orion69
Reged: 05/09/10
Loc: Croatia
10 Micron GM1000 HPS with 6" APO for AP? new
      #5776124 - 04/03/13 06:17 PM
I'm in the market for new mount which will be used exclusively for AP in combination with 6" APO, total weight with cameras and other stuff would be <20kg, probably somewhere around 18kg. My money limit is around 7500 euro so this looks like a good choice.
Since mount capacity is 25 kg (of photographic equipment I believe), is it likely that I would have problems routinely achieving 30min guided subs @ 750-1000mm FL?
Anyone have some experience with this mount?
Mount info: http://www.teleskop-express.de/shop/product_info.php/info/p4789_10-Micron-GM1...
Any information is greatly appreciated...
Thx
Edited by orion69 (04/03/13 06:20 PM)
seryddwr
Innocent Bystander
Reged: 02/19/10
Loc: La-la land.
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: orion69]
      #5776882 - 04/04/13 12:49 AM
That looks like an excellent mount. I've had some dealings with TS, they seem to be a very good company.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: seryddwr]
      #5776912 - 04/04/13 01:35 AM
30 minutes guided should be no problem. I do 20-30 minutes guided all the time with my Mach1 which is a comparable mount. Heck I could even do 20 minutes UN guided at 700mm (very good polar alignment required, < 5').
It's a scandal that the Mach1 costs even more than the 10Micron over there! that's $9400 equivalent.
vdb
Reged: 12/08/09
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: orlyandico]
      #5776926 - 04/04/13 01:46 AM
Per on SGL did a review, you can do easily unguided images even up to 30 minutes.
Here the unboxing thread:
http://stargazerslounge.com/topic/177893-gm1000hps-unboxing/
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: vdb]
      #5777439 - 04/04/13 11:15 AM
I'm going to be bringing one of these back from NEAF with me and will start playing with it when I have the chance. Ideally, mounts like these (i.e., high end mounts) should be much more capable of handling loads closer to their rated capacities than most of the mass-produced mounts so you should be OK. But I always have to wonder why anyone would bother with unguided imaging.
orion69
Reged: 05/09/10
Loc: Croatia
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: EFT]
      #5778086 - 04/04/13 04:33 PM
To be honest, it looks kinda small to me. Although I'm aware that this feeling is not based on facts, I really need to be sure that it can handle 6" refractor without problems and produce very long subs, I can't throw 7500+ euro just like that. Very good thing is that manufacturer is near (Italy).
@Ed
I would be really thankful for any info...
I will guide, have no intention to do unguided imaging since my setup is semi-permanent.
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5310396/page...
famax
Reged: 07/01/07
      #5778388 - 04/04/13 07:10 PM
you can check this...unguided
http://www.astronamis.net/t2561-1-essai-10-microns-hps1000
orion69
Reged: 05/09/10
Loc: Croatia
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: famax]
      #5778411 - 04/04/13 07:29 PM
Thanks, that is very encouraging!
Per Frejvall
Reged: 09/28/12
Loc: Saltsjöbaden, Sweden
      #5779938 - 04/05/13 03:39 PM
Hi!
I have a GM1000HPS and a GM2000HPS and they're both excellent mounts. I have never guided them...
The tricky part about going unguided is that you need to get the models right. Getting the right involves a system without random flexure. It can model a nice mirror flop or focuser slack that happens at the same point repeatedly, but no model builder in the world can handle random flexure.
Once you get your telescope and pier in proper order you will get half-hour subs unguided at 1500mm FL from these babies.
A suggestion would be to buy from Baader Planetarium as they handle the support for 10Micron. You also need a good driver (ASCOM) and some software to build the model. I have written an ASCOM driver that has the ability to work in J2000 (which 10Micron's can't in its present incarnation) and a model maker that builds a model fully automated in about 10-20 minutes. The model is kept in-mount so you do not need a PC once it is done.
My software is available for free at http://astro.frejvall.se
All the best!
/per
orion69
Reged: 05/09/10
Loc: Croatia
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: Per Frejvall]
      #5780079 - 04/05/13 04:24 PM
Thank you very much Per!
orion69
Reged: 05/09/10
Loc: Croatia
      #5782549 - 04/06/13 08:13 PM
Can I download user's manual for GM1000 HPS from somewhere?
Couldn't find it anywhere...
pbsastro
Reged: 03/21/07
      #5792509 - 04/11/13 02:27 PM
Per,
Can we pan manually while the motor keeps tracking? Can the clutches adjust friction for that purpose?
I value the feature of being able to move the scope manually (with adjustable friction) and not loose alignment. Also without the need to keep locking and unlocking the clutches. Just push to move while keeping aligment, like Discmounts for example. Only in this case I would have tracking as well.
Pedro
olivdeso
Reged: 02/20/11
Loc: Paris FR
      #5793790 - 04/12/13 04:13 AM
In this case, you may consider a second hand AP900, or even a new one. The AP900 is on sale at Ovision/France. They also have a second hand one a little bit cheaper (ask Gilles)
http://www.ovision.com/Le_Coin_Des_Affaires.html
Since you have a semi fixed set up, you can acheive a very good polar alignment using pempro. Pempro will also be very usefull to programm the PEC (it mesures and program the mount through the serial link). The remaining PE is about 1". So you can guid very well
At my side, I am using the AP900 with a 6" and other refractors, up to 70lbs. Using PHD guiding, I could guide at 0.2" RMS for 10min sub. I did not run 30min sub yet, but should not be a problem, only a matter of polar alignment, and pempro helps a lot for that, especially with AP mount.
pbsastro
Reged: 03/21/07
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: olivdeso]
      #5794159 - 04/12/13 10:50 AM
I am trying to decide between a 1000HPS and Mach1, but not easy at all.
They both have the same price here in EU.
Following specs, they have about the same capacity.
The 1000HPS has absolute encoders, Ethernet and all enclosed cables.
The Mach1has no encoders, no ethernet and has semi-external cables.
HOWEVER, the 1000HPS weights the same as the AP1100. And weight is very important to me.
So, the 1000HPS has the capacity of the Mach1 but weights the same as the AP1100. Unless 10Micron is even more conservative than AP about capacity.
So I have to choose, weight or encoders.
1000HPS seems a much better design in everything except weight, but weight is so important…
One minute I think I can not miss all the free 1000HPS features. One minute later I think it may be too heavy for me.
Mike X.
Reged: 06/28/10
Loc: Greece-Athens and Rome-Italy
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: pbsastro]
      #5795192 - 04/12/13 06:41 PM
I would spin a coin and let fate decide Your's is a nice dilemma but fortunately both are excellent mounts...so you can hardly go wrong.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: Mike X.]
      #5795737 - 04/13/13 12:58 AM
you know the old saying... the best scope is the one you use.
if the weight means you are demotivated from going out and using the mount, then the mount has exactly zero utility.
the Mach1 does seem like old technology now, but it is still the lightest great mount you can buy.
CounterWeight
Reged: 10/05/08
Loc: Palo alto, CA.
      #5797437 - 04/13/13 08:19 PM Attachment (41 downloads)
Just for sake of 'sayin so', I've used my TEC APO160ED (both at native f/8 and reduced with A-P rig in the focuser to f/6.x) + a piggyback 80mm guidescope on the A-P Mach1 GTO with no problems doing long NB exposures night after night, though I was guiding. Here is a link to one of the images. there are more on that site as well, I think it's important that if I make the claim I have imagry to support it - just don't hold my processing against me?
Yes, I think being 'permanent pier mounted' makes a heck of a difference too. here is a pick, the Mach1 looks almost comically small but it does the deed!
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: 10 Micron GM1000 HPS with 6" APO for AP? new [Re: CounterWeight]
      #5797950 - 04/14/13 08:28 AM
I don't see any reason why the Mach1 can't do it. It has 6" worm wheels, same as the Tak NJP which is 70 lb rated.
Per Frejvall
Reged: 09/28/12
Re: 10 Micron GM1000 HPS with 6" APO for AP? [Re: pbsastro]
      #5800355 - 04/15/13 11:49 AM
Per,
Pedro
Yep.
/p
12 registered and 23 anonymous users are browsing this forum.
