Crow Haven]
      #5797217 - 04/13/13 05:37 PM Attachment (3 downloads)
Here is the .png file image -- it probably won't show up well as the background is transparent and the airy disc is in shades of white...but it can be copied from this post and saved as a .png. If not, and if you or anyone wants the file I can email it.
2 registered and 17 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
