Pages: 1 | 2 | 3 | (show all)
Jeff Morgan
Reged: 09/28/03
Loc: Prescott, AZ
Re: Is Self Centering Adapter better for Collimating? new [Re: Starman1]
      #5837488 - 05/02/13 11:50 PM
Thanks for mentioning that Don - in the excitement of getting a new astro-toy (as witnessed by styrofoam peanuts all over the office floor), that one completely escaped me.
Reged: 06/16/04
Re: Is Self Centering Adapter better for Collimating? new [Re: precaud]
      #5837635 - 05/03/13 03:56 AM
How can it possibly be true that the EP is so tolerant of axial misalignment as you suggest? It makes no sense to me.
Try it, loosen the eyepiece and tilt it while maintaining focus. The amount of tilt possible due to slop is small and does not affect the image...
As I have said before, proper alignment of a cylinder in a tube is best done by seating the shoulder of the eyepiece/adapter/collimator against the top of the focuser drawtube, this ensures that the eyepiece/adapter/collimator is parallel to the drawtube axis.
Howie Glatter
Vendor
Reged: 07/04/06
Re: Is Self Centering Adapter better for Collimating? new [Re: Jon Isaacs]
      #5837674 - 05/03/13 05:40 AM
Hi Jon,
"proper alignment of a cylinder in a tube is best done by seating the shoulder of the eyepiece/adapter/collimator against the top of the focuser drawtube, this ensures that the eyepiece/adapter/collimator is parallel to the drawtube axis."
If the top face of the drawtube is square to the drawtube bore, and the drawtube bore is an accurate cylinder, this is fine.
In the unlikely though possible case that the face of the drawtube is not square with the bore, or if the drawtube bore has any taper, tightening the clamp screw may tip the eyepiece, forcing it out of 360 degree contact with the drawtube face.
precaud
Reged: 12/05/12
Loc: north central New Mexico
Re: Is Self Centering Adapter better for Collimating? new [Re: Howie Glatter]
      #5837760 - 05/03/13 08:03 AM
I have four 2" to 1.25" adapters here. Three of them exhibit some combination of a) the top plate not being square to the drawtube, and b) the drawtube bore not being perfectly parallel to the outer adapter wall.
Since, when installed, the tool references the focuser drawtube, the top plate is guaranteed to reflect the inaccuracies of those other surfaces PLUS its own.
PS - I should have said, the Parallizer is the one good one.
SACK
Reged: 08/11/11
Loc: TX
      #5838816 - 05/03/13 05:45 PM
A good tip there Howie.
8 registered and 46 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
