rkayakr
Reged: 10/27/10
Loc: Northeast Ohio
iEQ45 AZ at NEAF
      #5814451 - 04/22/13 12:15 AM Attachment (75 downloads)
iOptron blanketed NEAF with ads and examples of their mounts. Here are some pix of the iOptron iEQ45 AZ along with a dual saddle from the William Optics booth.
From the iOptron booth I learned that to convert the existing iEQ45 to AZ mode you need to:
    Disassemble mount head
    Remove glued on altitude scale
    -iOptron will provide a scale that attaches with a screw
    Remove polar scope
    Assemble mount head into iEQ45 AZ base ($128 option)
    Load new firmware into 8407 controller and mount
Pix attached shows also dual saddle option.
Bob
rkayakr
Reged: 10/27/10
Loc: Northeast Ohio
Re: iEQ45 AZ at NEAF new [Re: rkayakr]
      #5814455 - 04/22/13 12:16 AM Attachment (40 downloads)
Close up of dual saddle
Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
      #5814876 - 04/22/13 09:26 AM
    Remove polar scope
Bob
This is not what anyone could call a 'convertible' mount, is it. With the above regimen most owners would think more than twice before deciding to switch modes... Are they really advertising it as a Dual mount?
Dave
rkayakr
Reged: 10/27/10
Loc: Northeast Ohio
Re: iEQ45 AZ at NEAF new [Re: Cotts]
      #5814985 - 04/22/13 10:46 AM
Dave
The list is what you have to do to convert an existing iEQ45 (which I have) to the new iEQ45 AZ model. Once converted, you either stick the mount on the altitude base for equatorial use or on the AZ base for alt-az use.
I am happy that they are making parts available for those of us with existing mounts to upgrade if we want.
Bob
mgwhittle
Reged: 08/24/11
Loc: Chattanooga, TN
      #5815023 - 04/22/13 11:18 AM
My understanding is that you have to use it with the pier as the AZ can't mount to a the tripod. Is that correct?
rkayakr
Reged: 10/27/10
Loc: Northeast Ohio
Re: iEQ45 AZ at NEAF new [Re: mgwhittle]
      #5815352 - 04/22/13 02:06 PM
Mark
I asked that question and iOptron tech support said that you don't have to mount the AZ base on a pier. I could see how people with 150 mm F10 refractors might be concerned about hitting a tripod leg. I don't think that I own anything where that would be of concern.
If it were a concern, you could get the 8" high mini pier accessory that attaches to the tripod.
Bob
timmbottoni
Reged: 08/25/05
Loc: W Chicago suburbs, IL USA
      #5815377 - 04/22/13 02:13 PM
I think this is a really nice setup as it allows users to decide to update with the az option later.
The option to have two scopes is really cool too
Timm
richardlowney
Reged: 12/04/09
Loc: Wisconsin
      #5816270 - 04/22/13 08:14 PM
Bob,
As you allready have an IEQ45 and have seen it in the Alt/AZ mode do you think it could carry an NP101 and a C11 effectively. I mean with a reasonable dampening time. I've been reading the IEQ45 yahoo group and for visual in gem mode some say it can carry a C11 reasonably well. It seems the only other option is the new alt/ax mount from Orion based on their Atlas mount. It looks as if they don't recommend anything bigger than a C8 with something of equal or less weight on the other side.
Thanks, Richard
rkayakr
Reged: 10/27/10
Loc: Northeast Ohio
Re: iEQ45 AZ at NEAF new [Re: richardlowney]
      #5817158 - 04/23/13 10:36 AM
Richard
I haven't used the IEQ45 in Alt/Az mode so I have no direct experience. I don't own anything heavier than a C8 with an old cast iron JMI NGF focuser. Even loaded with a DSLR and accessories I don't have remotely enough load to test the iEQ45's limits.
The load you propose is well within the claimed limits.
"Payload: 45 lbs (20 kg) for EQ mode (excluding counterweight); 55 lbs (25 kg) for AA mode; or 55 lbs (25kg) + 33 lbs (15 kg) for AA dual mounting".
BTW - the second scope and dual saddle are now listed as an $188 option.
Bob
richardlowney
Reged: 12/04/09
Loc: Wisconsin
      #5817369 - 04/23/13 12:33 PM
Thanks Bob. I may have to give this mount a try. It is what I have been looking for and with the recent updates it sounds like Ioptron has really improved an allready good mount. I think I'll wait a little while though. Everytime I buy something this year we get a foot of snow.
21 registered and 37 anonymous users are browsing this forum.
