Observing >> Deep Sky Observing
nytecam
Reged: 08/20/05
Loc: London UK
is Leo I visual? new
      #5775982 - 04/03/13 04:56 PM
I'm getting told that faint dwarf gxy Leo I just north of Regulus is not a visual target but that can't be true.
David Knisely
Reged: 04/19/04
Loc: southeastern Nebraska
Re: is Leo I visual? new [Re: nytecam]
      #5776065 - 04/03/13 05:51 PM
Leo 1 *is* a visual target as long as you have a dark sky (ZLM 6.0 or fainter). I have seen it a number of times in my 10 inch Newtonian and others have seen it in smaller telescopes as well. It isn't bright (and you have to keep Regulus out of the field of view), but it can be seen as a dim diffuse oval glow roughly 8' arc x 6' arc in size. It is in reality probably somewhat larger than this, but that is about all I see of it. Clear skies to you.
Edward E
Reged: 03/26/06
Loc: Tucson, Arizona
      #5776210 - 04/03/13 07:06 PM
I have heard that it is and the late Mr. Scott Houston of S&T Deep Sky column reported that he saw it with a 10" reflector in Kansas, USA. I looked for it with an 8" f6 Reflector in the past but never saw it; I plan to go after it with my 20" f4 this weekend from 6+ mag limit skies of southern AZ, USA. I will let you know if I see it.
Feidb
Reged: 10/09/09
Loc: Nevada
Re: is Leo I visual? new [Re: Edward E]
      #5776568 - 04/03/13 09:46 PM
I could have sworn I've seen it before but not in my scope. I just checked my database and the last time I looked for it and logged it was in 1986 with my home-built 8-inch f/9.44 scope from Incirlik Air Base in Turkey. This was just before I completed my 16-inch f/6.4 Dob. There was probably no way I was going to see it from 570 feet next to a city of 500K people on a brightly lit base either.
This is the time to check it out with my better equipment at a much better location. Maybe this weekend if the weather holds.
Dave MitskyModerator
Reged: 04/08/02
Loc: PA, USA, Planet Earth
Re: is Leo I visual? new [Re: Feidb]
      #5776691 - 04/03/13 10:47 PM
There was a thread not too long ago where Leo I was discussed. I've observed it from dark sites a number of times through several different telescopes. I've also seen Leo II but it was a far more difficult target.
Dave Mitsky
nytecam
Reged: 08/20/05
Loc: London UK
Re: is Leo I visual? new [Re: Dave Mitsky]
      #5776993 - 04/04/13 03:52 AM
There was a thread not too long ago where Leo I was discussed. I've observed it from dark sites a number of times through several different telescopes. I've also seen Leo II but it was a far more difficult target. Dave Mitsky+
Thanks Dave - it's here - did a search but didn't find it hence my duplication with this thread. But I'll now try for Leo II and III - couldn't find Leo IV in Megastar
Frank
Reged: 01/18/09
Loc: Netherlands
      #5777783 - 04/04/13 01:49 PM
Celestron C14, SQM21.4, low magnification and Regulus out of the field and succeeded.
MessierScott
Reged: 06/18/07
      #5778200 - 04/04/13 05:42 PM
Yes, it is!
Get to dark skies and move Regulus off the edge of the field. It's definitely not obvious, but I've picked up a nice large oval glow against the background sky.
Akarsh Simha
Reged: 03/27/07
Loc: Austin, TX, USA
Re: is Leo I visual? new [Re: MessierScott]
      #5785052 - 04/07/13 11:32 PM
While I could not easily see Leo-I from a Bortle 4 observing site (it might have been possible with some more careful hunting) with my 18", it was obvious in the same aperture from Bortle 1 skies at TSP.
My guess is that dark skies are of utmost importance. If you have sufficiently dark skies, my guess is that you'll see it with much smaller aperture.
jgibson1@emich
Reged: 06/11/06
Loc: Tucson, AZ
      #5786853 - 04/08/13 09:05 PM
Hey that's the first time someone referenced one of my post here on CN!!!! YAY.......
I will agree with everyone and say Leo I is certainly a visual target. Just as everyone else stated you will need dark skies. However you will also want very transparent / dry skies. From my dark sky site back in MI I was never able to see Leo I in my 12" dob. This MI site was about 800' ASL and was fairly humid. My first attempt at my new dark sky site in southeastern arizona Leo I was rather easy in my 12" f/5 dob. This desert site is ~6000 feet ASL and very dry. I'm am certain it would be visible in less ideal locations but not as easy a target.
I hope to be out in the Chiricahua Mtns this coming weekend imaging and observing. Leo I will for sure be on my list and I will include Leo II and III.
Clear Skies,
Jason
Edward E
Reged: 03/26/06
Re: is Leo I visual? new [Re: jgibson1@emich]
      #5787816 - 04/09/13 11:01 AM
Congratulation on your being referenced Jason! Now your in the Big Leagues.
I had a go at Leo I this past Saturday with my 20" f4.5 using a Meade 14mm UWA 4000 (163X). The seeing was average at the Chiricahua Astronomy Complex(CAC) operated by the Tucson Amateur Astronomy Association (TAAA)located just west of the base of the Chiricahua Mts but transparency was very good. Stars to 6+ mag were visible. Keeping Regulus on the far edge of the VOF and when seeing was steady, I could easily see a round, brightening, like that of an unresolved globular cluster in the center of the FOV. I found Leo I is quite sensitive to seeing conditions as I observed it for ~ 20 minutes with varying seeing conditions.
Jason, where are you observing at in the Chiricahua Mts?
jeff heck
Reged: 01/16/06
Loc: stl,mo.
      #5788910 - 04/09/13 06:43 PM
It sure isn't for me with the 16" from the dark skies of central Kansas. Mass averted imagination syndrome, maybe?
Kraus
Reged: 03/10/12
Loc: Georgia.
Re: is Leo I visual? new [Re: jeff heck]
      #5789382 - 04/09/13 11:45 PM
It's a visual target if you see it. Tonight for me it was not. It's a toughie. Even with the triangle to the west and two stars to the east, it's still hard. It's just not obvious. I'd put it up there with the Horse Head nebula.
jgibson1@emich
Reged: 06/11/06
Loc: Tucson, AZ
      #5792178 - 04/11/13 11:41 AM
Edward,
I typically setup a few miles into the Coronado National Forest off of 42. There is a large open clearing with large concrete slabs that is nice. It is around 6k feet if I recall. Not the best view to the horizon but perfect for imaging.
If I'm only observing I will setup in the Echo Canyon parking lot in the Chiricahua National Monument. That's a great location with views all the way to the horizon for darn near 360 degrees.
I have been trying to make it to a TAAA meeting but my schedule has not cooperated. The resources available to the club members is very impressive. I emailed a club officier some time ago but never got a response.
Clear Skies,
Jason
Galicapernistein
Reged: 09/24/07
Loc: Detroit Michigan
Re: is Leo I visual? [Re: jgibson1@emich]
      #5794239 - 04/12/13 11:38 AM
Edward,
Clear Skies,
Jason
From Michigan to the Chiricahuas - you are definitely moving up in the world. I was there one night on vacation, and I couldn't figure out where the light was that was causing all the shadows on the parking lot, then I realized that it was the Milky Way! That's the kind of light pollution I like.
Edward E
Reged: 03/26/06
      #5794394 - 04/12/13 12:59 PM
Sorry to hear that the Club's officer did not respond to your request. They are usually very good on following up on request for info. What info are you needing? I might know the answer or can direct someone to you.
jgibson1@emich
Reged: 06/11/06
Loc: Tucson, AZ
      #5794590 - 04/12/13 02:14 PM
Edward,
No worries! I went back in my email and found my message. I had sent it to the TAAA-INFO address. Maybe no one is monitoring this mailbox? The message was sent prior to my moving to Tucson. I will send a PM with a bit more info.
From Michigan to the Chiricahuas....
Yup! A serious astro upgrade. I had the same MW shadow experience last April when I was there on vacation.
Clear Skies,
Jason
DJCalma
Reged: 01/17/13
Loc: Northern California
      #5794621 - 04/12/13 02:24 PM
What combination of aperture, field of view, magnification, would be necessary to visually detect Leo I in a white zone? ie Downtown Los Angeles.
MikeRatcliff
Reged: 06/12/04
Loc: Redlands, CA
Re: is Leo I visual? new [Re: DJCalma]
      #5794758 - 04/12/13 03:35 PM
Visually from downtown LA? Impossible. You're into photography territory. The surface brightness of the galaxy is less than the sky brightness. Nytecam has a nice setup and frequently posts images of faint objects here.
Feidb
Reged: 10/09/09
Loc: Nevada
Re: is Leo I visual? new [Re: MikeRatcliff]
      #5796393 - 04/13/13 10:57 AM
Tried last night, Friday, April 12, 2013, from Redstone Picnic Area on the north shore of Lake Mead and no dice. It was dark enough but couldn't pick it out though I was looking directly at it. I had the exact star pattern in the field at 102X, but the glare of the star, Regulus about made it impossible to pick out the faint glow. I switched to 220X which narrowed the FOV and darkened the background (plus cut out the glare of Regulus) but didn't help a bit. However, I easily picked up IC-591. A very faint oval glow. Sweeping back from there to the star pattern where Leo I was, I couldn't even tell a difference in the sky background. My observing partner tried also and between the two of us, nothing. He tried through his 10-inch, same result.
Sky conditions were plenty dark but maybe not ideal. There were high thin clouds moving throuh the area, giving inconsistent seeing and transparency so maybe...
I still think I've seen it before but either through another scope or forgot to log it, which is unlikely.
I'll try again next month.
1 registered and 4 anonymous users are browsing this forum.
Moderator:  Dave Mitsky, Phillip Creed, okieav8r
