Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | (show all)
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
Re: LX850 14" new [Re: GlennS]
      #5781942 - 04/06/13 02:05 PM
FWIW -- I was just able top connect my 10" X-850 to the SkyX Serious Astronomer edition -- selected LX200-10" as the scope. It appears to work well (well, at least for knowing where the scope is pointed, and slewing to objects).
Confirmed! I love The Sky X!!
Whichwayisnorth
Reged: 07/04/11
Re: LX850 14" new [Re: Whichwayisnorth]
      #5792254 - 04/11/13 12:19 PM
Update: Still just messing around indoors. My system hasn't left its spot on the living room floor since I assembled it. First clouds and wind, then very high winds and where I thought Wednesday night was supposed to be nice, clear, moonless and steady, it was only two of those things. Tonight there is a predicted 50% chance of rain as well as during the day tomorrow but it looks like it may be clear with no wind Friday night and Saturday night with clouds again Sunday. One of those things where having a little grab-n-go comes in handy but with this monster it is quite a lot of work (heavy) setting up and tearing down for just a night or two at the most. I am debating with myself setting up tomorrow afternoon or not.
Edited by Whichwayisnorth (04/11/13 12:21 PM)
R L Harris
Reged: 01/31/13
Loc: Independence,MO
      #5792325 - 04/11/13 12:58 PM
You need to build your self an obsevatory!
-Open door roll off roof power up and go- LOL
Edited by R L Harris (04/11/13 12:59 PM)
galaxy_jason
Vendor
Reged: 05/22/07
Loc: Texas
      #5792368 - 04/11/13 01:22 PM
http://www.hardwareworld.com/Super-TriDolly--12-inch-pTVE1P4.aspx
Whichwayisnorth
Reged: 07/04/11
Re: LX850 14" new [Re: galaxy_jason]
      #5792424 - 04/11/13 01:53 PM
Jason, I would if I could. Unfortunately it won't work for me. I need to solve this by buying property in Flagstaff.
Someday when my kids outgrow their playground equipment I'll have a nice spot for roll off.
All that being said, the issue isn't so much the 40-50mph gusts that came through but also the bad seeing I've had as a result.
Edited by Whichwayisnorth (04/11/13 01:54 PM)
galaxy_jason
Vendor
Reged: 05/22/07
Loc: Texas
      #5792497 - 04/11/13 02:22 PM
I use these to roll the scope out of the garage and into the
back yard. Do you have a driveway?
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: LX850 14" new [Re: R L Harris]
      #5792512 - 04/11/13 02:28 PM
An observatory certainly improves things, especially for imagers. I suspect, however, that this mount will generally be of less interest to those with permanent setups than to those who image in the field. The major model-specific features are of clear benefit for field use, but much less important in a fixed setup. I plate solve for pointing accuracy no matter what mount I use, so there's nothing new there for me. I very rarely have to do any alignments, so automatic alignment star centering and assisted polar alignment won't gain me much - and the autoguiding rig sits there, ready to go at all times. That said, I was due for a mount change here and I selected one (mount only) just because it intrigued me and it is scheduled for delivery this afternoon. I should have it set up in the observatory this weekend. Probably no stars this weekend, though. I do look forward to having axis home switches again (makes me feel more secure about remote operation).
Whichwayisnorth
Reged: 07/04/11
      #5793287 - 04/11/13 09:20 PM
Yep! However it slopes down very steep into a street that slopes down even steeper.
Hilmi
Reged: 03/07/10
Loc: Muscat, Sultanate of Oman
      #5793722 - 04/12/13 02:02 AM
Add a manual whinch attached to the side of the house
travelenfree1952
Reged: 12/03/05
Loc: California
Re: LX850 14" [Re: Whichwayisnorth]
      #5793822 - 04/12/13 05:48 AM
You wanted to send me a PM. I am now accepting PMs.
Travelenfree1952
GlennS
Reged: 06/19/12
Re: LX850 14" new [Re: travelenfree1952]
      #5802465 - 04/16/13 12:20 PM Attachment (81 downloads)
This little tidbit is not really related to the 14". I have a 10", but this will be an issue for ALL...
Meade was nice to include (for free -- well, sorta) a Zero Image-Shift Micro Focuser with all of the LX-850 SCTs. This device actually works quite well -- with one exception.
If you are into Astrophotography using a CCD (not dissing SLRs) and you use something a bit bigger than a DSI, the focuser will slip, causing focus to change -- and not in a good way.
I was using the ZISMF (Zero Image Shift Micro Focuser) for a few imaging sessions, and it was noce to be able to focus from my laptop. This all changed a few days ago.
I was imaging M82 near the meridian -- 6-hour sequence. After a few images, I started to notice fatter stars, then stars with doughnut holes in them -- the focus was now wrong.
My camera, filter wheel and adaptive optics come in at 6.4 pounds -- since M82 was quite high in the sky, the scope was pointed nearly straight up, with the full weight of the camera at the bottom. The ZISMF is a pressure/roller design -- I guess it just doesn't hold up under any real weight at the end of the optical train. Since I am imaginig that many purchaser of LX-850's will be using them for AstroPhotography, and have a fairly substantial camera at the end of it, this will pose a significant problem.
The LX-850 itself is performing quite well, and I have been able to get some really nice images -- which will continue as soon as I pull that ZISMF off the rear cell.
This device needds to be redesigned -- some sort of gearing, or at least a locking mechanism that can be engaged once focus is obtained.
The attached image will show what can happen -- the first image was quite sharp (I use a Bahtinov Mask), and the stars were small and sharp. This is the 6th Red image in the sequence.
Edited by GlennS (04/16/13 12:31 PM)
Hilmi
Reged: 03/07/10
      #5803860 - 04/17/13 01:58 AM
I have always felt that the ZISF could be further improved when it comes to load carrying capacity. With lighter loads, it is surprisingly accurate and allows for fully automated focusing. I even own a controller that allows you to use it independent of a Meade Mount
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Re: LX850 14" new [Re: Hilmi]
      #5804248 - 04/17/13 10:10 AM
You don't say where in SoCal you are but it's clear in Chula Vista till next Wednesday. Finally. I hope the same for you. BTW, those LX850's are really beautiful things. Congratulations.
Whichwayisnorth
Reged: 07/04/11
Re: LX850 14" new [Re: CharlesW]
      #5804430 - 04/17/13 11:57 AM
I am in Corona 92883. It was cloudy and almost rained yesterday but did clear up at night. However the wind has been from 15-30mph with 40mph gusts. Right now it is perfect. I am thinking of setting up tonight. I just received my 24/7/365 cover from Astronomics yesterday so I can leave it up for a while.
galaxy_jason
Vendor
Reged: 05/22/07
Loc: Texas
      #5804606 - 04/17/13 01:59 PM
Something is not right. I am using this with around 6 lbs of camera and filter wheel. Focus does not slip. Focus will change with time due to temp changes in the OTA. It can be significant but it is normally gradual. Make sure the set screws for the adapter rings are seated properly and are tight.
gavinm
Reged: 08/26/05
Loc: Auckland New Zealand
      #5804834 - 04/17/13 04:17 PM
Even though I replaced it with a Moonlite, I never had a problem with the Meade microfocuser either, and my camera was pretty heavy (+filter-wheel and AO8)
GlennS
Reged: 06/19/12
Re: LX850 14" new [Re: gavinm]
      #5804928 - 04/17/13 05:13 PM
Every thing is tight. I was able to observe the shaft slip as I slewed the scope as an experiment -- This on just can't handle the 6.4 pounds -- maybe 6 is the limit. This is a brand new one -- the first one I had woould slip with the weight of a 25mm eyepiece (heck, all I had to do was rothate the ZISMF in my hand with no weight -- the thing would slide up and down freely.
Whichwayisnorth
Reged: 07/04/11
      #5805217 - 04/17/13 06:49 PM
Assuming you adjusted the little allen head screw on the bottom that tightens it, I have no other ideas for you. I don't plan to use the one I have though. I'm looking at a Moonlight.
galaxy_jason
Vendor
Reged: 05/22/07
Loc: Texas
      #5805252 - 04/17/13 07:00 PM
Yes, even though the instructions say it is adjusted at the factory, you can tighten the Allen screws holding the rollers. That should fix the issue and eliminate any fkexure. If you are using a very heavy camera you may need to upgrade from the supplied focus but it should work for most applications
shkong
Reged: 01/18/13
Loc: WA
      #5806004 - 04/18/13 01:42 AM
If LX 850 14" work reliably.
I will jump to it to keep it lifetime for both visual and AP..
I will keep coming back to this thread
Orion 10 inch F3.9 Newt
Paracorr 2
CGE mount
Zhummel 12 inch Dob
9 registered and 25 anonymous users are browsing this forum.
