Momerath
Reged: 05/31/11
Loc: Upstate SC,
DSLR and registax problem HELP!! new
      #5816297 - 04/22/13 08:32 PM
The other night I was imaging the moon and took 20 or so seperate shots in RAW format. When I tried to stack even 2 of these in Registax I got a Out of memory error and the program stopped working
Could anyone please help me with this. How do I stack these images.
thanks
shawnhar
Reged: 06/25/10
Loc: Knoxville, TN
Re: DSLR and registax problem HELP!! new [Re: Momerath]
      #5816354 - 04/22/13 08:53 PM
Raw's are HUGE! Save them as TIFF's and Registax will not give you the error. ( I think, lol)
Video is your friend for the moon, take a 3 or 4 minute video and stack that, result will be better than the 20 or 100 still frames.
EOS Movie Record is free if you have a laptop or pc at your scope.
CharlesW
Reged: 11/02/12
Loc: Chula Vista & Indio, CA
Re: DSLR and registax problem HELP!! new [Re: shawnhar]
      #5817069 - 04/23/13 09:42 AM
Get BackyardEOS if you haven't already. Use the Planetary mode and it will save as an AVI movie. Registax and Autostakkert were built to handle those.
Jeff2011
Reged: 01/01/13
Loc: Sugar Land, TX
Re: DSLR and registax problem HELP!! new [Re: CharlesW]
      #5817087 - 04/23/13 09:57 AM
Definately use the movie mode on your camera. Even if you don't have a laptop available when imaging, there are plenty of converters out there that will convert a MOV to AVI after the fact.
I also recommend the following to reduce the size of the image to make processing much faster.
http://www.astrokraai.nl/castrator.php
Jasel
Reged: 02/20/13
Loc: Aurora, Ohio
Re: DSLR and registax problem HELP!! new [Re: Jeff2011]
      #5817346 - 04/23/13 12:24 PM
Ran into the same issue. AVI's are probably the best, however if your not ready for the jump you can use PIPP - https://sites.google.com/site/astropipp/ as a sort of pre-processing. Follow example 5 - https://sites.google.com/site/astropipp/example-uasge/example5 and it should help you with processing your RAW's to TIFs, and finally stack in Registax.
Hope this helps.
Momerath
Reged: 05/31/11
Loc: Upstate SC,
Re: DSLR and registax problem HELP!! new [Re: Jasel]
      #5818587 - 04/23/13 08:28 PM
Thanks for the help. I will have to try these.
RedLionNJ
Reged: 12/29/09
Loc: Red Lion, NJ, USA
Re: DSLR and registax problem HELP!! [Re: Momerath]
      #5818622 - 04/23/13 08:55 PM
Since you have a 60D, you could also use the 640x480x60fps "movie crop mode". This records the center 640x480 pixels (at 60fps) to a MOV file on your SD card.
The latest version of AutoStakkert can then take this MOV file and do its magic with the frames.
Maverick199
Reged: 02/27/11
Loc: India
Re: DSLR and registax problem HELP!! new [Re: RedLionNJ]
      #5819248 - 04/24/13 07:34 AM
Note the ZoombrowserEX that comes free with 60D can in itself convert .MOV to .Avi under edit. You can then transfer the .Avi file to Autostakkert or Registax 6 for processing.
7 registered and 18 anonymous users are browsing this forum.
Moderator:  Knuklhdastrnmr, fishonkevin, WOBentley, rflinn68
